USB DRIVE hi there my mac won't recognize that my samsung HM120IC usb drive is connected, it works fine in a friend's laptop but not mine. i have checked the usb ports with other devices and they work fine.the system that i'm running is 10.4.10so technically everything works fine but they just won't talk to each other- help!
  • 132 Answers
You did the update ver 1.1?  This is suppose to fix the mounting and unmounting of external USB devices.  Sounds like it never unmounted.
Posted on Oct 17, 2007
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
SE-084C Won't work on mac is there a soultion to this?
According to the samsung website the SE084C it can be used with a mac see
Are you using it via a usb hub or is it plugged directly into the usb port of the mac. As it is powered via usb, on the hub it may not have enough power getting to it, so plug it directly into the usb port. If you already have it plugged into the usb port change the usb port and finally check that the usb cable is working, if it isn't change it. Hope this helps.
Jan 08, 2012 | Computers & Internet
Hello, I just bought a Samsung Home Theater HT-D5500, I connected it a WD External Hard Drive but it is not recognized, I tried with USB memory and it was detected without problems. My WD HD is detected in...
I am having this problem too. I have a lacie stark 1TB hard drive for my mac and nothing happens when I connect it. iPod works fine. But the hard drive. Nothing. Any help would be great.
Sep 18, 2011 | Computers & Internet
I bought a hitachi external hard drive for mac, 250 g. when i first used it it took a long time for it to be recognized. On pc it works fine, but on my mac it won't get recognized anymore. (the hard drive...
Your problem could be any one of these issues:
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Jan 01, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
My WD External hard drive is no longer recognized by my Mac. It was fine when I went to bed. Showed no warning symptoms that I am aware of.
I would like to know the way the Drive is connected to MAC.
Have you connected it using USB or Firewire ?
If you have connected it using Firewire, Try connecting it using USB 2.0 Cable.
Let me know.
Dec 10, 2010 | Western Digital 4TB My Book Studio II Hard...
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
USB flash drive not recognized by Macbook Pro
hi im josh in cebu phils. if that happened that the usb port don't detect your usb drive then there maybe some problem in your pc. friend all you have to do is check first the usb connections of your can browse the my computer device manager then click the usb icons and see if marked + or 2nd you reboot your pc then go to bios setup utility then go to peripherals then check wether it is enable.if disable usb on board you enable it. and don't forget to save the changes you made before you exit. then reboot your pc. then problem will be solved. good luck please vote me so that i will know if i helped you.thnks
Feb 23, 2009 | Apple MacBook Pro Notebook
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
