Fan stops mid cycle but compressor continues to run on my lg split system. The unit then stops cooling. If you let it set for a few minutes it will reset and run for approx 5 minutes.
    Guru:
  • 588 Answers
Check the fan capacitor, and with the power off to the unit, spin the fan blade to see if it spins freely, if it doesn't then the bearings in the motor are bad,it if does then it's probably the capacitor or if you have a fan switch in the system, then check the switch.
Posted on May 15, 2009
Hi I have an Omni AOS - 09HR4F split system air cond and when I set it to the cooling mode the unit outside starts the fan motor running but the air coming out of the head unit inside doesnt get cold?
Could be a lot of reason why compressor is doing that .First make sure your outside unit is clean ,if not wash coil with water .If coil is clean check capicator and replaced if bad .if capicator is good then you might have a bad compressor or a leak in your system and compressor is shutting off on low pressure .
To figure this out you need to install your refrigerant guages to check
Mar 05, 2018 | Heating & Cooling
Indoor unit fan blows, then stops etc. every 1-2 minutes
At least it is cooling properly. U might just want to call Mitsubishi and ask them if it is operating normally based on your observations.
Apr 30, 2017 | Mitsubishi 18000 Btu Mr.slim Ductless Mini...
No heat but fan keeps running
If the air conditioner compressor runs all the time the main control board might be defective. The main control board provides the voltage to the fan motor and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Nov 25, 2013 | LG LAN186HV / LAU186HV 18,000 BTU 15 SEER...
Temp Control Problems
Hi, hild, first thing; stop the AC by remote controler, than select the fan option pressing by mode button and next start the AC, wait 8 minutes, if the unit still blows cold air, the thermistor has to be replaced. I hope this was helpful to you! success!
Jun 12, 2013 | LG Art Cool LA181CNW Split System Air...
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
My ac unit outside runs when the tempeture gets above what it is set on, but the fan blower keeps going on and off. I switched the theromstat fan to on from auto and it does the same thing, on and off in...
the fan control is not for the fan on the top of your outdoor unit. that is for the blower, you have 2 fans. Im guessing you have a split system, 1 unit inside and 1 outside?? Does the outdoor fan continually run??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Feb 06, 2018 | Ingram GMS90904CXA Heater
Hi I have a goodman MSG-18HWN1 heating and cooling mini-split unit. The unit keeps going on and off on a cycle of about 5 minutes. 5 minute, unit not started, unit starts for about 5 minutes, stops for...
Due to abnormal temp of out door.Check outdoor fan motor and compressor and also sensor.
Fan motor not working- rectify/replace fan capacitor.
Sensor defective-Replace it
Compressor high amps-Replace running capacitor.
Sensor misplaced or defective-Place correctly or replace it.
Jan 05, 2011 | Heating & Cooling
LG 8008R compressor runs one minute then fan blows 3 minutes
You need to have an AC tech come out and do some preliminary testing on this.
May 12, 2017 | LG Heat cool Window Air Conditioner
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
