Question about Motorola Cell Phones
Bluetooth pin for pairing with other bluetooth devices
Ya..
Posted on May 14, 2009
How do I pair with Samsung galaxy note 10.1 2014?
1. From a Home screen, touch Apps
Settings.
2. On the Bluetooth tab, touch the OFF / ON icon
to turn Bluetooth on.
3. Enable the target device's discoverable or visible
mode.
4. Touch the Bluetooth tab and then touch Scan. Touch
Stop at any time to stop scanning.
5. From the list of found devices, touch the target device,
then follow the prompts to complete the pairing:
• If the target device requires a PIN, enter a PIN for the target
device and touch OK. When prompted, enter the PIN on the
target device.
• If the device allows automatic or smart pairing, your device
attempts to pair with the device automatically. Follow the
prompts on your device and the target device to complete the
pairing.
Oct 19, 2014 | Microsoft Wedge Mobile Keyboard
Whatis the bluetooth pin for samsung c6112
check the bluetooth in settings go into bluetooth .. turn on bluetooth and phone will scan for devices to pair with. The other device will show if it has bluetooth on and set to discoverable.
Under available devices on your mobile touch with finger it will try to pair and say boothtooth pairing request. Confirm passkey is {whatever number it generates} to pair with {whatever device it is pairing with } note what the number is and press ok. At the top of the screen is a note says visable to all nearby bluetooth devices . the box needs to be ticked and other device should have same pass code when it tries to pair. It will ask you to confirm code.
Jan 12, 2018 | Cell Phones
My friend gave me his bluetooth but i need the pin to connect it to my phone and i cant get it .how can I pair it to my phone without using a pin or making a new pin?
The pin or the passkey is "0000". To pair the SGH-T749 (Highlight) handset with a Bluetooth Device follow the steps below:
  1. Place the Bluetooth device in discoverable mode
  2. From the standby screen, press on Menu
  3. Press on Settings
  4. Press on Bluetooth
  5. Search for the Bluetooth device by pressing on Search, located at the bottom
  6. Press on Yes to Activate Bluetooth and start the search
  7. Press on the desired Bluetooth Device (if not shown press on the left or right arrows until displayed)
  8. If prompted, press the Passkey "0000" then press on OK
  9. You will get a brief message stating connecting followed by connected, if prompted press OK again
Note: The first time you try to pair with another handset, you and the owner of the other handset must enter the same PIN. Once the handsets have been paired, you will not need to use the PIN again.
Mar 30, 2011 | Samsung OEM Travel Wall Charger for...
How do you turn this device on and pair it with your phone?
to turn this device into pairing mode hold the power button down for 8 to 10 seconds,then a light should stay on.once you have put the bluetooth device into pairing mode you phone will find it and ask for a pin\pairing code.most bluetooth manufactures use a 4 digit pin\pairing code they are as follows ,0000,1234,9999,or 1111 and try them in that order one should work for you .Hope this helps
Mar 23, 2011 | LG HBM 730 Bluetooth Headset Wireless...
I've tried sending pictures to other phone but they never go trough
I imagine this is through Bluetooth.
You have to pair the two devices first. It should be under your bluetooth settings > Pair devices.
Once you pair the devices it will ask you for a pin. Insert the same pin on both devuices and they will be paired. You should then be able to send pictures and other files via bluetooth.
Mar 01, 2011 | HTC EVO 4G Smartphone
Im having problems a sanyo katana lx cel phone connecting to a vehicle bluetooth? what do i need to do?
In general, each bluetooth device you want to pair with your phone must be put in pairing mode (consult the device's user guide on how to do it). Then, you must make your phone's bluetooth application search for new devices. After a while, the device should appear in the phone's screen. It should be selected, and be commanded to proceed. In case a PIN (or passkey, or pairing code) is requested, enter 0000 (four zeros - it's the default PIN adopted by the vast majority of bluetooth devices' manufactures, but here again, consult the device's user guide, to be sure). In normal conditions, this pairing process should be performed just once. All subsequent connections between already paired devices should be made automatically, provided that both their bluetooth stacks are turned on.
Hope you are able to sort your problems out.
Cheers! Carlos
May 11, 2010 | Sanyo Katana LX Cell Phone
How di I pair my motorola H720 bluetooth to my ,
On the PHONE
Turning on and pairing a Bluetooth device
To turn on and pair a Bluetooth device, perform the following steps:
1. At the Home screen, press the Menu key.
2. Touch Settings.
3. Touch Wireless controls.
4. Touch Bluetooth to select the check-box and turn on Bluetooth.
5. Touch Bluetooth to select the check-box and turn on Bluetooth.
NOTE: The device searches for Bluetooth devices and display a list under Bluetooth devices.
6. Touch the Bluetooth device that you want to connect to.
7. If required, enter the PIN and touch OK. the Pin/passkey: 0000
On Bluetooth headset
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Power switch
towards the microphone to initiate easy pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate headset is in pairing mode.
Select OK.
Oct 25, 2009 | Apple iPhone 3G
I have a new phone I am trying to pair & have lost the instructions. Have tried 0000 & 1234
I assume you are talking about paring your bluetooth head set with your phone. It would help if you list the make and model for both of your phone and bluetooth device.
But in general, you put your phone in discovery mode to search for new devices, then you can power up your bluetooth device in pairing mode, usually by holding the power button for a long time while powering on the device util it starts flashing. After a few seconds, both devices should find each other. The phone should prompt you if you want to pair with the device found.
Sep 17, 2009 | Cell Phones
I don't know the pin number to my bluetooth HBM-730
Are you trying to pair these two devices? In that case enter any number as your PIN when prompted and enter the exact number in the other device when it asks for. PIN number is asked when you try to pair two or more bluetooth devices. PIN can be any number but make sure you enter the same number in all devices.
I hope it helped.
Feb 10, 2009 | Cell Phones
Forgot how to par my bluetooth PLT 510 to my Palm Centro
To pair with a Bluetooth device:
  1. Make sure the device's Bluetooth radio is on.
  2. Set the handset's Bluetooth discover mode to On.
  3. Select the appropriate Bluetooth accessory.
  4. Enter your PIN number.
Once a Bluetooth accessory has been paired with the device, it can be used with the device, without the need for re-pairing, assuming the appropriate profile exists for the required service.
Sep 16, 2008 | Plantronics Lands Phones
Cell Phones Logo
136 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
