Question about Boating
I recently purchased a ''refurbished'' Minn Kota Turbo 65 (36 lbs. of thrust) from an acquaintance. I saw that it does indeed work, but would feel better if I had an owners manual to purview before actually going out on the water with it. Does such a thing exist or is it available somewhere?
    Problem Solver:
  • 14 Answers
I would bet that if you were to go to the minn kota website,you could download the owners manual or request one through the mail....
Posted on May 15, 2009
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    What's the thrust of minn kota mag 28
    12 volt its 28lbs thrust
    Mar 08, 2013 | Boating
    Have a minn kota riptide sf 101 thrust 62" shaft.
    There is more than the shaft, there is the housing and then everything needs to fit and have correct clearances.....I suggest sell the old one and get a 52 inch new one...
    Mar 01, 2011 | Minn Kota Riptide SF 101 Saltwater...
    My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
    Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
    Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Minn Kota Trolling Motor will not run
    Hi!
    For starters, here is a schematic:
    Endura 30
    Check to see if there is appropriate voltage getting to the switch (with an ohm meter).
    You can (please do this carefully) disconnect the battery positive and negative as well as the motor red and motor black wires and connect the Batt positive to the motor red and the Batt negative to the motor black. If the motor runs, the switch is faulty. If it doesn't then I suspect the motor needs looking at.
    Best of luck!
    Mike
    Feb 06, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota electric motor MKJI1033962
    Best to call Minn Kota direct for the manual Youll need your serial number thrust of motor and shaft length..
    800-227-6433 they will help you with any technical questions.
    Parts can be purchased from this dealer...There are schematics on the site for review....
    http://www.northlandmarine.com/MinnKotaQuickRef.htm
    =100){IAjax.Pop('/WorkArea/showcontent.aspx?id='+id);}else{__LoadTaxonomy(IAjax.getArguements(),'pagerequest=showcontent&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__ecmdiv='+tag);}}function OnDirectoryItemBubble(id,width,event){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=bubble&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&bubblewidth='+width+'&X='+EBubble.EventX(event)+'&Y='+EBubble.EventY(event));} function DmsMenuInit(){ dmsDynamicContentBox = false; dmsCommunityDocuments = false; }function OnAddCategory(name, selectedTreeId, parentId, action, id, type, share){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=addworkspacecategory&__categoryname='+name+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__selectedTreeId='+selectedTreeId+'&__folderId='+parentId+'&__action='+action+'&__taxonomyId='+id+'&type='+type+'&share='+share);}ektj$(document).ready(function(){DmsMenuInit();}); // --> .EkTB_overlayMacFFBGHack {background: url(/WorkArea/images/application/macFFBgHack.png) repeat;}
    Aug 10, 2008 | Minn Kota 40 Edge Bow Mount With Hand...
    Boating Logo
    949 people viewed this question
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
