Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker and water dispencer turning on by themselves.The problem only stops when I open the door .Water is now turned off. Model#ESS25XGMB Serial#GA246553
    Brigadier General:
  • 3,614 Answers
Fridge with automatic ice makers sometimes malfunction because the water inlet valve strainer that feeds water to the ice maker becomes clogged.
To correct this problem, unplug the appliance and disconnect the water supply. Remove the water line where it enters the valve--usually at the bottom edge of the unit. Locate the wire strainer and remove it. Clean the strainer with a stiff brush, using mild household detergent. Reassemble the component in reverse fashion.
Let me know for further clarification
Posted on May 14, 2009
GE ESS25XGMB Ice tray dispenser not turning.
In the future you can use a steamer to defrost that drain line takes 5 minutes. I don't think your bucket is sitting correctly check and make sure it has contact with the auger motor and is not sitting too high. If you hear the motor turning but the coil is not its not seated correctly. Also it will not move if the door is open.
Jul 25, 2013 | Refrigerators
Last night, I connected an active water line to the back of my Kenmore side by side. The ice maker is making ice but water water and ice is not coming out of the dispencer. There is another water jug...
You have a dual water inlet valve where your water supply connects. One goes to the ice maker and the other goes to the water dispenser by way of the water reservoir you mentioned in the fridge.
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing.You should hear the ice door open and the augur motor turning to turn the augur which pushes the ice out the door. If the augur doesn't turn Take all the ice out of the bin and try. perhaps the motor is too weak or the augur is locked up. Take the bin out and try to see if the motor will turn with no load. The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter when you try the dispenser. If you are, probably bad motor. If not ,dispenser switch or solenoid is not working.
Apr 20, 2011 | Kenmore Side by Side Refrigerator
My refrigertor has stop making ice.
just check if the lever in the ice maker is turned to on or off,because that causes the ice maker to stop making ice
Aug 15, 2009 | Refrigerators
Will not dispence ice, crushed or solid cubes, will dispence h2o
Hi
If the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
and if the ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Apr 09, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
Icemaker and water dispenser not working GE GSS25JFPA stopped working and i thought it was water filters (have not changed in 4 years changed the internal filter and a aux one in basement in line no...
generic troubleshooting video: http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
as the video shows a kinked line may be the culprit. or
if your ice maker is making ice and it is your ice dispencer that is not working along with your water dispencer and when you press the dispencer button the light dims on the door. I would replace the main board. I experienced the same problem and the board fixed it This board is shared by many models and brands of fridges and the transformer goes bad from power surges this board powers the solenoid valves that open for your water
Apr 03, 2008 | Refrigerators
GE 23.5 CU FT side by side w/ice maker and water in the door.
replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
18 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
