12345 does not work. Is there any other pins that are commom? I have never set a pin on my phone. I need to reset due to loss of applications icons.. ie: calculator, tools, etc...
The best thing you could do in this situation is a Master Reset. The master reset will wipe everything on the phone but restore everything back to factory settings. If you want to reset the phone dial ##7780# then type in the factory pin which is 12345. This will wipe the phone completely.
IF YOU WANT TO RESTORE YOUR MOBILE'S SETTNG THEN GO TO SETTING OPTION AND SEARCH FOR RESTORE FACTORY SETTING OPTION. IT WILL ASK YOU FOR PIN THEN ENTER THE DEFAULT CODE (12345 OR 00000). IF YOU HAVE CHANGED YOUR PIN THEN TRY THIS MASTER CODE 2712210654 THIS WILL DO FOR YOU
Hi , Menu > Settings > Restore factory settings . If the reset code is not changed , the default no will be 12345 .If you forgot the pin code then master security codes do not work on the 1600s, take the phone to a authorized service center to be reset. For any quires write back to . If u are satisfied with the answer please vote for me (with atleast 3ups) .Thanks in advance
You do not need a PIN 2 code to reset the phone. Go to Settings > General > Factory Reset. The code you will need to enter is the Lock code.Normally, it is 12345 but if you have changed it you will need to remember it.
from your nokia phone you go to security settings click on factory settings and write the default code that is 12345 by doing these steps your phone will restore your settings
