Question about Compaq CV 7500 17" CRT Monitor
Not enough contrast \ user mode?
A month or so ago, i did something that buoght up a professional controle menu, rather then the 'user mode' one that comes up when you press the far left button on the monitor
i did something to put the contrast right down, and now there isn't enough contrast on the user bit and the colour looks realy washed
i would like to get this other mode back up, so as i can fix this, but i don't have a clue how to
i bought the monitor second hand and therefore don't have any cd's or instruction manuals
amny thanks
  • 121 Answers
You can reset it back to factory settings with the auto reset button selection or in that menu switch from advanced.
Posted on Jan 09, 2009
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Picture is dark. I need to adjust the contrast
If its starts out bright enough then rapidly goes to dark it may not be a matter of contrast. If it is the contrast hit the menu button and go into the video menu then select user defined as the setting select the contrast and adjust it to whatever specific setting you would like.
Feb 01, 2010 | Element Electronics FLX-2210 22 in. LCD...
Cannot navigate Picture Mode (Colour) menu.
After some digging, I may have found something.
With no menus onscreen, press the menu button. Then press it again. According to a post I saw on another forum, that allowed the user to enter the tuning menus.
First press gets you "Overview" and the second opens the tuning menus.
Good luck, and repost the results.
Jan 09, 2010 | Televison & Video
Color calibration
All monitors have a brightness control. Click the menu button and from the on screen menu choose the brightness and set it to your liking. There should also be a contrast control and may or may not be a backlight control. All the user controlled setting are in the OSM.
Nov 27, 2009 | Computers & Internet
Universal Remote Code for ESA
ESA; 10812, 10171, 11963 10839
ESA; 0839, 0198 0171 0812 1944 1963 1220
Dec 19, 2008 | Directed 434MHZ Remote Control
Monitor displays 'user mode' contrast icon @ 89%
If you can access the on-screen menu (see link below for manual) try and reset to factory settings.
If that doesn't resolve the problem, then also check and see if any of the control buttons are stuck, (Press button them flick finger away to try an release a stuck button)
If issue still exists, you can consult a TV repair shop, but essentially, then monitor is uneconomically repairable and it would be more cost effective to just replace it with an LCD monitor
Jul 24, 2008 | Compaq CV 7500 17" CRT Monitor
Video settings
I think this is what you need.
Before pressing Menu make sure the picture mode button is set to User then you can change your contrast etc.
Also this is how to get to the factory settings menu but don't touch anything your not sure of or you could really mess up your tv for good. Don't change settings in here unless you know what you're doing. Don't blame me if you mess up your telly.
Jan 30, 2008 | Polaroid FLM-3232 Television
Safeguard mode error 06
Defective mechanism,
a stucked mechanism is
present. camcorders are
smart. it can detect error
and shut down itself for
safety. earlier models
domino the defect if
the user is not quick
enough to react when
something goes wrong with
the camera. You need
professional service to
fix it.
Dec 12, 2007 | JVC GR-D240 Mini DV Digital Camcorder
Compaq CV 7500 17" CRT Monitor Logo
338 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
