Question about Dometic RM2852 Refrigerator
Fridge blows circit breaker when turned on.
Trailer was stored all winter, when plugged in and fridge turned on it blew breaker outside trailer
  • 1 more comment
  • joannq May 18, 2009
    thanks for your help guys, turns out that the insulation around the element was damp. when i lit the propane it dried out and now the fridge works fine on electric.
  • Anonymous Mar 17, 2014
    When I plug my camper to pole, the fridge will trip breaker. Breaker does not trip if fridge is turned off. Camper has been sitting up for a while.
  • Anonymous Mar 20, 2014
    camper has been sitting for a while don't know how long just bought it
  • Dometic Master
  • 4,654 Answers
The refrigerator is trying to start so start relay and start capacitor and internal fan is our focus.Ok if the doors on refrigerator were closed during this time all the parts will get rust on them so we need to unplug and begin these steps when you are ready, I am here just let me know for sure the model and make match the numbers above your post. Thanks, Sea Breeze
Posted on May 14, 2009
Our travel trailer keeps flipping a breaker when we plug in 2 space heaters at a time what could be causing this?
Two heaters may exceed the capabilities of the wiring.
As you say only the plug breaker, move the other heater to that spot to see if the one heater is faulty. Also try plugging a kettle or similar to it. The breaker may just be weak.
If you are using propane heating, it must be a properly fixed appliance, not freestanding heaters because of carbon monoxide poisoning.
Dec 07, 2017 | Heating & Cooling
I just got an amcor CPLMB12000E fom a friend, it worked great for about 15 min. then the fridge turned on an blew a cecit breaker in the box. I reset itand all it does is blow harm air. I pluged it into a...
Check compressor and fan only things it can be disconnect one at a time until fault goes away and there is your prob hope this helps
Aircon chilling for a living....................
Sep 01, 2011 | Heating & Cooling
I have a travel trailer every time it gets 90 or higher outside it will blow the fuse. I have went on top and cleaned it good but no change. any ideas thanks
Where do you have it plugged in to? Is it plugged in with 30amp plug to receptacle. Which breaker is tripping, the one for AC only, or the main breaker for trailer, or breaker at plug in?
Jul 27, 2011 | Heating & Cooling
Heat worked fine all winter. Turned on A/C and blew a fuse. Replaced 3amp fuse and worked for a few minutes and blew another fuse. Checked all connections, filter, obstructions, need help...
If your blowing fuses then you have something grounded or shorted. By grounded I mean a wire has come loose and is touching the cabinet or a part that allows it to go to ground or your motor, capcitor or compressor is shorted.
Apr 25, 2009 | Heating & Cooling
Maytag MDB7130AWB dishwasher blows circit breaker.
These have been known to leak water into the door panel. If so the water can cause a short. Your breaker is keeping the machine from lighting up. Check any seals that may have been braeched in the door. Start at the dispencer latch
rubber.
Mar 07, 2009 | Maytag MDB7100AWB Dishwasher
My Maytag MTF2172HR* keeps blowing the fuse
You guys are gonna LOVE this one.
I called a local appliance repair man, who said it sounds like the compressor.
He went on to tell me if it was the compressor, I would have forked over $75.00 to him, and, now need a new fridge, as it's probably not worth to replace.
I was a bit angry, so, deciding what to do, I started snooping around the back of the fridge.
Everything back there looks brand new, and clean, so I was starting to think it wasn't the compressor.
I put in a new breaker in the circuit panel, and, still blew.
As I was behind the fridge, I grabbed the power cord, and felt something strange- looked down, the power cord was cut through and twisted, exposing the little wires inside, and, visibly crossing them.
So, I'm going to go to the appliance store, and see if they have a replacement power cord.
Thanks,
Sep 27, 2008 | Maytag 21 cu.ft. Top Mount Refrigerator,...
Dead micro
It could be a bad in-line circit breaker fuse. Unplug the microwave and take the outside cover off. Look for the in-line circuit breaker fuse. Use a plastic fuse puller (not your hands or a metal tool as there is still voltage stored in the microwave even when it is unplugged). Look at the fuse and see if it is blown. (The metal wire running length of tube will be broken. If you have one, test with an Ohmmeter.
Jun 03, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Dometic RM2852 Refrigerator Logo
128 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
