Hitachi 32ld8d20ua....Pics dark and blurring during on screen movement.invertor? I have a similar problem. Picture not always present but when it is, it is like a ghosting effect with a blue tint, like a negative photo
    Brigadier General:
  • 3,917 Answers
Depending on the age,as you did not mention, you could have a contamination inside the surface of the Picture tube in the liquid coolent or silicon spacer in between the crt and the lens assy. This will get worse with time and will happen most likly again on the other tubes unless you have a pro come out and replace the liquid and refill with fresh stuff. Its not a job for the unexpirenced person with TV sets. You may want to think about another set depending on the age of this set and the Estimate you get on this set. Good Luck
Posted on May 14, 2009
Hitachi 32LD8D20UA LCD TV, No Picture, Sound and Backlight Working
Replace the TV, the new ones are cheaper than repairing this one.
Feb 22, 2012 | Televison & Video
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
How to get the blur off
Blurred photos on a digital camera are almost always caused by camera movement while the picture is being taken. Remember to hold the camera still after the shutter is pressed, as there is usually a slight delay.
Oct 18, 2010 | Cameras
Blurring during realtime movement
Try a different USB port if you can.
Check the lighting, to make sure you do not have "low light" conditions, that will affect the picture in a similar way.
Check the focus ring on the front to make sure it is set right.
http://www.pcauthorities.com/pc-errors/how-to-fix-webcam-problems
Dec 18, 2009 | Logitech QuickCam Pro 5000 Webcam
Hitachi L32HO1UA HD TV blurred images very dark unwatchable scree
Hi Ellie!
Maybe in the manual you can find any information how to resolve this problem.
On this page of the manual there are shown most common receprion problems: http://manualsbrain.com/ru/manuals/979781/?page=72
Apr 26, 2017 | Hitachi 61SWX10B 61" Rear Projection...
Re: Blurred Image, horizontal lines, photo taken during the day
my friend ur CCD is getting weak this is the first sign of the problem when u get lines hor and vertcal and sun light pics are blurred and over exposed after that this problem extends to the indoor shots as well pls confirm it thru service centre for 100% ,
pls do rate me i know it is a difficult moment but i helped u in diagnosing ur problem without wasting time
Mar 03, 2009 | Sony DSC-T70 Digital Camera
Cannon a410
are you on auto mode or manual? if you are on manual, your settings might be on macro mode. reset it to manual.
Dec 04, 2007 | Canon PowerShot A410 Digital Camera
Light and dark?
The video invertor board needs replacing.
Jun 25, 2007 | Samsung LTN1785W 17 in. HDTV-Ready LCD...
Dark , blurry picture
MTNESTR, My guess would be the FBT loc.TH01(flyback transformer) Hitachi p/n#BW03004 which would be far less expensive than replacing the entire deflection board... A shop could ring test the FBT to confirm the failure. I do know the FBT in this unit has an internal resistor that is prone to failure. It is in-line with the focus block and if it's open it would explain the blur and lack of screen voltage to light the crts properly. The deflection board is about $290-$350 plus shipping and a FBT is somewhere between $60 - $90 depending on the supplier. Hope this helps! Bill
Jun 04, 2007 | Hitachi 46F510 46" Projection HDTV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
