Question about Sony Grand WEGA KDF55E2000 55" Projection HDTV
SOund Problem I can be watching a show for some time and then the Audio completely goes. I will switch to a different channel and the audio may or may not work. This has never happened with my high definition channel but is frequently happening with the other channels. I read the manual and all the setting seem to be set up correctly.
Doesn't sound like your TV... that sounds like your set-top box cutting in and out.
Posted on Jun 03, 2008
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Optical Audio output problem - What is the problem and what do I do to fix the audio output problem on my LG 55LH90 TV.
Do you have any other audio cables still plugged in that are not required,this could be the source of your echo.
Sep 07, 2014 | LG 55LH90 55 in. LCD HDTV
I have a constant ringing sound coming from the tv. It goes up and down as I increase or lower the volume by remote. As I change the audio option to "Spanish", regular "English" audio comes out on c
The fact it shows on tuner and not DVD means not likely a audio problem--check all audio settings in the set's menu AND if you are using a box for signal look there--has to be a setting.
Some JVC sets (brand indicated here) also had issues with when watching the background audio (like a sporting event) was louder than the people talking and could be interpreted as ringing--This is a setting in the set called something like "Theater" or "Hall"
Has to almost certainly be a setting in the set.
Mar 28, 2012 | JVC Televison & Video
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
Volume levels vary for no apparent reason. From normal to quiet and back at what seems to be random time intervals. No jiggling of any wires makes a difference. The speakers are old and I'm wondering if...
If you are using it to watch cable TV stations, They may have different audio levels between programming. Also you want to check and not use dolby when atching standard TV channels
Jan 19, 2011 | Audio Players & Recorders
Screen blacks out on certain channels randomly..doesn't happen all the time audio still works the picture just goes completely black for a bout a second then reappears.. very's new and it also...
Ur LCD inverter backlight board have problems,just not dead yet.When ur LCD inverter backlight board is dead.U will get only sound and no picture at all.
Feb 26, 2010 | LG 55LH90 55 in. LCD HDTV
I have a sony trintitron model kv20fs12 that i just bought used.A few of the channels have audio only during commercials. When the show comes on it has no sound. One channel has background noise such as...
Check your TV's audio settings and make sure it's not set for SAP (second audio program). You'll probably find it's turned on. On many channels or programs you won't notice anything since the broadcast doesn't include a SAP signal. But if the signal's there, the set switches to that sound channel and you have the trouble you describe.
The problem you might run into is that you often need the original remote to control the audio settings. I don't remember for sure if your Sony model has front-panel menu control. I believe that series does, though. (The remotes included with most TV sets usually have a single button to control SAP, which is often how the settings get changed in the first place. Someone hits the button and doesn't know it.)
Hope this takes of your mystery sound! Thanks for using Fixya.
Feb 14, 2010 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sound goes out for certain programs or commercials on different channels, but not all of them
Check your tv's audio settings. If there is an "SAP" button on your remote try hitting that. It stands for secondary audio program. Most manufacturers put it near the corners of the remote leaving it prone to getting hit without knowing. Most shows are broadcast with a spanish version of the audio. Hitting that button should allow you to hear it, but some tv networks do not broadcast the SAP audio making it seem like there is no audio. It usually affects more than one channel, and commercials do not broadcast SAP either.
Jan 20, 2010 | JVC AV-56P575 56" Rear Projection...
Audio problem... channel with no sound
make sure your S.A.P feature is turned off. S.A.P. stands for separate audio program.
Apr 25, 2008 | Toshiba 56HM66 56" Projection HDTV
No sound on four channels while all other channels sound is fine.
You most likely have the SAP1.gif mode activated. Look for a button on your remote or an item in the on-screen menus of your television1.gif called MTS or SAP. You want to set this to "Main" "Normal" or "Stereo" (or even "Mono") mode to hear the regular television sound.
If it is in SAP (Secondary Audio Program) mode, as I believe yours is, you may hear no sound or a different audio program. Often this is a translation to another language, such as Spanish, and other times (notably with PBS stations) it is an unrelated audio (often music) feed. On some stations there may be no sound at all with the audio mode set to SAP.
Feb 14, 2008 | Sharp Aquos LC-13SH3U 13 in. EDTV-Ready...
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
46 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
