Question about Reebok RL1500 Elliptical
Convert rpm or revolutions to miles or read odometer correctly
I want to be able to see distance in miles from the display information on my Reebok Elliptical trainer. Can I do this from RPM, Revolution, or I think from the odometer but I cannot understand how to use it for distance information.
How to convert 1440rpm to revolution
Posted on Mar 05, 2010
2003. 2wheel dr 150 p.u. I. Put smaller tire on because back problems getting in .now at 60 mph dash odometer reads 69 mph . Is there something I can do . So odometer would be correct.
there are different speedo gears in the transmission available that will allow for some ratio changes in the diff so check with a dealer spares to see if any are available for your vehicle
when you say smaller tire , is it a smaller diameter rim that was fitted
if that is the case by fitting a larger tire case may get back closer to the correct reading
by that I mean for example a 195 25 r14 case can be replaced by a 195 95 r14 case as the difference is in the 25 to 95 measurement
the 25 measurement makes for the rim almost touching the ground where the 95 dimension stands the rim well up off the road and because of that the distance covered in 1 revolution is far different to the distance covered in 1 revolution by the 25 size tire
that solution may put the car back too high for your back problem so if the gears replacement is not possible , then a last solution may be to find an instrument repair shop and have the gauge re- calibrated to the correct reading according to the speedo gears in the transmission
if it is auto with a VSS unit that signals the speedo there may be changes in that area that are possible
Jul 31, 2016 | 2003 Ford F-150
My trip odometer show double the distance traveled.
Check your miles by markers on the road. If the trip is double, it is a chip failure. I wouldn't worry about it until the odometer fails. It can be reset.
Aug 14, 2015 | 2005 Nissan Xterra
Convert kilometers to miles
If your question is how to display the distance information in miles, instead of kilometers ... it is a setting option you can change.
Touch the center area of the driving screen to view the menu ...
Tap on Change Preferences ... and move to the screen (near the end) to Change Setting
Tap on Set Units ... and get to and select Miles
Then finish/exit ... and all your distance units will be displayed in Miles
Mar 11, 2014 | Tomtom Go 630 GPS Receiver
Change kpm to rpm
The odometer will read in KPH because it is a measurement of distance which is what the odometer measures.! RPM is revs per minute and therefore will not be on an odometer, but on the rev guage.
Jul 27, 2013 | Motorcycles
Kpm to rpm
The odometer will read in KPH because it is a measutrement of distance which is what the odometer measures.! RPM is revs per minute and therefore will not be on an odometer, but on a rev guage.
I have a reebok edge series 2.2 treadmill, i bought it in argos in ireland but im pretty sure it's been shipped from england, does anyone know if the distance ran on the computer is in miles or kms?
I had this very same problem. I sorted it out this way: the information that Argos supplies says the speed starts at 0.8 kph with a top speed of 14 kph. If your Reebok Edge starts at a speed of 0.5 and has a top speed of 8.8, then the speed and distance is measured in mph, rather than kph. You can check this yourself with the following online speed converter:
http://www.eforecourt.com/mph_kph_speed_convert.htm
Feb 03, 2011 | Reebok Acd1 Treadmill Motor Control Board ...
96 toyota camry changed from miles to kilometers on the odometer
yes there is a button you push it in and it changes from kilometers to odometer, should be in front of closter on the right side, right side of steering wheel.
Oct 30, 2009 | 1996 Toyota Camry
2003 Saturn L300 odometer reads 694,278 miles and
change the whole instrument cluster with one from a wreck.
Jun 10, 2009 | 2001 Saturn L-Series
Distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
May 05, 2009 | Reebok Exercise & Fitness
Reebok RL1500 Elliptical Logo
1,482 people viewed this question
Top Reebok Sport & Outdoor - Others Experts
Tony
michael
michael
Are you a Reebok Sport and Outdoor - Other Expert? Answer questions, earn points and help others
