Question about Dell Inspiron 6000 Notebook
Image on the screen is very faint
I see the dell logo at startup then the screen goes dark and i barlely see the windows log on screen
  • 103 Answers
It sounds like yout lcd inverter is blown. You can usually get a new one and replace it yourself. I would look on ebay. Its just a small computer chip that fits inside of the monitor housing.
Posted on May 14, 2009
On acer aspire laptop screen is grey at startup
1. When you press the power button to turn it on, do you see any thing on screen, It probably should show an ACER logo?
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). If you do see a faint image it could mean your back light is broken.
3. When you press the power button do you get different LED's lighting up on the laptop? IE power LED, hard drive LED?
4. Does your computer give you any random beeps when it starts up?
Please answer these questions and I would be more than happy to work through this with your.
Thanks RCCT
Jan 16, 2014 | Acer Aspire Computers & Internet
RECOVERY FACTORY
Hi there!
Here are the steps to restore your computer to factory default:
Windows XP
- Turn on Computer
- during startup you will see the Dell logo, press <Ctrl> <F11>
- click Restore then Confirm
- let the computer finish starting
Windows Vista
- Turn on Computer
- during startup you will see the Dell logo, press <F8> several times
- select Repair your computer
- select keyboard layout then next
- log-in as local user
- click Dell Factory Image Restore
- Click Next and confirm data deletion
- wait until it finish
Apr 11, 2011 | Dell Vostro 1710 Laptop Computer PC...
On start up the screen goes black . As startup is progressing, the screen shows the dell logo and backgroun, and sometimes a log on query, but , after a few minutes the screen goes to black.
Hi
You probably have or had a virus destroy Windows start up files or you have a bad sector under the start up files. You may be able to slave the hard drive to another system to backup your data, assuming there are no bad sectors. Once you are satisfied that you have all your data then a reformat and operating system restore should solve the problems. If you find bad sectors though, just replace the drive.
Jun 06, 2010 | Dell Inspiron 6000 Notebook
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
My dads toshiba A20-S207 has a dark monitor. Can very faintly see the windows xp logo at the beginning of boot up, so it looks like it is booting up, but the monitor stays dark. Can u help?
common LCD dark.dim screen problem, u can google keywords get more information.
either LCD inverter failure or CCFL backlight lamp failure, ask for a pro get it fixed.
by using a flashlight could you see the image on the LCD?
Dec 06, 2009 | Toshiba Satellite A20-S207 Notebook
My dell (monitor) it turns on few secons but the image goes off,
First you'll have to power off the system.
Please power on the system and as soon as you see the Dell logo please tap the F2 button 3 - 4 times.
The computer will go to the system setup. Check if the screen goes blank here.
If the screen stays on then try this.
1. Please power off the system.
2. Please power on the system and as soon as you see the Dell logo please tap the F8 button 3 - 4 times. You'll reach the Windows Advanced Boot Options Menu on the screen.
3.Select Safe mode with Networking.
4. Select Administrator at the log in screen.
5. Warning dialog box with the message Windows is running in safe mode. appears. Click the Yes button.
6. The desktop appears with the words Safe Mode appearing in all four corners.
7. Uninstall the video drivers and restart the computer.
8. Resintall the video drivers.
Rate if useful.
Aug 19, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Back light or inverter. my screen is black.
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 28, 2009 | Dell Inspiron 8600 Notebook
Dell Latitude laptop turns on but very faintly see screen display
The backlight has blown. Can be repaired by professional.
Feb 06, 2009 | Dell Latitude D600 Notebook
Compaq Armada 110 - No screen image
WELL I WOULD LIK TO SUGGEST U TO PLEASE RE-INSTALL YOUR GRAPHIC CARD'S DRIVER AND HAVE A LOOK.
Nov 05, 2007 | Compaq Armada 100S Notebook
Dell Inspiron 6000 Notebook Logo
244 people viewed this question
Alun Cox
