Question about HTC P3300 Smartphone
When put phone for charging red light indicate for micro second .phone complet dead again after 3-4 attempts same hppen phone is dead.HTC P3300
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 143 Answers
Where you plug your charger in..
youl be able to see the connections. well there is 2 more on the outer side. just sprise them a little bit with a pin or needle.
dont do it too much as you might snap the connection.
this should work coz im doing it atm.lol
this is only a quick fix.. but you will be able to charge your phone.
Posted on Jan 07, 2010
I am trying to charge my phone right now but it is just a constant red light where it would usually be orange and it is saying 0% charged
did you run the battery completely flat?
my phone if it has gone dead, when plugged in to charge, has a red LED for about 5 minutes where you cannot even turn it on it is that dead. after those minutes pass the phone can then be turned on, and the LED changes color to orange to indicate it is charging and is also powered on.
Jul 12, 2010 | HTC G1
I have htc p3300. once started charging its get switched off automaticaly
does the charge light stay on (orange led) on or does it go green or flash on-off orange?
could be battery issue..
on the charge slot on the bottom of p3300 there will be 2 bins left and right inside. try bending them slightly - ONLY slightly tho incase it snaps.
use a needle.
its wat im doing at the moment, im currenlty trying to figure this out so ill keep you informed if i find the soloution.
atm i have to have my phone on charge to use it, otherwise it just goes off but thats how im getting it to charge atm.
if im not in touch..
raving_nanza@hotmail.com
Oct 28, 2009 | HTC P3300 Smartphone
Htc p 3300
dismiss all messages/notifications (for NO Blinking amber light), disable vibrate
attach the original charger, keep phone on a flat surface, find optimum position where the amber light is continuous.
repeat same if you answer any calls or move the phone
May 14, 2009 | HTC P3300 Smartphone
My HTC p3300 battery not gettin charged. It works on direct power for some time and get automatically shutdown after some time..indicating no charge. Keeps shutting down often.
I too have been experiencing problems. Replaced the battery but it happened again. The battery says it is at almost 100% capacity however several times in the day, when I go to turn it on it doesn't respond. I end up taking the battery out and then have to connect it to a charger (USB) so that the charging light blinks red once and then turns off. I can then put in the battery again and it will start up again. If I don't connect it to the charger cable to drain (get the red light to flash once), and try just putting back in the battery, I've noticed that the screen has a faint glow as though it was on but the screen is completely blank. I'm starting to think that there must be a short circuit somewhere because I'm going to assume that the new battery is good.
Feb 20, 2009 | HTC P3300 Smartphone
Htc not turn on, red light on
Remove the battery from the mobile, press the power button, for 30 seconds.
Re attach the charger , switch on the phone. If it turns on switch it off again and reinsert the battery and check.
If none of the above steps work, you would have to take it in for repairs as there could be a problem with the power supply inside the phone , that would require special tools to open
Thanks
proton
Oct 11, 2008 | HTC P3300 Smartphone
PHONE DOES NOT "ON"
You can reset your HTC 3300, it starts up again.
My experience is that it has something to do with the buttons, if switched off and you push several buttons and then the on button, it will not switch on again, its blocked. You can reset it again. Can someone give me a good problem solving solution ??
regards
peter
Sep 19, 2008 | HTC P3300 Smartphone
Sudden phone shut down.
better u change your battery and try....
Aug 28, 2008 | HTC P3300 Smartphone
The phone is not switching on
new battery
charge while off
led goes off when done
May 11, 2008 | HTC P3300 Smartphone
Please help, I can't turn on my HTC. What happened?
If you have a charged battery insert it and power the phone. If it hangs or whatever then (with the phone powered on, regardless of what's been displayed) keep on the keypad the two dashes ( - ) pressed and do a reset with the stylus. Do not leave the two buttons untill a black screen appears and ask you to press send (the green call button). Press it and you are done. If your phone doesn't have a hardware damage it should start. It will start from scratch again so you might be a bit patience.
Oct 08, 2007 | HTC P3300 Smartphone
HTC P3300 Smartphone Logo
130 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
