Question about HTC P3300 Smartphone
Htc p 3300
Phone not charging.red light blink for instantwhen put for charging. after replacing battery still not work
    Sniper:
  • 143 Answers
Were you plug in th charger, there is connectors inside.
on the outer wall of it is 2pins.
slightly sprise them, not too much coz you could break them.
anyway this should work, im doing it at the moment, its only a quick fix but will charge your phone..
Posted on Jan 07, 2010
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 67 Answers
Dismiss all messages/notifications (for NO Blinking amber light), disable vibrate
attach the original charger, keep phone on a flat surface, find optimum position where the amber light is continuous.
repeat same if you answer any calls or move the phone
Posted on Sep 28, 2009
Orange light blinking mean
just because it works on another phone doesnt mean its not the charger.
Mar 27, 2014 | HTC Cell Phones
I have dropped my mobile HTC touch P3450 , it got switched off. After while I have put it to charge , the red indicator was on for a while. But it went off after that and i could not switch on my...
Before asking them to touch your phone inside better do this first. Remove the battery and then insert it again. Maybe pins in the battery got jammed when you dropped it. If this doesn't work, while in charge leave it for a minute or so, if the red light is on, feel the back of your phone and feel it again if the red light goes off. If it heats up then it means a circuit is shorted causing your battery to heat up. As of asking service engineers, better ask the one you personally knew or have a second opinion before proceeding to have them repair it.
Apr 05, 2011 | HTC Touch P3450 Smartphone
Hi, what is the flashing light on my HTC wildfire screen ? sometimes it's flashing and sometimes not so could you please tell me how it works normaly ? thank you
i think you mean the led above the screen. it is a led that means a lot of things
like: orange - recharging green - full battery red - low battery
there are more things like notifications for text messages (all apps can make ir blink for their own reason)
hope this helps
Feb 20, 2011 | HTC Wildfire Cell Phone
My HTC mobile not going to on after pressing power button and on connection of charger it is showing red LED. Same there here. I woke up this morning and my phones just dead. Even if i connect the charger...
Remove the battery then connect the charger without the battery. Then hold down the power button for a few seconds. The red light may come up for a quick second during this process.
Don't remove the charger. After the red light goes off then insert the battery and check if the light turns amber or orange.
Leave it in orange or amber light state for about 2 minutes. After that, try to turn it on. If it turns on then it is resolved. If not then there is a hardware problem with your phone and it needs to be checked at any HTC Service Center.
Jan 28, 2011 | HTC Touch P3450 Smartphone
What does blinking orange light on the phone mean?
Solid amber light when the battery is being charged.
Flashing amber light when the remaining battery level reaches below 10% htc has had some problems with batteries,when charging, if you are getting the flashing amber light feel the back of the phone. if it is feeling hot you may have a bad battery. hope this helps.
Jan 23, 2010 | HTC Touch Cruise Smartphone
My HTC p3300 battery not gettin charged. It works on direct power for some time and get automatically shutdown after some time..indicating no charge. Keeps shutting down often.
I too have been experiencing problems. Replaced the battery but it happened again. The battery says it is at almost 100% capacity however several times in the day, when I go to turn it on it doesn't respond. I end up taking the battery out and then have to connect it to a charger (USB) so that the charging light blinks red once and then turns off. I can then put in the battery again and it will start up again. If I don't connect it to the charger cable to drain (get the red light to flash once), and try just putting back in the battery, I've noticed that the screen has a faint glow as though it was on but the screen is completely blank. I'm starting to think that there must be a short circuit somewhere because I'm going to assume that the new battery is good.
Feb 20, 2009 | HTC P3300 Smartphone
HTC S710 Smartphone not switching on
The battery is flat.
If the battery is very flat sometimes the phone will not start charging or turn on even when a power cable is connected.
This worked for me:
- Remove battery
- Insert power cable/usb cable
- Orange charge light should start flashing
- Re-insert battery
- Leave phone charge for a couple of hours
- Turn on
Feb 03, 2009 | HTC S710 Smartphone
Htc not turn on, red light on
Remove the battery from the mobile, press the power button, for 30 seconds.
Re attach the charger , switch on the phone. If it turns on switch it off again and reinsert the battery and check.
If none of the above steps work, you would have to take it in for repairs as there could be a problem with the power supply inside the phone , that would require special tools to open
Thanks
proton
Oct 11, 2008 | HTC P3300 Smartphone
HTC P3300 Smartphone Logo
293 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
