Question about HP LaserJet 5500DN Printer
Printer will not take settings
Our printer will not automatic feed anymore and will not print in color. It is asking to load high gloss paper prior to every print job. I have gone through and tried to manually change the settings back to the factory resets and it will not keep the changes. Is there something else required to set the printer back to the factory settings or is there something I need to do to change a setting?
    Sergeant:
    Champion:
  • 240 Answers
Try to unplug the printer while it is in on state ..it will reset everything..
Posted on May 14, 2009
Correct settings for printing on semi-gloss paper. I keep getting smears when printing and photo doesn't come out clearly
Well, it would be good to know why the photos are not good quality... like blurry or bad color or? Are you using a good paper? I have great luck with Canon glossy, and love the matte paper from Staples. Matte is actually easier and all around better color saturation, I find. I guess that you are using too much saturation of ink... see if your dialog box for printer options has a way to make saturation less intense. Also, I assume you are using the same dialog box to choose the type of paper. That is important, since different papers absorb ink at different speeds and amounts. I hope that helps... keep trying!
Nov 02, 2014 | Epson WorkForce WF-7520 Wide Format...
Paper Jams if I use a high gloss Laser printer paper. Looks like an accordian before the fuser.
Good day Sir, If you are using high gloss laser printer paper I suggest load up to 25 sheets.
  • make sure the glossy or the printable side of paper faces you.
  • the paper is loaded against the right side of the paper support.
  • the paper guide rests against the left edge of the paper.
Note: photos require more drying time. Remove each photo as its exits, and allow it to dry to avoid smudging.
have a nice day, hope this will help you.
Jul 30, 2010 | Lexmark X500n Color Laser All-in-One...
Photo Paper keeps jamming
It's the top rollers, the paper is too slick to get through them. I'm using HP photo paper, in an HP printer. It needs to do a 180, but gets jammed right where it prints, so the paper never makes it to the ink. It's an engineering problem by HP. I suggest putting a rough surface on the top edge of the photo paper, something removable but rough enough for the printer to pull the photo paper through.
Jul 12, 2010 | HP Officejet 6310 All-In-One InkJet...
How do I print double-sided automatically? HP Color LaserJet 2605
Go into the control panel, select the printer, select printing preferences, select finishing, put a checkmark in box where it says "print both sides"
Oct 09, 2009 | HP LaserJet 2605DTN Color Printer
Gloss or semi gloss paper stuck in fuser
You need to change your setting for media type, and media weight( you can use auto for this setting) but for media type you have several options. Bond, glossy, plain, etc. This setting adjust temperature for the fuser. You can do this at the front panel in menus.
Jul 20, 2009 | Xante Ilumina Digital Color Press Printer
Trying to print but it ask me to load paper or form feed. also got a bypass tray message.
Sound like the computer printer preferences "paper source" is set to bypass if set to "auto select" select the tray you want. Also make sure type of paper matches what is in printer.
-Carl
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
3010 dell color laser
Ok,
I've went around and around with the same problem (bug) and finally found a solution. Here is the deal. You have to exactly match the settings for the MPF tray in the aplication softwares to the MPF tray settings set from front panel on the printer.
I found this problem when trying to print on gloss paper. The MPF tray had to be set for "Coated 1 Side 2" in both the application and on the front of the printer.
Lets say I'm printing a Word Document. Go to file, print, select the Dell printer, then select properties, select paper tray, set paper source to MPF, set MPF settings to ""Coated 1 Side 2". Click OK.
Now do the printer setup. From the front panel on the printer.
Press Menu, press the down button to Tray Settings
Press center button to select.
Display now asks for paper type. Press center button.
Displays MPF. Press center button.
Push down button until you see Coat1 Side2
Push center button to select.
Press Menu to exit.
I only print on gloss so I have to set the MPF tray to Coated 1 Side 2. I was told this slows the feed and that is needed for coated papers. Now you could probably use another setting as long you set both the MPF tray in both the application and the control panel to match exactly.
Aug 19, 2008 | Dell 3000cn Color Laser Printer
2600N: glossy paper
Is this HP glossy paper? I would think that laser printers have a hard enough time handling any glossy paper as it is because you run the risk of the gloss burning as the paper goes through the printer so you might have to use the paper recommended by HP.
Here are the specs of the accepted paper.
http://shopping.yahoo.com/p:HP%20Color%20LaserJet%202600n%20Laser%20Printer:1991823169:page=details
Good Luck!
Hope this helps!
Mar 07, 2008 | HP Color LaserJet 2600n Printer
Printing
I wonder if it is in fact a printer problem? have you tried different programs?
Aug 18, 2006 | Canon BubbleJet i9950 InkJet Photo Printer
67 people viewed this question
Seeker5211
Seeker5211
