Question about Dryers
The dryer will usually heat when it first starts in the morning, then the heat will not come back on. Also the more dry, less dry does not advance
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Change heater element.
Vitally
Posted on May 15, 2009
Dryer Timer doesn't move in Easy Care Mode
do you have heat?does it stay hot while in coll down?if so your heating element is grounded,open the door,look up and remove the two screws holding the top panel in place,pick top panel up just a little and move it to the left that should remove the top panel, put it on cool down or no heat and run it,if the heat stays on this is your problem the element is sagging and touching the metal cover around the element,the way the timer works is on timed dry it counts down like a clock until it turns off when on more or less or auto same thing the dryer starts,the heat comes on and when it hits temp. the heat shuts off when the heat is off the timer will advance to off when the heat starts again the timer stops,if the element isn't grounded then you still could have a bad element there are two elements in your dryer if one is broke the timer won't advance or some have only one element so if the timer doesn't advance you probably have no heat or a bad cycling thermostat or a bad sensor up front where the lint filter is.you'll have to check them with a meter.first thing to check is the heater located behind the drum.
Jan 15, 2018 | GE Dryers
On my kenmore dryer 970-c82062-00 I can get all 3 timers to start but the heated automatic dry portion does not time out.
that model number doesn't come up,you sure that isn't the serial number?also does the dryer have heat,when you run it on time dry the timer just counts down like a clock,when on auto or more or less the heat comes on until the dryer heats to temp. the heat shuts off and the timer will advance,when the heat comes back on the timer stops moving,it will do this until the clothes are dry,if you do have heat you could have a bad sensor or a bad cycling thermostat but you'll have to check it with a meter.send the model number and i can help you better.
Feb 16, 2014 | Dryers
Dryer runs with no heat and never shuts off on its own
what are you running it on?auto or more or less,if so the timer will not advance to off without heat,usually the heat comes on,the dryer heats up until it reaches temp.the heater shuts off and then the timer will start to advance to off,when the heat comes back on the timer will stop advancing and the heat will come on,it will do this until the clothes are dry,so no heat the timer will not move,now if you put it on time dry the timer should count down no matter what just like a clock.if you open the door and look around the opening where you put the clothes in you'll see a tag with the model number send this and i can help you.
Oct 08, 2013 | Kenmore 63942 Dryer
Does not heat up and timer not working?
send brand name and model number so i can help you,also if it's on time dry it should count down even without heat if you have it on more or less the timer will not move without heat.heat comes on until heater cycles off when the heat is off the timer will advance a little,when the heat comes back on the timer stops advancing,it will do this until the clothes are dry.
Sep 15, 2013 | Dryers
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
Dryer takes forever to dry clothes. now it will not dry clothing
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a Free answer, Please rate me.
Apr 11, 2011 | Dryers
My dryers more dry less dry knob keeps sticking half way through and not heating up very much
The dryer will not advance the timer if it doesn't heat up correctly. You have a heating problem so go to the link and you can download a video to see how to test and determine which heating thermostat or component has failed and needs to be replaced.
Dryer Repair
Mar 18, 2011 | Dryers
It takes 3 cylcles to dry clothes
Heating Element
Cycling thermostat
This is a free answer, Please rate me
Oct 04, 2010 | Miele T1302 Electric Dryer
No heat
mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Feb 03, 2008 | Estate TGDX640JQ Gas Dryer
Dryers Logo
47 people viewed this question
Top Dryers Experts
