Question about Avid Juicy Ultimate Hydraulic Disc Brake , 160mm, Front
The rear wiper on my 1999 Subaru Outback Legacy wagon will not work correctly. When i hit the button it makes a really loud motor sound, but no movement. We took off the back panel, and noticed that it would move back to the original position if moved to the far side, but would not go the primary direction. To sum up the wiper motor appears to only go one direction, not both, like it needs to. What do I do?
    Habit-Forming:
    Scholar:
  • 152 Answers
IT LOOKS LIKE THE GEAR IS STRIP INSIDE YOU MAY HAVE TO BUY ONE, CHECK AUTO ZONE OR ORILEYS OR A JUNK -
YARD AND REPLACE IT.
D,R,CLAUDIO
Posted on Jan 21, 2018
Is there an access pannel under the rear seat of 1999 subaru legacy outback to access the top side fuel tank?
Yes, under the rear seat bottom on a sedan or behind the rear seat back on the panel under the carpet on the cargo area, right behind the seat back, screws hold the panel on, fuel pump right below it, easy to replace...I just did mine,1998 Legacy Wagon.
Jul 14, 2014 | 1997 Subaru Legacy
Why won't my 2010 subaru outback wagon interior lights go off unless it's locked
Check your Interior Light Switch what position is it?
The Striker may have lost a Wire. Test EACH DOOR
Apr 09, 2013 | 1999 Subaru Legacy
99 Subaru legacy wagon 2.5 DOHC. Started making sound like the bearing in a pully went out, pulled over to check it out and car shut down. Now it will turn over but it will not start.
i do not know about subaru 1999 but i can guess that your timing belt is broken and if you push it hard the valves could even bent and increase the fixing cost. i suggest you seek help from a car mechanic
your mileage must have exceeded 100000km check the record if you had ever changed the timing belt.
i pray that it is something else with least expensive.
Aug 30, 2012 | Subaru 1999 Legacy Outback
2001 Subaru outback driver side windshield wiper goes to far to the outside tears up the end of the blade - ideas please
I have the same problem with a 2001 Legacy wagon. The problem is not as simple as the solutions above. Mine are adjusted to park as low as possible when off. Even so, the blade on the drivers side goes all the way off the windshield. The Subaru dealer wants to replace the whole wiper blade transmission for about $450. Looking online it seems to be interconnecting arms and pivot points that connect the motor to the wiper blade arms.
Nov 17, 2011 | 2001 Subaru Outback
MPH hour gauge not working. 99 subaru legacy outback
the speedometer/odometer problem sounds like the vehicle speed sensor, which is ususally found on your front wheels, the stalling out sounds like an unrelated problem, but i couldnt tell you where to start for that one
May 03, 2010 | 1999 Subaru Legacy
For a 1999 Subaru Legacy does it have just the screw on transmission filter or is there also one in the pan?
I have a 99 Subaru Legacy Outback wagon also. I just changed my fluid & filters. There is a spin-on AND a bolt-in that's inside (you have to drop the pan).
Apr 03, 2010 | 1999 Subaru Legacy
2003 subaru outback wagon. 3ltr engine. wipers stall on windshield.they lack power and will resart again for a few strokes with a push. not sticky windshield. wiper motor?
if you can get to it try to lube the drive mechanism with a little wd-40.. if does not work have the wiper motor replaced..good luck..
Nov 15, 2009 | 2003 Subaru Outback
My 1999 subaru parking lights will not turn off
the rocker switch on top of your steering column is on.
Aug 26, 2009 | 1999 Subaru Legacy
My car is a 1999 Subaru Outback Station wagon. We
two things you must address, first the tires may need rotating, 4WD cars need all tires to be close to the same size or conflicts in gearing occur, second change the oil in the rear axle this can cause noisy operation.
Jul 02, 2009 | Subaru Outback Cars & Trucks
Subaru Outback - '03 boxer 2.5L engine sounds like a diesel
heavier oil if you are not in a cold climate. but before you do that have the oil pressure checked. We used to use a can of STP every once in a while on a motor in a dodge we had... nothing wrong with it... was just noisy.
Robert
Feb 05, 2009 | 2003 Subaru Outback
Avid Juicy Ultimate Hydraulic Disc Brake , 160mm, Front Logo
215 people viewed this question
Top Avid Cycling Experts
Michial Gueffroy
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you an Avid Cycling Expert? Answer questions, earn points and help others
