Question about Intel Pentium III-M , 1 GHz Processor
PROCESSOR MAKE - Intel Pentium III-M , 1 GHz Processor
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there.
    Can you explain your problem in more detail please.
    Regards
  • 433 Answers
Http://developer.intel.com/design/mobile/pentiumiii-m/documentation.htm
Intel: the link above will tell you all about your P-3 mobile processor.
Posted on May 14, 2009
Mx6955 processor support
Compatible Processors Pentium 4, Celeron D, Pentium Extreme Edition, Pentium D 64-bit Processors Compatibility Yes Processor Socket LGA775 Socket
Aug 11, 2013 | ASUS Computers & Internet
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
What would cause my aspire 5630 to shut down sporadically?
Shut down sporadically, caused by rising temperatures on the processor (processor overheat). Processor overheat, caused by damage to the processor fan. Processor fan function to reduce the processor temperature.
Possibilities and solutions
1. The possibility of sluggish processor fan. Processor fan spins, with a low speed, so it can not reduce the processor temperature.
Solution: clean the processor fan with a vacuum cleaner, or replace the processor fan.
2. The possibility of fan processor die.
Solution: replace the processor fan.
The characteristics of damage to the processor fan
After the laptop is turned off (more than 1 hour), the laptop can turn on and survive + - 30 minutes. In the period of + - 30 minutes, the laptop died suddenly, because the processor temperature exceeds safe limits (shut down temperature).
How to check
Laptop is turned off (more than 1 hour), then turn on. Download and install software to check the processor temperature. Ex. Real Temp 3.60. See the change in temperature. If the temperature continues to rise, it can certainly cause damage to the processor fan.
- Normal temperature, when first turned on + - 38oC
- Normal temperature, after turn on for hours 40oC - 45oC
- Temperature overheat processor, when first turned on 60oC - 65oC
Nov 18, 2011 | Acer Computers & Internet
Hi....how can i repair my processor it is very fast to heat..then my computer is shut down....but i try to change my board... it is sane problem
remove the processor heatsink and the processor clean the surface and apply a thin layer of heat sink compound and fix back the processor and also check the processor fan is working if the processor is fauly the processor heats up quickly and shutdown the computer
Aug 04, 2011 | Compaq Pentium II , 266 MHz Processor
Dear sirs, I would like to upgrade the cpu`s of my Compaq Evo W6000 PC with the Motherboard Model 06D0h. Please let me know what are the strongest cpu`s I could use. Many thanks Murat
I suggest this to you.
Intel Xeon Processor, 1.4 GHz/100.0K
Intel Xeon Processor, 1.5 GHz/100.0K
Intel Xeon Processor, 1.7 GHz/100.0K
Intel Xeon Processor, 2.0 GHz/100.0K, L3
Intel Xeon Processor, 2.2 GHz
Intel Xeon Processor, 2.6 GHz/400
Processor, 1.8 GHz, 603FCPGA
Processor, 2.0 GHz, 603FCPGA
Processor, 2.2 GHz, 603FCPGA
Processor, PRST, 2.4 GHz/400, INT 261668-004 284645-001 source: ftp://ftp.compaq.com/pub/supportinformation/technotes/evo_w6000_workstation_rev6_us.pdf
Jun 29, 2011 | Compaq Evo Workstation W6000 PC Desktop
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
I want to know about different cpu processor.how they are working and evolution of cpu processor
PROCESSOR IS BASICALLY KNOWN FOR ITS BEST PERFORMANCE AND SPEED. CURRENTLY AMD PROCESSORS ARE KNOWN FOR ITS BEST PERFORANCE AT LOWEST RATES. BUT IF YOU NEED A BETTER PERFORMANCE YOU SHOULD GO TO INTEL PROCESSORS. COZ TODAY INTEL PROCESSORS ARE THE WORLDS FASTEST PROCESSORS. THE ONLY LIMITATONS FOR THIS PROCESSORS IS ITS PRICE.
BUT IF YOU NEED TO PLAY GAMES AND WANT TO WORK IN MULTI TASKING YOU I ADVICE U TO SHIFT INTO INTEL PROCESSOR.
YOU CAN COMPARE THE BOTH PROCESSORS. JUST GO TO GOOGLE.COM AND TYPE COMPARE PROCESSORS IN SEARCH. THE RESULTS WILL SHOWS YOU THE SAME THING AS I SAID.
BYE
NICE DAY.
PLS. RATE MY SOLUTION.
KETAN
Feb 18, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
What processor?
Not all processors fit laptops. You shouldn't get a higher powered processor as you would then need to change the power supply as laptops are set to suit themselves.
Getting an intel may stop problems accoring.
Jan 14, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Processor compatability
Processors have a matched frequency rating with the motherboard and memory. So, when replacing or upgrading the processor, the new processor will need to have the same frequency as the old one. If the processors use the same type of memory, ie... PC2100, then ther are most likely compatable, and the use of a processor that was made for or from the same make of laptop is always a good idea. Some processors are designed specifically for use in certain manufacturer's system configurations. For example; say you have a Dell Latitude C840 with a 1.8ghz processor and you want to upgrade to a 2.2ghz processor from a Dell Inpiron 8600, this will work. Both of these machines use the PC2100 memory and have a matched frequency rating of 266mhz, and the processors are made for use in Dell machines. If you would like to tell me exactly what you're wanting to do, maybe I can recomend a processor for you. Let me know.
Jul 22, 2008 | AMD Computers & Internet
Overheating? Processor running at half speed?
If the PC boot and start I believe your processor is OK, it's very unlikely that a bad processor can start.
Normally the average temperature of a processor is between 40-50 degree C. Your processor is overheating and it will not last too long.
Please look at the link here below http://processorfinder.intel.com/List.aspx?ProcFam=483&sSpec=&OrdCode=
and see if you can reconize your processor. The number on the left is the same number printed on your processor (You have to remove the fan again).
As a second test I suggest you to download the Asus manual of your motherboard and verify that you don't have any jumper that you are missing.
If you want to post the motherboard type I can further help you.
Oct 23, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel Pentium III-M , 1 GHz Processor Logo
56 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
