Question about Akai PT5492S 54" Rear Projection Television
Akai PT5492 I have an 54 in rear projection t.v. There is a small buzzing sound in the speakers and i tried different speakers with the same end result. Is here something else I can change.
    Champion:
  • 230 Answers
I can help you. Call me  910-8936663
Posted on Oct 27, 2007
My rear speakers are suddenly doing this buzzing sound. I tried different speakers and different cords, and it seems to have come down to the speaker outlets. What could be the problem ?
External speakers ? try them on something else.? Internal speakers ? sounds like an issue with either the software...OR a dry joint on the board?? What leads are being used? check everything you can in order to eliminate the problem.
Jun 29, 2016 | Audio Players & Recorders
No Sound
check the speakers!!! or maybe you have defective parts like fusibul resistors! or open capacitors...
Sep 29, 2007 | Akai PTH5498 54" Rear Projection...
AKAI model PTH5498 turned it on in morning and it worked fine, then went to kitchen then heard a pop then a buzzing noise tv had no picture
Short on the power and deflection boards---with set unplugged take a careful look inside for burnt or blackened parts etc.
May 17, 2012 | Akai PTH5498 54" Rear Projection...
I purchased an akai its and older model i assume it has the big back on it but a flat screen about a 50inch tv when you hit the power button it cuts on the cuts right back it makes amlost like buzz sound...
Sorry this problems u describing it is not good.The tv having a buzzing sound mean the tv FBT-flyback tranformer is dead and it is not giving the tv anymore high voltages to the tv screen.Also the deflection circuitries board have some dead components too.Sorry can't give u a price,because this tv have to get an estamate prices by a tvs tech. and trouble shoot major sections of the tv circuitries and replacing parts.It vary from shops to shops.Must call many tvs shops get an estamate and compair prices.
Mar 01, 2011 | Akai PT5598HD 55" Rear Projection...
My TV is buzzing nonstop. What will fix this??
is it buzzing when turned off or just on and is it buzzing durning bright scenes or just buzzing bright scene change buz is an If problem . in todays set , the best thing to do is change out the signal board sometimes
it could be a transfomer laminate buzz in the case your best bet would be to hire a tv tech to take a listen
Nov 20, 2009 | Akai PTH5498 54" Rear Projection...
The picture out of line, and makes a buzzing noise.
Ur convergencce it dead,know how to solder?,buy a convergence ics and resiestor,must be replace it dead.Tries Tv repair World.com or Ebay.com.
Jul 02, 2009 | Akai PT5598HD 55" Rear Projection...
AKAI PT5492S
make sure it's not muted. you can also change from lift to right speakers. you may have burned up the audio driver amp.
Apr 22, 2008 | Akai PT5492S 54" Rear Projection...
Akai pt5492
This could be one of many different issues. Main flaw with these units are as follows:
Blue picture tube leaks coolant onto neck board and mainboard causing problems.
Dec 17, 2007 | Akai PT5492S 54" Rear Projection...
Akai PT5598HD 55 in. Rear Projection
Something like this Id have someone who knows there way around electronics, a qualified tech or someone you trust really well :-) Does the crackling affect the TV picture at all ? My first guess would be dust and or dampness on the audio components. Sometimes this can conduct electricity across small pc chips and reak all sorts of havoc. I had an old Tomas electric organ once, and it actually caught fire because two speaker wires were rubbing together and eventually wore thru the insulation and shorted out, but it was also making alot of crackling and static noises. Try raising and lowering the volume low to high and high to low and see if the crackling noises gets worse. Some audio amplifiers put out quite a bit of power, so I wouldnt trust leaving the TV on without a fire extinguisher handy.
Nov 06, 2007 | Akai PT5598HD 55" Rear Projection...
Akai PT5492S 54" Rear Projection Television Logo
349 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
