Iv got the hotpoint wt960 and it keeps saying test and will not wash anything
Your machine has gone into service engineer 'test' mode as you have pushed a couple of buttons together by mistake. Go through this sequence .. Switch Off. Switch On (all LCD lights flash). Press Start/Cancel button (LCD panel now reads On). Together press the 3 ON/OFF STARTCANCEL and SPIN buttons like you would CTRL-ALT-DEL on a PC. The screen will show "DOFF". This means you are now out of test mode and back into normal operating mode. This happened to me and I was talked thru the sequence over the phone by the Hotpoint service assistant Emma - brilliant and free.
Posted on Jul 17, 2010
  • annetewart
    annetewart Aug 18, 2012
    Thanks so much. Romondo. Cant do without my machine.
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
How do i reset my hotpiont ultima lcd wt960 washing machine?
I have a hotpoint wt960 i did 1 load of washing, turned it off. Put next load in then it would not turn back on. any ideas???
Nov 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint WT960. After each wash there is
The hole that the fabric conditioner goes through is blocked.. use a straw to blow down it and this should solve your problem. hope this helps.
Sep 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960 comes up with test all the time
Press the Start/Cancel button until all the console Led's Illuminate
Press both Start/Cancel and On/Off buttons together until 'd off' appears
Normal screen should return and you can select a new programme. (GL = good luck)
Mar 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint wt960 keeps saying test HELP
turn the machine on whlile pressing the start and on buttons at the same time.hold until 'dOFF' appears.
Feb 22, 2009 | Hotpoint Ultima WF860 Front Load Washer
Does wt960 have an eco mode?
This model does not have a specfic energy save programme, however, by selecting a coolwash at 30oC or a mini load, you will use less energy.
These features are detailed in the user instructions.
Plz rate my solution.
Thankyou.
Jan 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hi where is the filter for a hotpoint WT960 washing machine
Its most likely built into the tub and you don't need to access it.Under the agitator is usually the place on the tub they would put a filter
May 25, 2008 | Washing Machines
Washing Machines Logo
183 people viewed this question
Top Washing Machines Experts
