Question about Posiflex PP7000 Printer
Posiflex pp7000ii not printing in margins
Is there some sort of set up to get my printer to print in the margins of the printer head.
thanks
  • jeffstorer May 14, 2009
    The link you gave is for a monitor , not a printer
    margin setup for a posiflex pp7000ii printer
  • 952 Answers
My cousin have the same exact thermal printer. There is no way for you to do this. Some devices have limitations. Sorry man.
Posted on May 14, 2009
  • 483 Answers
I think its in the manual as i looked it up.
http://www.atol.ru/download/documents/pos_per/monitor/posiflex/tm7115_um_eng.pdf
Check that out.
Thanks
Fame !
Please can you say me how to set correct margin size for Printer Zebra Xiiii plus
choose the "View > View Options" Menu with the BT document open and now enable the "Show Unprintable Region" checkbox. Will you now see the unprintable width margins covering part of the left margin of your label? If yes, then this means that due to the unprintable width of the printer you cannot print on this are (this the related to the printers print head tolerance).
With regards to the not being able to print on the bottom side, this could be a page setup issue. Please attach your BT document to this forum topic by using the "More Reply Options" button.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Techsupport Printer
Feb 26, 2014 | Zebra Xi Series 140Xi4 - label printer -...
How to realign prints
Hi!
Go to printer settings in Control Panel and print a test page and do head cleaning cycle for the nozzles.
Hope this helps
Nov 04, 2011 | Epson STYLUS R230 InkJet Photo Printer
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
How can we set margin in posiflex pp8000 partial cut v3.01
a beep sound when i connected the posiflex pp8000 v3.01printer to my pc and also papper out inticator is glowing. what i do to solve the problem ?
Nov 24, 2009 | Posiflex PP7000 Printer
Need USB-SERIAL PORT settings for POSIFLEX PP-7000II printer. It is printing garbage on standard COM port settings
Aug 15, 2009 | Posiflex PP7000 Printer
Printer not printing margins correctly
Set the margin unit of measurement to whatever you find most useful: inches, centimeters, millimeters, points, or picas.
  1. Choose File > Options > Advanced.
  2. Under Display, in the Show measurements in units of box, select the unit you want.
Mar 24, 2017 | HP Office Equipment & Supplies
My printer prints pale inks on the margins
If it is Laser Printer then you need to replace the DRUM in Cartridge or need to replace the cartridge. Incase if it is InkJet printer you need head cleaning. Else replace the cartridges.
Thanks & Regards
Nandu :)
Mar 16, 2009 | HP LaserJet 1018 Printer
Tally T2240/24 Printing Problem
When you changed the ribbon, it is more than likely that the print head is out off position and the printer needs to find its home position again.
To get the printer to find its home position again power the printer OFF and back on again, the printer will then check the position of the print head and set the 'home possition'
You can set the left margin on the printer by simply moving the paper in the printer by unlocking the tractors and sliding them in the required direction.
Oct 28, 2008 | Tally T2240/24 Matrix Printer
How can I print without margins?
You may all you need to do is open the properties of the printer and check that there maybe a setting that says margins or you are looking for edge to edge printing. Check that then you should be able to print without margins. Also within MS word click file then page setup and check the margins in that as that can also cause your fault.
Hope this works
Thanks J
Jan 08, 2008 | Samsung CLP 300 Laser Printer
Posiflex PP7000 Printer Logo
303 people viewed this question
Top Posiflex Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Posiflex Office Equipment and Supply Expert? Answer questions, earn points and help others
