Question about Canon MultiPASS F60 All-In-One InkJet Printer
Black Ink Skipping
The printer was working fine one minute and the the black in just started skipping. It will print a couple of lines perfectly, then the next line is printing, but it's very light. I tried changing the cartridge, cleading the nozzles and print head, and even cleaned the clear strip behind the print head as you suggested to someone else. I need clear printouts, and it's not what I'm getting. Please HELP!!!
  • 4 more comments
  • Minerva58 Nov 12, 2007
    My problem is similar. Nothing in black will print. All the colors work fine, but no black text or background prints. If there's a colored background, the text or design that should have printed in black shows up white. I have cleaned everything and put in a new black cartridge thinking that I had run out of ink. Nothing has worked so far. Thanks for any help.
  • Dawn Miner Dawn Miner Nov 12, 2007
    me too! Just started. Maybe we buy new printers?
  • Anonymous Nov 27, 2007
    I have the same issues. F60 was working fine and I switched to off brand ink and now the black does not print or skips. Any ideas?
  • Anonymous Nov 29, 2007
    Our printer started having this same problem a couple of months ago. I've been avoiding printing, but now I want to print the holiday newsletter and I'm out of luck! We did all of the same cleanings that the other posters have done and it didn't help us either. Do these things only have a five year life span?
  • etats Apr 07, 2008
    Aye, I too am suffering the same problem with the black. Please help...
  • Anonymous Aug 24, 2008
    Same problem. Prints every other black line of text. Tried suggestions to clean printer heads--and no luck. Any suggestions??????
Same problem...Canon obviously has a problem in this area they should address and support their users at their cost.
Posted on Jan 20, 2008
I had the same problem. i use ink refills instead of purchasing new cartridges. the ink refill that i use came with print head cleaner. i removed the print head with all cartridges, then removed cartridges.
next, and have plenty of paper towels handy because this will be messy, add print head cleaner drop by drop until the solubilized ink and excess cleaner drip from bottom of print head profusely. you can either let print head air dry or dry to soak up all liquid with a q-tip.
i reinserted ink cartridges and re-inserted print head into printer. did nozzle check and black ink was printing properly. next re-align print head.
Posted on Jan 17, 2008
If you open the printer so the cartridges move to the center and lift the gray handle so you are able to pull the printer head out. Chances are when you do... you will see all the corrosion. Just clean it off and you should be good to go.
Posted on Dec 05, 2007
After entering my posting earlier today, I did some more internet searching on this problem. I found a helpful British website that listed a trick for cleaning the printer carriage area. It's a little more than halfway down the page, if you click on this link, http://www.valueshop.co.uk/printing.asp
Here is what they suggested:
"1. OPEN printer so the cartridges move to center of the carriage.
2. REMOVE all cartridges.
3. FOLD a letter size piece of paper in half, and then in half again the other way so it is quartered.
4. START with the long, folded edge and insert into front of printer where paper normally feeds out. (it will slip in a little over halfway)
5. MOVE the paper left and right to remove any excess ink under the carriage. When the excess ink is removed the printer should print streak-free. "
I tried this (actually used 3 or 4 pieces of paper because it was pretty grungy), and I can print without bands of gray now. Although, the colors are not as vibrant as they used to be, neither is the black. (My holiday newsletter looks good enough to send out, at least.)
After cleaning the printer carriage area, I ran the nozzle check pattern test again and it still looks bad. I then cleaned and realigned the print head, and again the nozzle check pattern continues to look bad. The user manual for the F60 (page 10-5)said that if the nozzle check pattern does not improve after a deep cleaning then the printhead may be damaged. I called Canon tech support and they think that the printhead is probably damaged, but they suggested that I take it to an authorized Canon repair shop, which is too far away, and probably too much trouble. My other option is to order a new printhead directly from Canon for $45 plus $6 shipping and install it myself (or make hardware engineer hubby do it ;-) ).
Hopefully this trick for cleaning the printer carriage area will help others at least for the short term, like it helped me. Good luck!
Posted on Nov 29, 2007
SOURCE:
Black ink is skipping lines
Take out cartridge put in a sandwich baggie and shake it; then re-install
Sep 25, 2014 | Canon PIXMA MP610 InkJet Printer
Ink cartridges
The symtoms of a dried out cartridge is white lines through the printed letters.
I've seen brand new dried out cartridges.
Aug 08, 2008 | HP DeskJet 882c InkJet Printer
Black ink problems
Most likely there is a problem with the ink level reader. Replace the black ink cartridge.
Jul 04, 2008 | Dell 922 All-In-One InkJet Printer
Full ink cartriges print a few lines and skip a few lines
well..did you run a test page?
or clean the print heads?
or recalibrate them?
recommend all these steps for you
and as my 2200th solution, you are entitled to a FREE tuneup for good. find out more about that service here
Mar 23, 2008 | Canon PIXMA iP90 Mobile Printer
Cannot print in color on HP OfficeJet 9110 All-in-One
Nothing to do with the driver, I'd say the cartridges are your problem, skipping lines and missing colour are indications of needing new ink carts, are carts new HP ones?
Jan 19, 2008 | HP Officejet 9110 All-In-One InkJet...
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Black ink not printing properly
This could be a driver problem. Could you uninstall the driver and reinstall it. go into the printer and faxes and delete your printer and reinstall it if you have the origional install disk. Otherwise go on to the internet and download the driver from the makers site first before you uninstall it. You may have delete a part of the driver by mistake or maybe it got corrupt.
. Otherwise there could be a problem with the printer itself.
Try it and see how you get on
Sean.
Nov 30, 2007 | HP PSC 1315 All-In-One InkJet Printer
Printer skipping lines
The printer ink that you are using are genuine?
Try Genuine ink clean the head after check nozzle , print nothing spaces , test printing pictures.
Nov 27, 2007 | HP PSC 2355 All-In-One InkJet Printer
Canon MultiPASS F60 All-In-One InkJet Printer Logo
388 people viewed this question
Clive
Clive
old marine
old marine
