Question about Emerson EWF2004 20" TV
Black box on screen
There is a black box that shows up on the screen within 5 minutes of turning on. At first I thought it was the cable box but once that is turned off the black box is still there. There is still a picture behind this box and the sound is fine. It is about 8 inches wide and 6 inches tall on the bottom and is completely black no writing or anything. Has anyone had this problem before? How do I get rid of it? I have only had this television for a little over a year and really don't feel like replacing it. THANK YOU for any solutions you might have for me.
  • kb1999 Nov 03, 2007
    I've got exactly the same prolem. It occurs when I watch a DVD. No box appears when I watch cable TV
  • bob sutton Dec 16, 2007
    I have the same issue but it is not the closed caption. i don't know what it is.
  • 39 Answers
CTPATS-THATBOX IS MOST LIKELY DUE TO THE TV HAVING THE CLOSED CAPTION TEXT FUNCTION ON,SIMPLY GO INTO YOUR MENU AND TURN THE CLOSED CAPTIONS OFF. JOE TV
Posted on Nov 19, 2007
I did what Joe TV suggested and it worked. The CC text function was on.
Posted on Apr 06, 2009
SOURCE:
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
The monitor screen goes dark about 10 minutes
Please verify the power option setting present in 'control pannel' option once. If you have selected to turn off the power supply after 10mins, (once the system is in idle state) then the SMPS will stop supplying power.
thanks.
Jul 20, 2009 | BenQ FP71G 17" LCD Monitor
Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Jan 08, 2009 | Toshiba 32A33 32" TV
RCA MM6110 The TV is on but I am not getting a picture.
Have you tried resetting the cable box by unplugging it for 5 sec. and plugging it back in? (power cable)
Aug 27, 2008 | RCA MM61110 61" Rear Projection Television
HITACHI 53" REAR PROJECTION
Good Day;
Some cable techs are good but too many are not.l So, if you have not solved this by now try this:
Unplug TV & box, wait 5 minutes plug both back in (reboot).
Good Luck.
May 30, 2008 | Hitachi 53UWX10B 53" Rear Projection...
My xbox 360 is showing green
no red lights, no previous error msgs, and video output on the box has just died. playing halo yesterday and mid-game the colours went askew (like a green overlay) with horizontal banding, backing out to the dash solved nothing so after a reboot there was simply no video. troubleshooted the tv and cables and its definately the box.
http://forums.xbox-scene.com/index.php?showtopic=625804
Nov 11, 2007 | Microsoft Xbox 360 Console
Large Black Box Showing up in middle of screen.
When a black box appears on the screen it means that your closed captions are on and set to TEXT. When the closed captions are set to CC1, it puts the words on the screen and when set to TEXT it puts a black box in the center of the screen. Go into the set's menu, navigate to the closed captions page and set the captions to OFF.
Aug 18, 2007 | Hitachi 50UX57B 50" Rear Projection...
Black Shapes Encountered on TV Screen
your problem is in the horizontal sweep and its called blanking. it happens on mostly zeniths sets as Ive seen it a few times and the only waty to fix it is to replace the entire chassis as there are no parts for zenith available just the module as a complete assy. Basicly, The blanking is suppose to only blank the top and the bottom of the fields of the screen that you don't see but it misfires and causes all sorts of lines, squares, and boxes on the screen. When i first was told of this problem i thought the same exact thing?? About the closed caption but the set came into the shop and didnt do the problem. I thought the customer was seeing things. Then finally on night late I CAME BACK TO THE SHOP TURNED ON THE BENCH AND THERE IT WAS!!! i SAW IT WITH MY OWN EYES!! I replace the Module and all was good. Thge repair was about 175 bucks. Good Luck in your repair. Oh this should not be attemted by a handi person, as there is dangerous high voltage inside these sets.
Jun 14, 2006 | Zenith B27A76R 27" TV
Emerson EWF2004 20" TV Logo
1,631 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
