Question about Riso RZ220 Duplicator
Drum stuck RISO RN2235ui
I changed the master drum to another color that has not been used in some time. The RISO made this horrible noise and threw an system error T01-521. I reset and turned off and back on several times. I have attempted to change the master drum but it will not reslease from chamber. Any way to release it?
  • RAUL VILLANOSA Jan 02, 2013
    you can also align your drum at 12:00 position by way of unscrewing the gear lock at the end of the drum so that you can freely rotate the drum at its normal position, you can also check the sensor of the drum if its is working
    Problem Solver:
  • 19 Answers
assuming you have a RN machine
you should of removed the master on the drum by hand if it was not used for more than a couple of weeks, and wipe dry under the clamp.
To get the drum out, hinge up the top of the machine over the top of the drum there is another small door, it hinges up like the top of the machine.
At this point ensure that the drum is in the home position i.e the clamp of the drum is at 12:00 (on top). if not turn drum to that point by hand.
Then try the button again to release the drum. If that fails there is a small **** under the drum at the front door area. there is a catch there that holds in the drum which you can move to the side with a flat screw driver.
Posted on May 19, 2009
    Problem Solver:
  • 20 Answers
The drum is not on its normal position when you insert the drum unit, try to insert a flat screw driver under the drum unit. There is a rectangular slot under the drum unit on the front of the machine, gently insert the screw to unlock the drum manually. Refer to the manual for gear alignment if ever there is a misalignment of gears.
Posted on Jan 15, 2013
How to fix Riso CZ100 error code h 101
1. Double click on ur start key to go zero on display panel. Machine will Ready to printgood luck
2. You need to input the value on the machine for the ink color the value is 1-black or 2-color
you need to go into service mode the go to 890 and input what color of ink the drum is weather its black or color and that should get rid of your issue
3. The machine either has "knock off" ink (generic) or "knock off" masters (generic) installed in the machine.
Try installing Genuine Riso ink and masters and the problem should be solved.
Apr 05, 2017 | Office Equipment & Supplies
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
Riso rp3700 drum is stuck
Assuming that it is still in the locked position. Open the top and observe the position of the drum. Rotate the drum the normally locked position. i.e. The master clamp on the drum is in about the 2 O'clock position. Put in test mode, enter 556 and push start. That may release the drum.
PrntNow.com
Mar 17, 2013 | Riso RP 3700
The riso is indicating that there is a jam in the drum area. I am getting a message A-01 -211
Error type A01: Master feed error Error point 211: Master-positioning sensor in ON during standby.
Dec 21, 2010 | Riso RZ220 Duplicator
Risograph RA4050 diplaying error code E11, anyone know what that means? Has recently been putting masters on the drum crooked and making grinding noise.
E11 is the pressure control motor encoder has nothing to do with the master problem it is most likely out of time. (grinding noise)
May 03, 2010 | Riso RZ220 Duplicator
RISO 1610. Start light is blinking. Drum release
Friend,this code refers to switches cover:
can cover the trash (disposal box) that has two switches, magazine master.Tente verify that the drum is in position for opening.
Apr 09, 2010 | Riso Office Equipment & Supplies
I have a problem error fo115 of riso rz-220
F01-115 means no master on drum at start of printing. Make sure you make a master before trying to print.
Jan 20, 2010 | Riso RZ220 Duplicator
I need to know what buttons to hold down on a riso 390U in order to get a different color ink to print in a drum
That's almost correct. Risos have two kinds of drums: black and color. The black drums have to stay black. If you want to print color you need to a) buy the appropriate color drum or, b) change the color in a color drum you already have. If you change from, say, blue to red, you're going to have purple for a little while. It's not a really efficient way to get things done.
Oct 05, 2009 | Riso RZ390 Duplicator
MY RISO CR1630 GIVES AN ERROR CODE 15 WITH TOOL FLICKER - IT LOOKS LIKE AN INK PROBLEM CAN YOU HELP PLEASE?
It is master position sencor,take out your master roll,pull out your drum. Take a a4 paper and push it threw there were your master go in,roll the 3 rollers in front so that the paper go forward so you can see the paper inside machine and pull the paper out to the inside of the machine. Put every thing back,turn off machine and while you hold the reset button in,turn machine on again. let me know if it worked.
Aug 13, 2009 | Riso Office Equipment & Supplies
779 people viewed this question
Top Riso Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marius Chiriac
paulfvincent
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
