Question about Minolta Office Equipment & Supplies
My copies are blank. I replaced tonor, but still no ink.
My minolta 1080 copier won't put ink on the paper. I replaced the toner bottle, but still the pages that come out are blank.
    President:
  • Minolta Master
  • 990 Answers
Hello sir; I believe it is time for PM service, that means you need to replace drum, blade, developer, etc.
Posted on May 15, 2009
I have a Minolta CSPRO EP1083, it stopped making copies, the paper comes out blank. I put a new toner bottle in and the paper still comes out blank.
Problem on lower charger.Some times wire was broken .It has 2 wire one saparation wire and other high voltage wire may any one broken.Assemble new wire may be it fix problem.Other lower charger was damaged ,need new one .If you try clean all socket and dry.I hope your copier good working.
Aug 02, 2011 | Minolta EP1083 CS/PRO Copier
I have a Minolta Di181 black and white copier. It started printing lines all through the paper and was a little dark. I bought another copy machine because this one is old. It is a imagistics zc25 this...
Well, you put your self into a pickel. With the Di181 you most likly neede a new drum and cln blade & a good cleaning. Now with the Imagistics, you may have the same problem, but you put Minolta toner into a Imagistics. Thats like putting oil into water and wonder why they don't mix? Now you need to replace the drum & blade & developer & toner and vaccum out all the toner and start off with all new. Good Luck
Jul 28, 2010 | Panasonic DP-8020E Black and White Copier
How can I tell may Xerox 5334 to feed toner?
Power the machine off. Press and hold the zero while you power the machine back on.
Then enter routent 9-05 and press start. that is the tone up procedure.
Jul 27, 2010 | Xerox Office Equipment & Supplies
I just replaced the toner cartridge in my Minolta EP1031 CSPro copier and it is putting out way too much toner. I tried running it with just a blank white piece of paper to try and get the toner cleaned...
There is not awhole lot to do.. The toner bottle you put in was it a white or light blue? White is toner & light blue is developer. Developer is used by a tech to replace. It sounds like the copier is over toned. You are most likely going to have to have the developer replaced to solve the lose toner... Wish I could give you a easier solution.
May 22, 2010 | Minolta EP1031/1031F CS/PRO Copier
Replaced Konica 7022 toner and add toner light stays on
Remove the toner bottle carefully, pwr off and unplug the machine , then plug it in and turn it on do not put toner bottle into machine until asked for.
Jun 30, 2009 | Konica Minolta Office Equipment & Supplies
Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Jun 18, 2009 | Konica Minolta Office Equipment & Supplies
How do you change the toner in a Minolta Dialta copy machine?
Check the back of the machine see if the sticker is still on it. Model number should be there. As for toner carefully remove the toner bottle turn the machine off wait ten seconds turn the machine on do not put the bottle of toner in until the waning comes on to tell you to add toner. The word "up" on the toner bottle should be visible onthe tup when you install it, so should the hole. Theres a small nub that will lock int place when installing it.
Apr 01, 2009 | Minolta DiALTA Di183 Copier
Canon Copier Model C122F - error light flashing
A common mistake is that people think that the waste toner needs to be emptied and instead the toner needs to be replaced --- and vice versa. Check to make sure that the toner bottle is not empty. Also, if you made copies that took ( used ) more toner then the machine was able to replenish, the machine has not had a chance to catch up. Place a white sheet of paper on the platen glass and make blank white copies. You may only be able to get 1-2 copies at first but as the device catches up with the toner replenish you should be able to make more. The blank copies you make -- do NOT put that paper right back into the machine. Lay it flat and let it cool, this will help prevent unwanted jamming due to heat build up in the paper. IF you have good amount of new toner in the machine, gently tap the front line ( or rear line) that feeds the used toner into the waste bottle. Sometimes the waste toner will clog and back up into the machine giving false 'waste toner full' message.
Jan 04, 2009 | Canon Office Equipment & Supplies
Minolta Di200f copier
The error code has to do with the toner bottle/hopper. You just adde toner Right? Take the new toner bottle out and make sure not to spill any. Then close the doors of the copier and turn the main power switch OFF then back On. Let the copier warm up to Ready toCopy. Then reinstall the toner bottle and that should do it for you. The toner was out of HP when the toner was replaced. ... Good Luck
Oct 08, 2008 | Konica Minolta DiALTA Di200 Copier
90 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
