Question about Nikon Coolpix S210 Digital Camera
Lcd cracked lens won't open?
The lcd got cracked but i was still able to take pics. Now when I put the battery in the on/off light comes on, the screen lights up, but the lens doesn't move. What are the functions to go from playback to camera mode?
  • 502 Answers
There is a company in new york that carries parts for small digitial cameras : Camera Repair NYC
Posted on May 22, 2009
The camera was in playback mode, so i tired a few buttons. The button that changes the mode is the +/-.
Posted on May 15, 2009
After assembly camera lcd displey is still off
Perhaps in disassembly pressure on the LCD cracked the crystal display with will cause a rich black screen. If the camera has both internal and LCD displays, perhaps the switch is set to the eyepiece? My lumix will shut off the LCD and turn on the eyepiece to save battery. Check wires to that switch.
Nov 13, 2014 | Panasonic Lumix DMC-LX3 Digital Camera
Ex-s770 start to turn on then turns off
hi the problem is going to be with the lense motor jaming and not letting the lense come out all the way to switch the camera on to take pictures what should happen is the lense should come out all the way the go in just a little bit so that it focuses it does this so that it resets the lense for when the screen comes on.
If the camera has been put down with the lense out and any pressure has been put on it and put the lense out of line then this will cause the problem your having.
But the even bigger problem is their is no way of repairing it as most shops dont repair the smaller digital cameras so the chances of getting someone to look at it is a bit remote.
The only thing you could try is when the lense comes out try and pull it gently a bit further and see if that lines it back up as their a sensor on it so that when the lense comes out it switches the camera into the mode to take pictures but you can acess the pictures with the lense in so you know the batterys fine and that the circuit board is also fine.
It just the lense i know you cant get replacement parts for your make and model the only spares you can get is batt and cards so gently pull the lense if you can you cant damage it anymore than it is anyway can you.
Let me know how you get on ok.
Jan 29, 2008 | Casio EXILIM Card EX-S770 Digital Camera
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
Hi my tv fell off the wall last night about three feet to the carpet now it won't turn on the amber vizio light won't even come on when I plug it in. I took it apart and nothing appears to be...
After a fall like this (even on carpet) it probably has a cracked circuit board or a loose connector, first (since you took it apart any way) look for all connectors, than unplug them and re-plug them to make sure all plugs and boards are seated correctly, if you still don't have luck, than take out all the circuit boards and check them for cracks under a good lamp and magnifying lens, than repair the cracked traces with a good soldering gun by scratching off the varnish coating and applying solder. (if the crack is to wide you can solder a peace of coper wire to the trace on the board)
Have fun!
Jun 25, 2011 | Vizio L32 32 in. LCD HDTV
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open,...
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open, but no image is available just a black screen. When I I try to take pic is showed very low light but doen't show image of pic taken when I check. Please advise. This a brand new camera and was taken excellent pic as of this friday. Groove_us@yahoo.com Mr.Tracy Johnson
Apr 26, 2009 | Samsung i85 Digital Camera
Yukon spartan my pic is not clear light works but cannot get focu
Define 'clear'.
Is it blurry? Focus the scope or clean the lenses.
Is it distorted? Don't know how to fix. Especially if the lens is cracked/scratched etc.
Is it dark/snowy? Put fresh batteries in.
Do you see black spots in the tube? Don't worry, certain amount of these are quite acceptable.
Anyway: It's a night vision for pete's sake. The picture won't ever be like the one on normal binoculars.
Jan 17, 2009 | Yukon 24021 Monocular
Can't take pictures or video
Lens assembly is defective in your camera. If you know about camera, open it and inspect.
Jul 31, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Canon Rebel XTi LCD is white
Sounds like you need to contact the Canon warranty department.
Jan 02, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Red light in front :[[[
I had a similar situation with two of my C530's, one would only come on with the front red light (above the lens) flashing twice and then staying on solid red (regardless of the dial position). The other would turn on, but the LCD display would turn almost white and all pictures would be white.
Make sure you have good batteries, remove them from the camera, put them back in (make sure the dial is in OFF position before you insert the batteries) and with one finger put pressure on the top of the camera between the dial and viewfinder. Don't use excessive force, as not to crack the case, but put some pressure on it and as your squeezing it, turn the camera ON (Auto, Movie or View). This worked for both of my cameras, on one I have to do this one once in a while, the other I'll be taking apart to find out what's going on under the case.
Oct 26, 2007 | Kodak EasyShare C315 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
82 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
