Question about Panasonic AG-1980 S-VHS VCR
Programming panasonic vcr
We are having trouble programming the vcr to get all the channels we have basic cable and the channels are different on vcr.
    Novelist:
    Champion:
  • 254 Answers
First, check in the VCR setup and see if it set for cable or off-air/broadcast/antenna (not always named the same).  If it is set for off-air... then it won't tune cable channels beyond 13.  It must be set for cable mode in order to tune those upper channels (mid-band, superband etc.).
I assume you have the VCR hooked up correctly- cable into VCR antenna/RF input, VCR RF/to TV output to the RF/Ant input of the TV.
Posted on Oct 17, 2007
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
Sharp TV-Remote not working correctly
You will need to complete a channel scan from the tvs menu. I assume you have basic cable and that your cable company is still providing analog channels for you to be able to pick up any transmission on this telvision with the digital changeover and all.
May 05, 2010 | Sharp 27C-240 27" TV
I have a panasonic pv 9451- is there a way to reset the auto programming for the channels? can i reset the vcr programmed information entirelyu and start anew?i think i programmed out channel 3 which is...
Should be able to use the remote to access the VCR menu, and setup the auto programming. If not automatically, then you'll have to do each channel manually. Just check all your options in the menu.
Usually all vcr's have the option of channel 3 or 4.
Apr 14, 2010 | Panasonic PV-9451 VHS VCR
Unable to view/record cable channels with Panasonic DMR EZ48V
Here is what you will need. This is assuming you do not have a HD cable box.
1) A two port cable splitter available at your local hardware or electronics store. VERY IMPORTANT- this splitter needs to pass up to 1000 mghz so you do not interfere with the functions of the cable box. Also, when purchasing this don't be fooled gold does not always equal good (a common mistake made by folks).
2) 1 small coax cable.
3) 3 Additional coax cables. (1 long enough to reach from the wall to the cable box. 1 long enough to reach from cable box to the TV. 1 long enough to reach from wall to the VCR. These cables should be RG6 coax cable (about the width of a standard wooden pencil)
4) 2 RCA cables (Yellow/Red/White)
Here is how you need to connect the cables....
1) Use the small coax cable and connect it from the WALL to the INPUT of the two way SPLITTER.
2) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the CABLE BOX.
3) Use one of the coax cables and connect it to the OUTPUT of the CABLE BOX to the INPUT of the TV.
4) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the VCR.
5) Use one of the RCA cables and connect to the DVD/VHS COMMON OUT on the VCR. Connect the other end of this cable to the VIDEO IN on the back of the TV.
6) Use the other RCA cable and connect it to the VIDEO OUT on the back of the CABLE BOX. Connect the other end to the IN 1 on the back of the VCR.
Here is how to set up the VCR-
1) Tune the TV to the video input that you connected the VCR to.
2) Go to the auto program in the menus for the VCR and select "CABLE" as the source and you should now be able to get all the channels you would normally get without the cable box.
3) This will give you the option to record shows from basic cable on the VCR. While copying these channels you will still be able to tune the TV to CH 3 for the cable box and watch TV normally through the cable box.
4) If you want to copy one of the channels that is only available with the cable box you will still be limited to only being able to watch that channel while it is recording but here is how you will do it.
  • Tune the CABLE BOX to the channel you want to record.
  • Tune the TV to the VIDEO INPUT you have the VCR connected to.
  • Select either VCR or DVR on the VCR.
  • Select recording mode.
  • Press the INPUT SELECT button.
  • Select IN 1.
  • Press RECORD.
Hope this has been helpful....
Good Luck....
Jan 19, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
CABLE
The only way would be a scart lead from the cable box into av2 on the vcr
Oct 24, 2009 | Panasonic PV-V4022 VHS VCR
Timed recording with cable (new)
If you're referring to programming your VCR for recording, that works just like it did before the cable box was installed, but with two major differences.
The first difference is that the VCR must always be programmed to record on the converter box output channel. Usually this is channel 3, but may also be channel 4. The cable box selects the channel from the cable system, but it's always outputting to your TV on the same channel. That channel is what the VCR needs to record from.
The second change to programmed recording is that you can't program your VCR to record programs on different channels. The reason is because, as mentioned above, the VCR is actually recording from the cable box which is always on the same output channel. Unless you are home to change the channel on the box, you're stuck. For example, if you want to record a show at 10PM on channel 8 and another at 11 on channel 26, those are the cable channel numbers. The box output is channel 3 (or 4) in both cases. The VCR can't switch the box for you. It's only going to record the program on the channel you selected before you left home. You also need to leave the cable box turned on, but the TV can be off. This is probably the thing most people find confusing about dealing with a cable box.
Now having said all that, some brands of cable box do include a timer feature of their own that allows you to program the box to switch channels. This feature is used in conjunction with timer recording on the VCR. You still always program the VCR to record on channel 3 (4), but now the box can be programmed as well to switch to the channel on the system you want to record. This allows you to get around the limitation described above. If your box offers this feature, it will be accessed through its setup menu using the remote control. Ask your cable company if this is available if it's not clear from the setup menus or instructions the installer left you with.
May 12, 2009 | Emerson Televison & Video
FROM : ROD MYERS MYCO@SBCGLOBAL.NET I NEED TO RUN THE CABLE INPUT THROUGH THE VCR AND THEN TO THE TV. PROBLEM IS I DON'T KNOW HOW TO PROGRAM TV CHANNELS INTO THE PANASONIC VCR. IT CURRENTLY GOES TO CH 2, 3...
If you have the remote for the unit, with the incoming cable connected to the unit, on the remote, press menu/set up button, once in channel set up, select auto search...it may take a couple minutes for all the channels to be found...once complete, select done/exit, or press the menu/set up button again to exit.
any questions, let me know.
clarkco
Apr 29, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
How to setup my VCR to record programs from my Panasonic 42 Inch HDTV Plasma TV?
TV doesnt matter, you need to list what kind of VCR your trying to program with.
if you are programming from cable, the cable box, box or not, should be ran thru VCR then VCR to TV.
to record. easiest.
if you are doing cable to tv to vcr. make sure that tv is in one of the AV spots, so when you select input on vcr itll show your tv again. program as accordingly.
Feb 26, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Cannot program cable to tv
if your are using a cable box,all of your channels will be control only on the cable box.so, what you are going to do is use the remote control of the cable box.
Nov 07, 2007 | Panasonic PV-C1320 13 in. TV/VCR Combo
Panasonic AG-1980 S-VHS VCR Logo
119 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
