Question about Rowenta Commercial Garment Steamer - White
Is there a product to run through a rowenta pro garment steamer to eliminate build-up?
  • 26 Answers
To start with, use distilled water for steaming. This will prevent calcium build-up. I buy bottles of distilled water for ironing/steaming only. I have never had calcium build-up from using distilled water for ironing/steaming. Do not use tap water!!!
You can buy some CLR (stands for Cacium, Lime & Rust) (can be found at Walgreens, CVS, Target, Walmart, etc.). You can run this product through your steamer to eliminate build-up.
Posted on May 19, 2009
Why do water drops form om my clothes while steaming
You have a build up of water In the hose. Sometimes happens because the hose is too low to the ground. Try stretching the hose up and tap it and the water should travel back down the hose.
Another reason could be that you are using too much steam for that particular fabric.
Jul 08, 2014 | Rowenta Commercial Garment Steamer - White
Rowenta garment steamer is 9100 lights up but no steam
Look at the manual again maybe theres a button that you have to turn on. Or call the nearest repair man maybe he knows or can tell you.
Dec 26, 2012 | Rowenta Commercial Garment Steamer - White
ROWENTA IS8050 INSTRUCTION MANUAL
Rowenta IS8250 Garment Steamer instructions are no longer available from Rowenta.
May 28, 2012 | Rowenta Commercial Garment Steamer - White
How to unclog a garment steamer
Hi, Try puting a cup of white vinegar in and let it sit over night. It should disolve the build up of calcuim. Also try CLR it also will work. Good luck.
Nov 04, 2011 | Rowenta Commercial Garment Steamer - White
I have a Rowenta steam iron and it has been leaking, not steaming properly. also, I have been using tap water. How can I clean it? Can I use the products designed for dishwashers, like "Glisten" to rid...
the loss of steam is from usually from a barrier or o-ring or some sort of insulating material it has to be sealed because if it is not the the steam will not build up the pressure required for adequate cleaning power, try to seal up where the water is coming from, and yes you should be able to use something to get rid of the build up just make sure you rinse it all out so it wont mess anythng up and tap water is fine you will just get that build up from it cause of the chlorine and other products in tap hope this was helpful:)
Nov 16, 2009 | Rowenta Commercial Garment Steamer - White
On and off petal switch not working
When I took mine apart I noticed the switch had melted near the contacts. This makes me not want to fix it, but instead, look for a better model. Hope this helps.
Jun 10, 2009 | Rowenta Commercial Garment Steamer - White
Rowenta Commercial Garment Steamer - White Logo
1,691 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
