Question about RCA F25649 25" TV
RCA 27" TV Guide Plus
We unplugged our 27" RCA TV for a short time last evening and now the Guide Plus feature won't work. We went through the set up, turned the TV off overnight and everything it said to do on the screen - still nothing. Can you help?
  • 3 more comments
  • cha123 Apr 19, 2008
  • Anonymous Aug 01, 2008
    same problem. i waited over 48 hrs gone through my setup steps over an over. nothing seems to bring my guide plus data up. a g link cable was mentioned but i havent had once since ive owned the tv. i believe the guide worked a while back without it so i cant see that being the problem. pls help
  • KennShipley Dec 07, 2008
    I have a 27" RCA with the guide plus. Just before ThanksGiving the onscreen guide worked perfectly, After Thanksgiving it does not work at all. I have tried unpluging the set, going through the setup and leaving it off over night. I have tried entering 99999 for the zip and leaving it off over night. I have tried reseting the set unpluging it and still no joy. I believe the cable company has blocked signal (Charter Comm). I have called them and they say they have no information about it. Nobody at Charter knows anything about the Guide plus,,, which is very hard to believe. I also have a DVR which has the Guide plus and the same thing happened to it. I could belive one device failing..... but not two..... So either cable company the broadcaster that host the signal is at fault here.
  • rngoforth Jan 20, 2009
    I have a RCA and have gone thru all the set up instruction in the manual and cannot get the Guide Plus to show the programs. It worked fine until I had a power outage and now all it will show is no program information available. I called comcast and they said they were still sending the same cable information. Would a different VCR cause the problem with the Guide Plus?
  • Anonymous Mar 31, 2014
    my Mit.TV CS27303 loses audio after 2 mins. Nothing seems to help even turning set off & back on, HELP.
  • 3,130 Answers
If you have the set off, and the cable plugged into the back of the set for a day or so, the guide plus should come back. It will sometimes take up to 48 hours. If it does not, there is a problem with the set and will require servicing. Good Luck
Posted on Oct 16, 2007
Menu keeps popping up
If you have the guide plus feature go into the setup for it and when it asks if you have a cable box, indicate no, when it asks if you have a Vcr also indicate no. Last if it asks for the zip code enter all 9, This should rule the Guide feature out of service and you will know if it is your problem or not---it created a lot of problems in sets that had it, especially RCA or GE sets.
Dec 20, 2012 | RCA F36650 36" TV
RCA Home Theater Premiere 36" TV comes on automatically
Only two possible reasons I can think of for this--
ONE: you have looked in the customer menu and there is no item listed as Timer?
LET me know if it has the guide plus feature and I can tell you how to end the problem--most of these the set will come on at the same odd time and usually with volume up high.
Dec 26, 2009 | RCA P52937 52" Rear Projection Television
I bought a 27 inch tv in 2002 now the tv guide
Here is a whole forum discussing this.
It sounds like you need to reset your local zip code to 99999 then unplug the TV for at least 12 hours. Then plug it back in, reset to your real local zip code and go through the guide setup menus.
Dec 24, 2009 | RCA F27442 27" TV
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
RCA 27V550T 27" TV
Problem fixed. I unplugged the TV for 20+ seconds, then before plugging it back in, I shorted ac plug prongs together with a metal key to ensure complete discharge. Plugged TV back in and used procedure to reset password WITH ONE CHANGE TO THE PROCEDURE.
With TV turned OFF press and hold <CLEAR> button on the remote while pressing <VOLUME DOWN> button on the TV, hold until TV turns on. When the menu appears DO NOT RESET THE PARENTAL CONTROL CODE as the user guide instructs. When my menu appeared it was in the SETUP screen on the LANGUAGE setting. It was set to SPANISH, using the remote I navigated to ENGLISH. Then using the remote I navigated up to GO BACK. Then I navigated to EXIT and hit <OK> button on the remote. All was back to normal.
Jan 10, 2008 | RCA 27V550T 27" TV
Guide Plus on 32in RCA stopped working
Either the hardware has failed or your cable system or broadcasters do not provide this information. Frankly, with this chassis you should be glad it works at all.
Oct 16, 2007 | RCA F27649 27" TV
Television won't turn on
The beeping sound is the power supply trying to start up. That means there is a short somewhere inside the set. On these TV sets most of the time this trouble is in the horizontal sweep circuit. Sorry but the only way to reset a TV set like this is to unplug it for several hours. But in this case I doubt very much it will work. If you have no solid state repair experience then please call in a certified tech to assist you in this repair. Let me know how you made out. Good Luck
Jun 28, 2007 | RCA F27681GY 27" TV
RCA 27r410t 27" won't turn on,just makes high pitch noise
that high pitch is comming from the flyback replace the flyback and the HOT.and you will restore back the life of your tv.good luck.
Jun 04, 2007 | RCA 27R410T 27" TV
Loud hum when attempting to turn on my RCA F27628 27"TV
could be that the main b+ filter Capacitor went bad and blew up. Also could have been the horizontal output transistor shorted and the flyback poped. In eather case it would be recommended that you take this set into a repair shop unless your familar with HV circuits in tv sets. Good Luck
Jun 10, 2006 | RCA F27628 27" TV
Guide Plus feature not working.
hi call your service provider and tell all this they will fix it or send you a man good luck
Apr 28, 2006 | RCA F25649 25" TV
RCA F25649 25" TV Logo
336 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
