Question about Xerox Phaser 6100/BD Laser Printer
Xerox Phaser 6100 low toner
I never get a 'toner low' message I only change it when it no longer prints correctly, is there a way to see actually how much toner is left in the other colors so I know which one to replace? I feel like I am wasting toner by not know what exactly to replace.
Thanks
    Novelist:
  • 208 Answers
Sadly,
On the 6100 toner detection is very unraliable.
The best way you can determine if the ink is low, is to remove the cartridge and look at the roller for streaks.
Sorry, but thats pretty much the only way to determine it accuratly.
Those cartridges only make 3000 pages each and that based on a 5 percent coverage. If you are running a lot of graphics, the life will be less than 1000 pages.
Posted on Nov 29, 2007
  • Rick Kasper Nov 29, 2007
    Correction, the yeild of those standard color cartridges is 2000 pages.
    If you are running more than a few lines of color, the yeild is very low.
    Again they base yeilds on 5 % coverage.
    I have seen those empty at 300-500 pages.
  • 78 Answers
I was looking on http://office.support.xerox.com and I really hate there way of doing this. They advised that sometime below 30% you start to notice lines missing they advise (old School) to open the front panel remove the toner it solid across the front. if it is not to shake the toner to distribute the toner evenly again. They also advised that thier display panel doesn't always show when it is empty. I wish I could help more, but it sounds like they need to catch up alittle with thier printer warning.
Posted on Oct 15, 2007
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
When the red light blinks on the printer what does it indicate-model-xerox phaser printer 6110
The blinking toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner. See "Redistributing Toner" on page 5.2
from the manual online as pdf: http://download.support.xerox.com/pub/docs/6110/userdocs/any-os/en/Guide_XP.pdf
Apr 06, 2011 | Xerox Phaser 6110 Laser Printer
Xerox Phaser 6100 vs Windows 7
Try using the Vista driver, it may work and may not have all the functions that was available under Vista.
Jun 10, 2010 | Xerox Phaser 6100/BD Laser Printer
Mac OS 10.6 Snow Leopard: Printer Driver Update for Xerox Phaser 6110 does not work ! Xerox/Apple is providing a most complicated instruction to circumvent the problem that I am not able to...
    1) Change the “Xerox” Folder Permissions:
    • Navigate to Applications > Utilities and open a Terminal window.
      • Type the following command: sudo chown -R root:admin /Library/Printers/Xerox
    • You will be prompted to enter your password.
    2) Install Rosetta from the Snow Leopard DVD:
    • Insert the Snow Leopard Install DVD
      • Select Optional Package
      • Select “Rosetta only” from the list of optional packages
      • Click install and follow instructions to complete installation; there is no need to reboot
    3) Reset Printing System:
      • Navigate to: System Preferences> Print & Fax> Xerox Phaser [6100, 6110, 6110MFP]
      • Right click on the printer
      • Select Reset Printing System
    4) Install Printer (without removing the driver):
      • Select +: add the available Xerox printer
Mar 18, 2010 | Xerox Phaser 6110 Laser Printer
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
Need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Aug 08, 2009 | Xerox Phaser 3100MFP/S Laser Printer
After removing toner cartridges error display said replace various colour toners.
it is not according to your printer or your head of cartige is not clean or damage. try replace new one
May 09, 2009 | Xerox Phaser 6100/BD Laser Printer
Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Oct 22, 2007 | Xerox Phaser 6100/BD Laser Printer
Colour Printing
YES, Possible faulty / contaminated Transfer system, I would get this serviced, as this is a more complex fix
Aug 22, 2007 | Xerox Phaser 6100/DN Laser Printer
Xerox Phaser 6100/BD Laser Printer Logo
144 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
