Question about Yamaha HTR-5850 Receiver
I have linertec LA-8 olx Amp
I need to know how to bridge it to power a single 1000W Sony Xplod Sub, Do i need a crossover?(The amp is bridgeable just want to know how to do it safetly)
    Genius:
  • 1,148 Answers
IF ITS A POWERED SUB,,JUST USE RCA JACKS TO THE SUB TO THE RECIEVER VIA THE PLUG THAT SAYS SUB
Posted on May 15, 2009
Amp going into protection
Is the amp bridged? If you only have one speaker connected to it, I sure hope so. How much power can that speaker safely handle and what is the impedance of the speaker? 2,4,8 ohm? A 1200 watt amp with only one speaker may be too much amp.
Jan 14, 2014 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Ive got an sony xplod 1200 watt amp thats bridgeable ive got two dual 4ohm subwoofers how do i wire this up to get the countinued bass with no cutting off
wire each sub in series inside the box, this makes them each 8 ohms, then run them parallel from the box to the amp bridged. this will give you 500 watts at 4 ohms
Apr 07, 2012 | Sony Car Audio & Video
Hey i have a sony amp (600 watt xm-zr604) with 2 10"sub(sony xplod).when i raise the volume hight enough the amp go off(red light came on) what can i try
sounds as though (at high volumes) the amp thinks it has a short circuit. This may be caused by the way you have them connected.
Speakers have a resistance and amps needs a certain amount of resistance to function right (too little resistance = short circuit)
The way it works out for the speakers is, if the two are connected to one amp output channel, the amp will see half of the resistance of a single sub. (4 Ohms/sub amp sees 2 Ohms)
If the amp instructions say that it's 4 Ohms/channel then you need to use 1 channel for each sub.
Hope this has been some help.
May 07, 2011 | Sony Xplod 800W Class AB Bridgeable...
I have a 1200 w sony xplod amp, with 2 caps, hooked to my sony xplod 1200 w 15s, I just need to know what size inline fuse I need to have connected to my power wire to my battery? I have a 40A that keeps...
with no signal input the fuse should not blow ,if it blows then the amp has a short on it ,if it blows when the volume is turned up really high the try 60 amps .
Jun 18, 2010 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
I have 2 12'' subs 1300.watts and 2 1200watts amps both bridge to push 2400.00watts do not sound lond enoungh
impedance mismatch cud be the culprit. make sure ur speakers are the right ohms for ur amp. most amps are designed to operate on a 4 ohms speaker load on bridge mode. some amps are never designed for bridge mode. so if u bridge these amps u will get less output. u have to be very careful when u make the connections. plus when u bridge two amps for 4 ohms load, the total impedance becomes 8 ohms. make sure ur speakers are 8 ohms. few ohms can make big difference on power amps.
Apr 07, 2010 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
I have a 1200 watt sony xplod amp hooked up to a 15" SBL Gorilla sub. The bass hit for a while and then started to cut off. Now it wont work unless i touch the remote wire to the power wire, and even then...
this kind of problems usually happen when the amp is not getting enough current to power up the
 amp. the moment a loud low frequency hits the amp it fails. cud be ur power unit not giving enough power to the amp or u have a loose connection somewhere on ur power line. besides 8gauge is a bit small. try using about 4gauge. should have good ground too. they draw large current so ur battery should be in top condition as well.
Mar 21, 2010 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
Amp and sub connection
Too many problems, lol. One at a time. I lost you in your post, run by me again but one amp at a time.
Jan 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sub power hadling capacity
Yes. If the rated power is 380W and the Max power is 1000W then it will handle it. Subs fry when clipping occurs. Clipping is when the amplifier is pushed past its capabilities and the output to the sub gets "dirty". The better quality the amp, the safer it will be on your speakers. It is also important to remember that the gain control on the amplifier is NOT a volume control to boot the sound, it is only to match the output from the headunit to the input handling of the amp. Cranking the gain up too much WILL CAUSE CLIPPING.
Jan 04, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Yamaha HTR-5850 Receiver Logo
137 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
