Question about Sanyo Televison & Video
My Sanyo TVS-1430MA TV now shows a "Factory" message on the screen and I cannot change the channels neither directly on TV nor with the remote control, unless I turn of et on the device. But 10 seconds later the message show again.
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
MikeNJ1964
  • 398 Answers
SOURCE: sanyo 31 inch dbx mts color monitor (1992-93?)
Your TV is in the demo mode. Try this: Press the MENU button and hold it down for about 10 seconds.
Posted on Aug 14, 2007
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
Posted on Mar 19, 2008
jerryg50
  • 1667 Answers
SOURCE: sanyo remote control hdtv ht30744
You need the original factory remote control. Do a web search for Sanyo. Go to their tech support. They can advise you about how to order a new remote for your set.
Jerry G.
Posted on May 09, 2008
  • 22 Answers
SOURCE: Wharfedale TV/DVD combo
Contact agent for the unlock code.
Menu and 4 digit code unlocks factory default.
Problem is caused when wrong sequence of keys on remote is pressed, part of parental control.
Posted on May 12, 2008
Universal remote does not work for navigation through settings
Some TVs do not respond to a universal remote. Vizeo is one of them. I suggest you order a remote specific to your TV and model number http://dp26649.remote.sanyo.emtcompany.com/
- cost is 19.95, free shipping
Sep 05, 2015 | Sanyo DP26649 26 in. TV
Dish remote 2 changes channels on both tvs and dish remote 1 changes channels on both tvs
Is the receiver in dual mode? Go to the receiver, open the door, and hit the mode key. If both TVs are still showing the same thing, then the issue is not the mode.
Go to TV 2 (the one without the receiver) and make sure the TV is tuned to channel 60 or 73. If it is still showing the same thing, go to TV1 (the one with the receiver) and hit Menu, system setup, Installation, modulation (menu 6-1-5). make sure the modulation for tv2 matches which channel you put your tv2 on.
Still showing the same thing? check the back of the receiver, the RCA cables (red/white/yellow) are plugged into the TV1 ports not the TV2 ports.
Showing different things but the remote still changes channels on both tvs? Go to TV1, hit menu twice, near the bottom there are two boxes each with a number. This is the address for each remote (tv1 and tv2). On the TV2 remote hold sat until it stays lit, choose a number different than on the screen, touch pound (#), the sat light blinks three times, hit record, the number on the screen should change to match the one you typed in.
Still being silly? Call a priest, you have a poltergeist!
Oct 24, 2013 | DISH Network IR Remote Control
My Sanyo AVM-3651g 36" TV keeps showing the
On the remote that came with your TV, press the Display button, which is directly below the Volume Up button. Pressing it once displays the channel number and time, pressing it twice displays the channel number continuously, you must have accidently pressed the Display button twice. Just press it once more to remove the display.
Sep 02, 2011 | Sanyo Televison & Video
I have a sanyo tv. Slightly older. Not hi-def or New
Hi:
This may be due to the possiblity that the you are on the wrong input source, If you watch HD Channels then the input source would either be componet or HDMI input. Try changing the input source of the television with the TV's remote until you see the Channels again. IF you are not watching HDTV then the television is on the wrong reception channel for the Direct TV's box. Try channel 4 or 3 or even 73.
May 06, 2010 | Sanyo AVM-2509S TV
Connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Jan 02, 2010 | Sanyo DS27930 27" TV
Vizio 32/DirecTV - slow to change channels
Some TVs switch faster than others, plain and simple. I went from a Sony LED to a Sanyo LCD TV and there's a world of difference between the two in terms of how quickly each powers on and how fast one channel goes to the next after inputting the channel number on the respective remotes. The Sony is lightening fast compared to the Sanyo. I have a Phillips LCD in a bedroom that takes a long time as well, like the Sanyo. Personally I think you get speed with either the LED (over the LCD) and/or it's related to the quality and associated price you've paid.
Dec 09, 2009 | Vizio L32 32 in. LCD HDTV
How to program remote control panasonic EUR7722X50
hola tengo una tv sanyo de 16 pgls model 1430MA(C) compre un control ke dice control original sanyo no especifica marca ni nada asi por el stilo me pueden conseguir la solucion para esto
Feb 10, 2008 | Televison & Video
Sanyo DS31590 channel display
I found the solution to this problem . If someone accidentally hits the recall button the display channel will show on the TV screen, To correct this problem hit the Info Button and the display channel will disapear. This works only if you have the standard cable box. I have another TV that uses a dual mode cable box, tried this procedure with analog RCA TV but it didn't work. Don't know if this procedure will work for all display problems, but it worked for me.
Jan 12, 2008 | Sanyo DS31590 31" TV
Frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Oct 13, 2007 | Sanyo HT27546 TV
Televison & Video Logo
74 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
