Question about Whirlpool MH6150XL Microwave Oven
Over range microwave not working properly
Power is ok. Interior lights work, control panel lights up, accepts time settings and turns on, turn table functions. NO HEAT!
  • 1 more comment
  • Anonymous Dec 23, 2007
    Lights on, Turntable won't turn and no heat.
  • crossfire969 Aug 04, 2008
    all systems work, but no heat and it makes a weird noise and begins to smell like something is burning or getting hot.
  • Anonymous Mar 23, 2014
    Turn table and light OK does not heat
  • Whirlpool Master
  • 9,098 Answers
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
I have a GE JVM 1870 over the range microwave with the active vent. The interior light is out which is a simply fix. How to I get to it?
follow this steps and fix it. God bless you
  1. Light bulb If your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control board If your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Dec 09, 2013 | Microwave Ovens
My microwave heats, but the surface light and interior light don't light up and the turn table doesn't rotate. Everything else seems to be working fine. What is the best way to trouble shoot the problem?
  • Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#6#ixzz2gUUt9D8f
    Sep 30, 2013 | Microwave Ovens
    The motor will not work. The interior light comes on, but the turntable does not go around. The cook time counts down, but no cooking occurs.
    the turn table motor could have failed, but the counting down will be the monitor switch or a micro switch located behind control panel
    Feb 24, 2011 | Amana ACO1860 Microwave Oven
    GE model J KP85B0A3BB over range will not heat up. Both control panels for microwave and range work, interior light comes on when door opens, and glass plate will turn...
    The most likely problem is the magnetron, it works with the high voltage capacitor and diode which can be a factor. The three work together to generate the high voltage that heats the food. If the repairs are done by a professional the cost will be high when you consider parts and labor.
    Feb 09, 2011 | General Electric Microwave Oven
    Turn table does not turn when heating. Interior light does not come on during cooking, works fine when door is opens.
    some microwave is have PCB control if pcs is shorted some parts light bult,fan or syncronus motor is on mode we need to replace the pcb but some problem is only is micro switch,if mocro swict is rusty or corroded that the time not working the turn table,but you said every time open the door the ligth is ok,if the turn table also running during open door have problem in your pcb board that we need for replacement,but check the price of parts and make it desicion if you want to repair or buy a new one if your unit is very old.
    Dec 28, 2010 | Microwave Ovens
    My control panel will set for time other functions will work and and light and fan time will reset but will not turn. on noticed that the door sags and the upper prong that keeps it closed is broken off....
    due to the fact that micowaves produce extreme amounts of high range rayons the units are constructed with several safety features one of the main ones being twin micro switches built into the door latching. when the door is open it sends a signal to the microwave to stop working so unless both latches are in place and strike the switches the unit will think the door is open and not respont to cook. you will have to have the door latch replaced parts are available form www.kenmore.com as well as ebay and as close as your local reapir shop.
    best of luck
    please take the time to rank this reply
    thank you and merry christmas
    Dec 07, 2010 | Kenmore 80599 Microwave Oven
    Control panel not working
    If "control panel not working" means no display, clock not on, etc. but the interior light comes on when the door is opened(power is being received and transmitted from transformer\rectifier) I would check to see if power is being received by control panel(with a multimeter, checking for voltage at the input terminals). If it is receiving power but not working, the "repair clinic" on the internet is a great place to look for replacement parts.
    Sep 20, 2010 | Maytag Appliances Over-the-Range Microwave...
    Samsung microwave -the electrical panel runs, the
    it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
    Nov 14, 2009 | Samsung MU3250W Microwave Oven
    Whirlpool MH6150XL Microwave Oven Logo
    151 people viewed this question
    Top Whirlpool Microwave Ovens Experts
    William Miller
    William Miller
    Chuck
    Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
