Question about Dell 924 All-in-One InkJet Printer
Every time I try to print the printer just chews up the paper .
I am certain that there are no bits of paper left in the printer , but what ever I do it just chews it up.
    Genius:
  • 1,605 Answers
Yes, there are still paper stuck in there.
turn off the printer and use dental tool and a flash light, slowly turn the paper pickup roller and check the either end of the roller, that is usually where the bits of paper are stuck.
make sure the pickup roller don't have any sticky stuff on them. that will cause the paper to jam up.
Posted on May 14, 2009
Lexmark s605 paper jamming
Sounds like an obstruction on the right hand side of the feed mechanism. All-in-ones are a pig to find these - I've had one HP almost completely stripped before I found a chad of plastic stuck in a corner. Nine times out of ten it's a torn corner of the first bit of paper to get chewed jammed in the feed slot.
Apr 06, 2012 | Lexmark Interact S605 All-in-One Color...
Epsom stylus sx610fw insists there is a paper jam - none to see, but will chew up ordinary paper when working. is there any way to open it up more to look for torn paper that could be registering as a
Yes it can be repaired, but it will most likely take a sensor to do it, this is a common issue. I think the way it works is it senses the force required to turn the roller, if the sensor or the chip it sends its signal to is defective a false paper jam is triggered and the printer stops printing. The problem here is with printers being so cheap to buy why not just replace it. The last time i got a printer it was free with the rebate, and it was a Canon "all in one" that was far better than the HP it replaced. Your decision.
Jan 19, 2012 | Office Equipment & Supplies
First i had an error PAPER JAM , then i open my printer to get out the paper unfortunately the paper became two pieces and one of them get stuck in again. and now i can get it out of my printer.what...
Good day.
There are practical way of removing paper bits in your printer.
- try to print again or load a paper. The bits of paper may move with the new paper that you have loaded or printed in.
- you can get a household tweezers to pick-up the bits of paper left in your printer.
Good luck.
Tedmac
Oct 27, 2010 | Computers & Internet
There was bits of paper, from a stuck edge from a sheet of business cards that I think are perhaps still in the printer. When I print a colour sheet the alignment is off, printing black and white seems OK.
What do you mean by alignment?
If you mean that the colours are misaligned, run a full calibration. Repeat it three times and then try your printing.
If bits of the business cards were left in the printer - it should affect the colour printing as well as B + W. You would also be getting paper jams.
Oct 25, 2010 | HP Color LaserJet 2600n Printer
Samsung ml-1610
There's probably a small bit of paper jammed in the paper-out sensor (hopefully. Otherwise the sensor may have been snapped off).
Extract the paper tray and look inside with a strong light. The paper out sensor should be a dark gray or black piece of plastic dangling from the upper left side. Remove any paper bits you find with a pair of tweezers, then blow on the mechanisms with a compressed air canister for good measure.
Oct 27, 2009 | Samsung ML 1610 Laser Printer
Every time I try to print, the printer grabs the paper crooked.
There's a leaver where the paper comes out, make certain it's to the left when printing with paper and to the right for envelopes.
Jun 14, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Can smears when priting be fixed
Have you tried cleaning the corona wire on the drum unit (the blue slider bit)?
Replace the drum unit (assuming you have already replaced the toner cart?)
To check the remaining drum life press the go button 3 times. A report should print out with the info on. Even though you may have some remaining life, the drum can fail early.
If the dots/marks are repeating about 3 times down the page it is almost certainly the drum unit that has the problem.
Apr 16, 2009 | Brother HL 5250DN Laser Printer
My Canon mx 310 won't print
1 You mast open all the covers? and looking for any fragments from outside.... to the great apeaneon finde visual control for a drive of paper and remoove spare objects
Mar 23, 2009 | Canon Office Equipment & Supplies
R265 chewing paper
Suggest a small piece of paper or dirt is stuck in the print path near the print heads. Use vacuum tube to **** out any dirt
Mar 19, 2008 | Epson Stylus R265 InkJet Photo Printer
Dell 924 All-in-One InkJet Printer Logo
106 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
