Question about Alesis RA-150 Amplifier
Samson power amp capacitor?-HELP!!!!
I have a Samson s1000 power amp that has a blown capacitor.
The (value) or numbers on the capacitor are
Samwha 100 WV-6800 uf CE-HM 85 degree.
I have no idea what these numbers are,i just need to find part so my tech guy can fix it?Any help????
  • bryankeithid May 14, 2009
    This helps a little,but i i still can't find one with the correct value anywhere!!?????
Buy from Distributor Farnell SAMWHA HC 6800uF 100WV
That fits your board. Same as the Korean brand interM 2 x 500W amplifier (M1000)
Note that the HM series capacitor has been replaced with HC 2009 by SAMWHA.
You can find the product sheet at SAMWHA Electric.
It has 4 legs to solder, so it is not a standard one.
Posted on May 09, 2011
  • 700 Answers
Its samwha brand with a 100volt working voltage 6800 microfarad capacitance value its next symbols seems to me the chemical compositions or stock code, and its maximum working temperature. Could be a low ESR type capacitor.
Posted on May 14, 2009
Model XP300. Where can I get a schematic diagram and service manual?
You should be able to read the value of the capacitor on the side
Can you confirm if it is Flat Panel TV from Samsung ? because I find an Epson and Buick
Mar 24, 2016 | Samson Audio Players & Recorders
Samson SX1200 - Protect light on. No blown output transistors.
Have you checked the power supply section? Also look out for any IC's in the amp stages. They can go causing that kind of fault.
Oct 11, 2014 | Samson SX1200 Amplifier
Capacator in lower left corner is blown apart from an 220v generator connection.... where can i get a replacement capacator or board ?
The capacitors are industry standard items that can be cross referenced from the component markings, values, or part numbers referenced on the components through several national component suppliers such as Digikey, Mouser Electronics, or Newark Electronics. If a single bulk capacitor has blown, both should be replaced as the other will have been stressed and should not be trusted to be functionally sound.
Apr 11, 2014 | Parallax Power Supply Parallax 7300 Series...
R1400D SCHEMATICS
This is actually not so difficult from a logics perspective.
(Also it is true about their lack of schematics)
There are usually many more than one capacitor in these units. Good thing is all the capacitors are usually from the same manufacturer. Therefore is you match the size you can usually be pretty sure of the value of the blown one as they are usually a range of sizes for each value.
Hope this helps.
Jul 13, 2017 | Boss R1400D Car Audio Amplifier
When I turn on the amp the indicator lights comw on and seem ok for 3 or 4 secs and then there is a click and the amp lights go out even though power is still showing as on.
Sounds like the amp is going into a protective mode.
Make sure your outputs aren't shorted.
If you're into electronics, look for bulging electrolytic capacitors or blown transistors.
Something is tripping the safety in the unit!
Mar 01, 2011 | Samson Xm910 8Channel Powered Mixer...
Fuses keep blowing on my Samson Servo 120a
If after putting in the right rating of fuse you have a blow out, then you must diconnect the speakers and test. If the fuse hold ok then the speakers must be checked for shorting or fault in the network. However if the fuse still blows off, then you will need to take out the cover to test within the main board for the power section or output section malfunctioning. First of all discconnect the power to the output stages and test, if fuses blows check the powersuppy section, the rectifier to the main capacitors for reduced values. If not check on the output stages, the drivers, the predrivers for malfunctioning. However you will need some knowledge of electronics to probe stage by stage to isolate the fault.If not get help to proceed. Good day
Aug 03, 2010 | Samson Servo 120 Amplifier
LED blinks in milli seconds and the images appear too late.
If your lcd comes with ac adapter open this and check for blown or bulge capacitors, replace this with same value.
If your monitor comes with plug cable, open your monitor (too risky to do it by yourself) check the power supply section, check and replace blown and bulge caps.
Jul 09, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Hi There the fuse just blew in one of my Samson
Hi there
To answer your question;
If it is not indicated near the fuse holder then look closely at the metal end caps of the fuse.
The value will be written on one of them,
It may look like 2A/250v for 2amps.
Hope this help
Cheers
Jun 14, 2010 | Samson Resolv 65a Main / Stereo Speaker
P4004 - Blown Components
if burned components are on output stage or amplifier section on board..Then look at the oposite side of amp..Both amplifier section should be a mirror image oof componentc from other..that way you can know the values of parts.If they are on power supply section ..Then you might need manual if available..
Dec 23, 2007 | Rockford Fosgate Punch P4004 Car Audio...
Alesis RA-150 Amplifier Logo
1,055 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Gil Shultz
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
