Question about Panasonic NN-S753 Microwave Oven
Door does not secure when closed
I have an electric four burner stove. the over does fails to latch securely. the cleaning mode does not go on, and the oven light is on all the time. Please advise. pfr@rousmaniere.com
  • 355 Answers
Hello dear
it could be bad connections at elements or bad elements a volt meter works good for this problem
well
Is the gas able to flow freely through and out of the bad burners? Sounds like they may be clogged somehow
Posted on May 14, 2009
  • Rohit  Asthana
    Rohit Asthana May 14, 2009
    welll after seeing model no i can conclude it
    Thanks for that ID number. That's a big help.
    Now, looking at the schematic, it's clear that you would have a shorted primary latch switch (top door switch) or that switch's mount is damaged.
    For safety, disassembly and diagnosis of door switch trouble, see my generic files:
    http://www.microwavedisplay.com/safety.t...
    http://www.microwavedisplay.com/disassem...
    http://www.microwavedisplay.com/doorsw.t...
    If a switch is all you
    need, we offer a universal type for only $5 postpaid which you can
    order
    here.
    We're
    happy to help you with free advice and we'd appreciate your
    thoughtful rating of our answer.
  • Rohit  Asthana
    finally the problem could be
    Either you have a faulty door interlock switch(es), or the door latches
    (on the door) have been damaged and will not activate the interlocks.
    either way, you have to be conversant with adjusting microwave latch
    assemblies once the repair has been effected AND THE USE OF AN OVEN
    LEAK DETECTOR IS IMPERATIVE for final testing or the end user will be
    subjected to harmful levels of microwave radiation.
    Hope you are understanding me
I am unable to close the door of my Miele microwave oven model M8260. Is it possible to fix this?
I assume you mean that the door can be closed but will not stay secured shut. The only way to tell is to take the cover off and inspect the latch assembly. I have found that a small spring can break. It can usually be found at your local hardware store.
Nov 19, 2017 | Miele Microwave Ovens
Door catch is stuck in unit so door won't close and microwave won't work
No, the only way is to take it to a technician. The door and catch has about 4 safety interlocks to stop you getting microwaved. The case has security screws only the techs can undo.
Apr 07, 2016 | In Microwave Ovens
Fix my ge spacemaker microwave door from wiggling at the door hinges (not the latches)?
http://youtu.be/nIdT4kS3noY This link will show you how to gain access to the problem. Sounds like a lose screw or two
Jan 03, 2015 | GE Microwave Ovens
My whirlpool microwave combo #4450785A stopped working the light went out and it says door on it please help it is not starting and says door
The door latch could be defective. Your microwave is designed to operate only when the door is securely latched closed.
Jul 20, 2014 | Whirlpool Microwave Ovens
E305075FPSA HighSpeed Eletrolux the door appears to not be closing tight.
No! this not normal, I'am concerned about microwave leakage, and a 1/8 gap is to much, should be tight against the seal "major safety factor" the door is out of alignment or the bottom latch is not secure "to much play" I recommend a pro simply because he needs test for leakage when the door is properly fixed.
Mar 22, 2012 | Electrolux ICON Microwave Combination Oven
Kitchenaid superba combo. Microwave gives
HI, this is an indication of a failed door switch. When the switch fails, the control cannot recognize the closed door signal. Simply replacing the door latch mechanism will solve this issue.
Replace the door latch assembly, asap.
Dec 22, 2009 | KitchenAid Microwave Ovens
Won't whut off when open door
The microwave running with the door open can be dangerous.
It's most likely the switch in the door stuck in the closed position. Or it has failed/broken in the closed position.
Sometimes the switch is just a button sticking out of the cabinet where the door pushes on it when closed -- sometimes the door latch pushes on a switch inside the latch receiver in the cabinet.
If cleaning around that switch doesn't solve the problem, you should take it to a repair shop.
Apr 28, 2009 | Microwave Ovens
Hi , Either you have a faulty door interlock switch(es), or the door latches (on the door) have been damaged and will not activate the interlocks. either way, you have to be conversant with adjusting microwave latch assemblies once the repair has been effected AND THE USE OF AN OVEN LEAK DETECTOR IS IMPERATIVE for final testing or the end user will be subjected to harmful levels of microwave radiation.
Jan 05, 2009 | Panasonic NN-S753 Microwave Oven
Door latches to microwave broken
I assume you're talking about the spring that keeps tension on the door hooks (latch heads, as they're called by Sharp). When you shut the door, the "hooks" are held down by this spring to actuate the door switches. To fix this, you'll have to separate the door panels. You can download the service manual from my Web site. There's a loop built into the latch head assembly and sometimes the loop breaks. If so, you can drill a tiny hold in it and reattach the spring there. There may also be a loop on the innner door panel to hold the spring. That one can break, too. If it's broken, you'll have to find a way to secure the spring to the panel. If the panel material is thick enough, a tiny screw eye could be inserted, then epoxied overnight to secure it. I've attached a diagram to this message that should help you. If that doesn't help you, I have the service manual for the R1600-series microwaves on my Web site at: http://www.microwavedisplay.com/R1610.pdf Repost if you need more help.
Nov 15, 2006 | Sharp R-1610 Microwave Oven
Panasonic NN-S753 Microwave Oven Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
