Question about Karcher G 2600 VH Gas Pressure Washer
My Karcher, Powered by Honda, High Pressure Spray Cleaner, 2600 PSI, will not pump high pressure. It has a "G 2600 VH" pump
  • 389 Answers
SOURCE: I was using the pressure washer and it stopped
This problem, where the unit continually switches on and off when the handgun is closed, is quite common. Unfortunately it has at least six different possible causes, only two of which are easily checked.
The first thing you can do is look for leaks.  Even the slightest leak will cause this pulsing because the unit gets up to pressure, switches off, loses pressure, switches back on again, comes back up to pressure, switches off... and so on.  This repeated switching is not good for the motor and should not be allowed to continue for longer than necessary to observe what's happening.
So... 1. Does the handgun shut off completely, or does it drip? If it drips, it may simply be because a seal has failed. The handgun can be dismantled, checked, and any defective parts replaced; be sure to lubricate O-rings with silicone grease when reassembling. As a last resort, the whole gun may need to be replaced.
2. Are there any visible leaks at the high-pressure hose screw connections?  If so, most likely an O-ring needs replacing - again lubricate the new one well with silicone grease.
3. If there are no visible leaks, either from the gun or from the connections, all other possible causes are internal within the cylinder head or control head of the pump. New parts will be needed and this normally calls for a professional repair, although it's not beyond the scope of a truly competent amateur.
I hope this helps. Any further questions, just ask! Please remember to rate this response.
Posted on Apr 17, 2009
  • 2692 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
  • 104 Answers
SOURCE: My Karcher high pressure sprayer is delivering intermitant pressure.Every 15 seconds or so it developes high pressure for only about two seconds. Why is it not delivering a constant high pressure stre
Check that the water supply is constant , it sounds like the pump might be pushing out more water than can be delivered , or it could be a dirty inlet filter
Posted on May 23, 2009
  • 548 Answers
SOURCE: I have a 3000 psi karcher pressure washer with
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
Posted on Sep 15, 2009
  • 61 Answers
SOURCE: troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Posted on Sep 20, 2009
Grey oil leak and no water pessure
depends on where the oil leaks from , normally a cloudy or "grey" oil sheen ,oozing out from here and there doesnt consern me too much , but now the oil running from the big hole or crack in the housing now that conserns me , make sure unit is "primed" with water (small flow from tip with motor off but hose turned on) if still no good then cycle your unloader a few times by tunring the pressure adjustment all the way up and all the way down with water on and motor runninng , this should work unless you have a larger problem
Feb 20, 2015 | Karcher G 2600 VH 2600 PSI 2.3 GPM 161cc...
No pressure...new pump
Gun could be the problem if you hear the engine pick up speed and you can feel the pressure on the hose.if engine speed doesn't increase than there is a governor issue with the engine.
Oct 03, 2014 | Karcher G 2600 VH 2,600 PSI Gas Pressure...
How can I stop the siphon?
Are you using the black nozzle? Switch to a different nozzle. If you are not using the black nozzle the siphon fitting is bad.
Sep 24, 2014 | Karcher G 2600 XH 2600-PSI Honda Gc190...
How do I fix a Karcher 2600 PSI pressure washer has water in oil..
you mean water in the pump oil ??? or engine oil ???
im suspecting pump oil... you didn\'t seal it properly or you have a crack somewhere in the main housing. rarely is it viable to repair these pumps... if you search a little you can find replacements pretty damn cheap !!!
Aug 09, 2014 | Karcher G 2600 VH Gas Pressure Washer
My honda excel 2600 psi pressure washer do not have any pressure when i squeez the trigger
Trash in, worn or damaged inlet and outlet valves are one possibility. Unloader valve stuck open or badly worn would also cause low pressure. Wrong spray nozzle size is another. Is the nozzle the right size for your pump?
Is water leaking from under the pump? That would show worn high pressure seals.
Apr 13, 2014 | Garden
IT HAS PRESSURE BUT IT PULSATES INSTEAD OF STEADY SPRAY
I have same model with same problem. Tried the easy fixes:
unloader valve lube and clean, inlet water sufficient, and nozzles and hose are fine. Broke down pump and called for parts (about $50 for 3 inlet valves and some seals) hopefully this will fix it. Mine has been used in my business pretty hard for a few years, so not bad.
Joebro
Jun 11, 2011 | Karcher G 2600 VH Gas Pressure Washer
Karcher G2600 VH - low water pressure
If the spill valve activates is "spills" water under the washer. There is a restriction or the pump has become inefficient and will not pump the volume and pressure it should at full RPM.
Jul 20, 2010 | Karcher G 2000 MK 2000 PSI 20 GPM 87cc Gas...
No spray
I have a G 2600 VH psi which isn't listed here, I have need to order a part that isn't listed, this part goes into the detergent tank that monitors the difference between types of nozzle is attached to hose, what is it call?
Jul 06, 2010 | Honda Maxus Pressure Washer MX5222
OUR KARCHER 2600 PSI PRESSURE WASHER W/ HONDA ENGINE WON'T START. WE BOUGHT IT A SAM'S CLUB LAST YEAR AND PROBABLY HAS ONLY BEEN USED ABOUT 4 TIMES. PLEASE ADVISE.
Hello:
Have you tried changing the gas, Especially, if it has been in the machine of a while. Also some Honda engines will not start if the oil is low. Also try removing the high pressure hose before you start it? Do not run it very long without water flowing through the pump, though.
Sep 20, 2009 | Karcher Garden
Not getting any pressure at nozzle.
Can anyone Solve this? My simoniz S2500 gas powered pressure washer has low pressure coming right from the outlet. It used to be high pressure until now.. I think it has something to do with the pump and if so, is there anything I can do to repair this problem? The screen is good; water comes out of the hose good, wand is ok......Just that lower pressure is at the wand even at high settings....It comes in a form of a spray in both modes......
May 17, 2009 | Honda Water Pump 2 Inch IntakeOutlet 5 Hp...
Karcher G 2600 VH Gas Pressure Washer Logo
494 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
