Seems to be coming out on top by carb
SOURCE: Kohler Courage carbeurator leaks when engine off.
You need to rebuild the carburetor. You can most likely find a rebuild kit through the manufacturer.
SOURCE: how do i essemble a pull starter on a troy built
to just put the rope in take starter cover off look inside the cover and turn thr pully to the left counter clock wise turn till it turns no more line up the two hole one from the pully and one on the starter cover where the rope was originaly put the rope in thr hole and tie a knot this is called preload has to have tention on thr pully to pull the string back but if thr spring is broke its another process
Frazier
