Question about Brady TLS 2200 Label Printer
Tls2200 codesum E12063
Hi, when i connect my brady tls2200 to the ac power supply and turn it on, appears the codesum E12063 and the legend memory error, i checked it in the users guide finding nothing. would you help me please to find out what do i have to do?
thank you.
2 Suggested Answers
  • 14 Answers
SOURCE: Error message: codesum: C47B72 memory error
Your printer firmware got corrupted or if yu tried to upgrade, it did not complete successfully. Most probably you will have to do a firmware install
Posted on May 24, 2010
Brady TLS2200. I turn it on and get a error CHKSUM
Once again, first thing in a GOOGLE search!
Brady TLS2200 manual
https://www.cableorganizer.com/images/brady/tls2200/manual.pdf
Page 77 error messages
Error in Checksum
The software was improperly installed on your printer. (or lost or corrupted in the memory.)
Contact Brady Technical support group.
Aug 03, 2016 | Brady TLS 2200 Label Printer
Looking for a part number for the internal battery
Hope this helps this should be the part# for battery pack for you label maker P# TLS2200-BP
Jun 10, 2014 | Brady TLS 2200 Label Printer
Brady TLS2200 won't feed labels. no errors.
Turn off the printer and open the printer back door. Use a spot light and look inside properly. Make sure there no paper. Some times a small piece of paper creates the problem. Then after open the back door, top side turn the printer upside down . So if anything is inside it will come out.
After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software (Check if there are any new drivers on the website) .
Feb 25, 2014 | Brady TLS2200 Thermal Label Printer
Unable to print labels
Turn off the printer and open the printer back door. Use a spot light and give look inside properly. Make sure there no paper. Some time small part of the paper creates the problem. So you can do one thing after open the back door, top side etc make the printer upside down etc. So if anything inside that's will come out. After cleaning again connect it with PC and turn on. Now give a look. If you face same problem then Un-install the printer driver and software from the PC. Then restart the PC and Printer both. Now connect the Printer with PC via USB and install again the driver & software. Then try to print and let me know the result.
Aug 09, 2012 | Brady TLS2200 Thermal Label Printer
Camera will not turn on. Already replaced batteries.
as per your camment you already replace the battry thats means no problem in battery Ok Firstly please follw the steps,remove memory card(if have),power resourses like AC power adaptor and batteries and wait some some just about 10 min,than reinsert the battrie and AC power adaptor,swith on the camera without memory card,if it is work and than insert ithe memory card otherwise reinsurt the memory card correctly and close the memory card door properly if the camera working fine other wise follw the third instuction that check the AC power supply,this is connect properly through input or not.connect the properly and turn on the camera and check issue is resolved
If you not find the solution thats means your camera has been damaged,need the service of camera and second resion is if you insert the battry incorrectly ,some issue
One more resion is images in memory card,firstly download ths images in system and formate the card.
Thanks,
Jan 16, 2010 | Sony Cyber-Shot DSC-F707 Digital Camera
Jan 06, 2010 | Brady TLS 2200 Label Printer
The on off button is stuck in. is there anything you can do or do i just buy a new one.
Reset the camera
  1. Turn off the camera, if possible.
  2. If an SD memory card is installed, remove the card.
  3. Remove power from the camera as described below:
    • If you are using only batteries for power, open the battery/memory card door and remove both batteries.
    • If you are using only the HP AC power adapter, disconnect it from the camera.
    • If you are using both batteries and the HP AC power adapter, remove both batteries and the power adapter.
  4. Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the HP AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
Turn the camera on and off. If the issues is not resolved do the following
Connect the camera to the optional AC power supply
  1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
  2. Try turning the camera on.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
If the is not resolved ,then repeat setps 1 to 4 abiove but remove the batteries and keep the AC power adapter connected.
Oct 14, 2009 | HP Photosmart M425 Digital Camera
Errors
I believe this is a checksum error. Most likely the CMOS Button Cell Battery is dead and CMOS
memory is now corrupt !.
Replace the CMOS Battery if less then 3.6V. It is located under the Main Battery.
Then reload the latest software !
Hope this solves your problem
Regards
AZSUNS
Nov 09, 2008 | Brady TLS 2200 Label Printer
Brady tls2200 label printer
Go to setup mode
(Func + Setup Keys Together)
"Printer" is first line of text, Press Enter
Scroll down 4 times using Down Arrow
"Burn Temp" is selected, Press Enter
"Burn Temp is 0?" Using the Up/Down Arrow you can increase/decrease the burn Temperature. +2 or 3 should do the trick.
AZSUNS
Nov 01, 2008 | Brady TLS 2200 Label Printer
Brady TLS 2200 Label Printer Logo
250 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
NOEL
NOEL
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
