Question about Carrier Heating & Cooling
Carrier Infiniti system, system maufunction on primary display
I purchased my home 1.5 years ago and this elite system was installed. It has worked fine until recently. I'm gettin " system Malfunction on my primary display unit in the MB. If I go to the attic and reset power( unplug unit) display clears and unit cools again. I found some unmbers on the outside unit( heat pump) 24ana748a300, but I have not found the model number on the attic unit. I have reset the unit 4 times in the last 7 days. It has been inconsistant on reset time..early morinig and very last at night( when its not very hot) and aslo in the middle of the day. I did read something about the Primary control unit( big Motherboard on the wall) sometimes gets confused talking to the attic unit and it needs to be reset. Your help would be very much appreciated..
Thanks
Perry
  • pstringfello May 15, 2009
    Thank you for the advise. I was hoping for a few things to try or symptoms to look for that could be causing the problem. About a year ago the unit did the same thing,I called a tech to the house he came out, looked at the unit for about 2 hrs and said he couldnt find anything and charged 75$. The Motherboard that has the 2 leds that indicate the code or problem are fine, no flashing at all.
    Thank you,
  • 38 Answers
Call a Carrier service comapny and have them investigate further, when system malfunction comes up on the user interface usually there is a substantial problem.
Either that or the User Interface has gone bad and needs to be replaced
Posted on May 14, 2009
My motorola elite charging dock when it's charging the light on the charging dock blinks green and yellow it will not charge the earpiece unless I'm holding it down
Will:
Sorry you are having an issue. How long ago did you purchase the headset? If within 1 year and you have proof of purchase, please CONTACT US for options.
Mark
Motorola Support
May 26, 2015 | Motorola Mobility ELITE SLIVER Bluetooth...
F1 CODE ONSEARS ELITE OASIS WASHER MODEL #110.27032603 SER.#CU0670188
F then 1 flashes when there is a primary control failure. Replace the machine control assembly. The part number for the control board is W1018966
it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apwagner.com
appliancepartspros.com
apdepot.com
Gene
Aug 15, 2011 | Kenmore Oasis HE 27082 Top Load Washer
I have a compaq presario pc. Motherboard is Asus P5LP-LE : Lithium UL8E. I have 3 Gig of RAM installed, a 400w PSU. I have just purchased a new graphics card - Radeon HD5570. My MoBo has 1 PCI-E x16 and 3...
I think you have not connected power connector to your Radeon HD5570 .
This graphics card have 6pin power connector .
You need a 6pin power connector cable that comes with the graphics card box.
1.First connect your 6pin power connector to Graphics card.
2. Then connect other part of the cable to PSU.
Hope it will work for you.
Thanks for using FixYa.
May 14, 2011 | Computers & Internet
HI, I purchased my Surado Home Manager 3.0 a few years ago, I had successfully installed it once some years ago on my old system and it worked, but now when I install it and attempt to register my product...
IF YOU ARE TRYING TO INSTALL IT ON A WINDOWS 7 OR A VISTA YOU WILL NEED TO PURCHASE THE UPDATED SOFTWARE. IF YOUR TRYING TO REGISTER IT IN ON AN XP, THEN YOU NEED TO CALL SURADO AND HAVE THEM RE-REGISTER IT FOR YOU.
Dec 19, 2010 | Computers & Internet
Fujitsu scanner light bar will not return to
When you face such errors, please check if the Scanner panel displays-"E-0" and TWAIN displays- “The running system is abnormal. Please confirm the carrier lock has come off.”
The error is Carrier unit drive alarm. After power-on, carrier unit (FB) moves to home position, that is where the carrier unit locates when home position sensor is turned ON. If the home position sensor is not turned ON after the carrier unit has moved pre-defined steps, this error occurs.
Probable causes:
Defective sensor, motor, or carrier belt.
Also, please check the following:
1. Is there is any abnormal noise from FB motor when this error occurs?
2. Does any foreign object get inside drive unit or carrier unit?
3. Is CR belt tension loose? Loose belt should be tightened.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Mar 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
UV100E Ultraiolet system. Noticedbulb not coming
Honeywell has a great team of technical support personell, just call the number on your owners manual.
Jan 14, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
Drops signal as soon as location changes
You may have a dead zone in lake area !! I experianced alot of signal lose on a lake in oklahoma last year !!! swampratt200 !! AAEEE!!!
Jul 21, 2009 | Sanyo CRSR-10 SIRIUS Radio Receiver with...
Screen Blinks and comes back
hello,
this problem accure due to faliour of invertor circuit. plz call a hardware engineer or replace the monitor. your monitor is in warrenty so i suggest you to replace it with new one.
ok
bye
ramesh722
Nov 13, 2008 | Acer X193W LCD Monitor
Rear Sonar System
my rear sonar system on my qx56 does not work. the switch under the steering is constantly off. what my be the problem.
Oct 29, 2008 | 2004 Infiniti QX56
Kenmore Elite Trio model 795.7757
Hello fergust
Welcome to Fixya,
You said, I have just purchased this unit and switch it on.After some 3 minutes error message appeared on the front door screen . Message ---- ER CF Neither fridge,freezer or ice maker are working. What is the problem.
Did you turn the refrigerator and freezer on to the proper cooling adjustments as in the user manual?
Is the ice maker hooked up to the water line and in the on position?
Did you use the free help line if you are doing it your elf?
While I look it up, you can try to reset the system by plugging the fridge for 5 minutes, or if you can not reach the plug, then throw the breaker for 5 minutes.
Not less than 3 minutes. That is why I sad, 5minutes.
Usually this will do it! let me know as I look up the error codes.
Please remember to leave a rating!!!!!
Call this number for all Kenmore questions 1-800-4-MY-HOME
One Year Limited Warranty
When installed, operated and maintained according to all instructions supplied with the product, if this appliance fails
due to a defect in material or workmanship within one year from the date of purchase, call 1-800-4-MY-HOME to arrange for free repair.
Let me know how it goes!
Bless You.
Huuum
Sep 08, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Heating & Cooling Logo
493 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
