Question about U-Line CO2075F-B Echelon Refrigerator Ice Maker Combination
Ice Maker frost and freeze where ice drops into refrigerator door
The ice maker itself seems to be working on this Whirpool Imperial refrigerator. The ice maker makes the cubes and dumps the cubes into the depository. The refrigerator is designed to allow you to get crushed or cube ice and water from refrigerator door, without opening the freezer.
Several months ago, the place where the ice drops into the door slot started to freeze over. If I pressed the door lever with a glass, no crushed or cubed ice could fall. If I unthaw the area, ice drops freely for about and hour. Then, the area freezes over again. I scrape or thaw the area practically daily, even though I no longer use the door and reach into the depository to get ice. What is making the spot freeze over where the ice drops into the door.
The water is fine. I can still press the lever and get cold water.
  • 286 Answers
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
Posted on Aug 23, 2009
My kenmore 106.51133210 refrigerator is not making ice
Try filling the ice maker with tap water until the tray is full allow it to freeze turn on the ice maker and if after the water freezes it drops the ice into the ice container then replace the water control valve found at this link below
Water Inlet Valve WPW10341320
If after the water freezes with the ice maker on it does not drop into the ice bin then replace the ice maker itself part number below
Ice Maker Assembly WPW10251076
Thank you
Appliance 911 Sea Breeze
May 06, 2016 | Kenmore Refrigerators
Why is my 2001 Whirlpool Imperial Series side by side refrigerator frosting up around the ice maker?
Ice makers can do this for several reasons. One is the incoming temp of the water is causing condensation to form and it freezes. Another reason is air leaks from the ice maker door.
Aug 22, 2014 | Refrigerators
My Whirlpool Freezer/Refrigerator model# ET19RMXGW02 is not keeping items cold. The ice maker is not working. There is frost in on the back wall of the freezer but objects like ice cream are all soft. ...
your evaporator coil behind this frost on the wall is iced up and you cant blow cold air through solid ice,remove this panel and defrost the coil,then check the defrost heating element below the coil,the defrost thermostat located on the coil or the defrost timer itself for being defective
Aug 05, 2010 | Whirlpool Refrigerators
Ice maker quit after my husband over filled the top shelf and blocked the air flow for the freezer. The freezer started to defrost itself and water was on the floor in front of the freezer. He unblocked...
Yes, If you will try a couple things. Fill ice maker with water and let freeze. Tell me if it will drop the ice when frozen, Let me know that and your model number. I am doing this to decide which one is the problem. The ice maker or the water control valve. Sea Breeze
Nov 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working in side by side whirpool refrigerator
Who replaced a motor in an ice maker? There are no motors to replace. Demand your money back and buy a new ice maker at your local appliance parts store or on line.
Jul 01, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Whirlpool side by side ice maker freezes up. can't get ice out of
Can you give more details?
If the ice chute is frosting up, chute door is not sealing, air , with moisture, is getting in and freezing. An ice cube getting trapped by the door will cause this also. Either case, replace door and delay mechanism.
May 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frost on ice maker
look at the chute where the ice comes out the door and see if the door in there is sticking open and leaking air in some times it helps to hold a flashlight on the out side aimed up the chute while lookin down on the inside
Dec 31, 2007 | Whirlpool GS6NBEXR Side by Side...
Frost accumulation on ice maker
Normally the frost is taken away during defrost so if things get worse we need to look at the defrost timer.If freeze temps.begin to rise let me know, Thanks JT
Oct 24, 2007 | Frigidaire FRS26KF5C Side by Side...
Refrigerators Logo
583 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
