Question about Husqvarna Designer I
Designer I Husqvarna Sewing Machine
The machine has power and turns on
but the screen is frozen. I have turned it off and then back on several times but nothing changes. It will sew the straight stitch, and I have not even activated the A screen.
Thanks for your help.
Are you kidding me.....I can pay to be on your plan and you may suggest a solution.
But I can tell you how I fixed the problem for free??
I'll let you know for $19.95!!!
Posted on May 15, 2009
  • Michella Linton Aug 23, 2010
    Kaoler- did you really fix it because my machine is doing the same thing. my e-mail is linton_mi@yahoo.com
Designer 1 touch screen frozen
the touchscreen cable may have come loose or perhaps the touchscreen has failed. take the machine to an authorized Viking repair dealer to have them troubleshoot it.
d
Apr 14, 2014 | Husqvarna Designer I
Designer SE screen frozen
it's possible that the computer part of the sewing machine made have gone out, it's time for a trip to the sewing machine repair shop
Apr 13, 2014 | Husqvarna Designer I
My machine's screen keeps turning off but the function buttons stay lit. The machine appears to reset itself randomly while im sewing and sometimes even when im not near it. Everything else seems to be...
Has your Designer 1 ever had the power supply replaced? Almost all Des 1's had a recall that was replacement of the power supply. Any Husqvarna Viking dealer will be able to check the power supply, or transformer, in your machine and make sure that it has been replaced. Sometimes this can be a loose connection inside the power supply.
Sep 17, 2011 | Husqvarna Designer I
.legge@hotmail.comMy designer 1 Touch Screen
Hi,Try this,switch off machine,press in reverse and pivot button together,switch on,release buttons and press up/down needle button,this brings up calibration screen.With a plastic stylus or something similar(not metal) touch in centre of each cross,they should turn green.Switch off and on again. This will calabate machine the screen.
Hope this helps
Mar 22, 2011 | Husqvarna Designer I
My Designer 1 touch screen is not responding. I know how to calibrate it, but can't do even that until I can select the options on the screen. Is there a way to unlock it?
I have this information from a person who was a Husqvarna Designer expert:
When you just can't get to the menus at all:
Turn the machine off.
Then hold down the "Reverse" and "Pivot" buttons and power it back on.
You now have the setup screen.
Touch the "Needle Down" button and you will see the crosses.
Use a small blunt object like the metal end of the buttonhole foot (the stylus that
came with the machine would be better ) and
touch the centre of the crosses and each will turn green. Then click on
"save".
Oct 11, 2010 | Husqvarna Designer I
Original designer I and the touch screen is frozen.
The front cover will have to be removed to access the componets to find the problem... it could be as simple as a loose connection or as complicated as having to replace the touch screen. Removing the front cover is not a simple task if you do not have experience in working on this machine. I would suggest it go in to an "authorized dealer.
May 15, 2010 | Husqvarna Designer I
Machine shut off will not turn back on viking designer 1
Did you check the power cord both at the sewing machine and at the wall plug? Push them both in firmly. Check the power cord along its whole length to make sure it is not broken. Replace it if you find any serious rips in the plastic outer casing of the cord. No need for a special Husqvarna power cord - a small appliance cord with the same plugs at either end is all that is needed.
Did you hear a "popping" noise when the machine turned off? You may have a short in the transformer in which case it needs to go to the technician.
Apr 18, 2010 | Husqvarna Designer I
Janome 300e touch screen not working
The screen has something stuck around the edges or its damaged, have you tried to touch all parts of the screen to see anything happens? If you need more help 612-270 2957
Jun 22, 2009 | Husqvarna Designer I
Designer embrodery machine wint start. left in car and is very cold but mot frozen? just click when i power it up
wait till it reaches normal room temperature,and try again, certain elements in the operating computer do not like to be frozen.
Jan 28, 2009 | Husqvarna Designer I
My Desiger SE embroidery machine is frozen on the start up screen
Turn the machine off. See if you can put it in update mode by pressing and holding the lower right and upper left buttons to the left of the take-up lever while turning the power back on. If you can get to update mode, download and install the latest update.
Let me know how this goes.
Apr 26, 2008 | Husqvarna Designer I
Sewing Machines Logo
232 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
