Question about DeLonghi Caffe Elite DC77TC Coffee Maker
Power problem When I turn the machine on I have a red light but no heat to the core.
  • 709 Answers
Hi s_fowler,
Your heater fuse may be blown.  You have to look on the bottom and remove screws to access. To chack a fuse you use a Volt ohm meter, and set it to measure ohms or resistance. The fuse will be install in a wire leading to the heater.  It may have shrink tubing around it. You will have to pierce the shrink tubing to get your leads to touch the wire on both sides of the fuse.  If your meter reads -1 or OL, the fuse is blown.  If your meter reads less than 1 but more than 0 your fuse is good.  If your fuse is good, you will need to test the heater.  The heater is located under the canister plate.  Only 2 wires exist going to the heater.  Disconnect the heater wires to open the circuit.  Using your Volt ohm meter, Measure the heaters resisitance. This is done by putting a lead on each of the wires leading into the heater assembly.  You should measure between 2 and 20 ohms.  If your meter reads -1, or OL, then theater is burned out. Depending on what you find, the place to get parts is www.repairclinic.com.  I believe they have the part your need.
Please click on Solved, as this is you only time you will be able to vote.  I have put a lot of effort into give you a free tip, so please click solved either way.
Posted on Oct 16, 2007
Green power light only on trevi exclusive
When power is turned on, the coffee selection button should blink during warming up. If it is not blinking then the following i possible:
1- The electronic sensor is bad. It is clamp mounted on the boiler to sense temperature and send message to control board to turn the heating off when it is ready to make espresso. The blinking light will be fixed to display this.
2- The heating element on the boiler is bad and not heating. The electronic sensor cannot relay any temperature as it is.not sensing the heating.
3- The electronic control board is bad and not sensing the temperature.
The machine should be opened up to test the sensor or the neating elements, and replace what is bad..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Aug 31, 2014 | Spidem Trevi Automatic Espresso Machine
Turn on power to heater & nothing but the power light comes on, please help
There's a heater core box where radiator coolant passes through. When you turn on the heater, the fan on the heater core box blows air through the core, then the air is heated up and it passes through the air ducts, which leads to the windshield defroster, the vents, or your feet depending on where you set the control. If you're not feeling heat, either the fan on the heater core box is not working, or there's restriction on the coolant hoses and hot coolant isn't passing through the heater core box. Remove and diagnose the heater core box to ascertain the coolant lines are not blocked and the fan is fully operational. If the heater core box is OK, then the hoses have restriction to prevent hot coolant from passing through the heater core box.
Nov 26, 2013 | Plymouth Voyager Cars & Trucks
I have Accer Mini tower with dou core 3.0 processor i remove the cpu fun with the heat sink to add oil to the fun and a return back properly i didn't touch any thing but after i turned on it , the fans...
Hi
Before your computer running fine, you just remove the fan and heat sink, and fix properly.
1) Check your VGA cable both of side fix properly
2) Check your Monitor power button is switch on.
3) Remove your RAM and fix again.
May you fix your problem
Jun 01, 2011 | Acer Veriton M460 Micro Tower Core 2 DUO...
No water/coffee comes through? the temprature indicators doesnt light up?
The POWER LIGHT for the 889 is RED and located on the LEFT of the center cowling
The BOILER LIGHT for the 889 is YELLOW and located on the RIGHT of the center cowling
If you turn on the power to the unit (the INNER SWITCH on the RIGHT SIDE) the RED light should turn on, showing that the machine is powered. At that point the YELLOW light should also turn on for about 10 seconds, at which point it will turn OFF with an audible CLICK.
If the RED light does not turn on then you have a very dead machine.
If the RED light does turn on but the YELLOW light does not then you have a half dead machine.
Opening up and repairing the 889 is not for amateurs. High voltage, heat and pressure inside.
If you decide to bin the machine I would appreciate getting the drip tray from you as I have lost mine.
Graham Leach
Sep 05, 2010 | Dualit Espresso 889 Espresso & Coffee...
Red boiler light will not go on. The boiler does heat up.
Open the steam valve when you turn the machine on that will vent out the boiler, keep it open until it starts to hiss slightly and produce small steam bubbles, then close and machine should heat to temp. If that solves your problem then the vent valve needs to be replaced, until then you can turn using the steam valve open trick.
May 31, 2010 | Isomac Tea Espresso Machine
I was playing the bigs 2 when suddenly my ps3 started to shut off.I turn it on again it wont turn back on.The red light just keep on blinking.
Turn the PS3 power off via the switch on the back.
Hold the power button on the front of the machine down for about 15-30 seconds.
Then, without letting go of the power button on the front of the machine, turn the switch on in the back.
If it still doesnt come on then you may have serious problem with PS3 in which contact Sony or the retailer you bought it from for exchange or rapair.
Jul 27, 2009 | Video Game Consoles & Games
Problem of red light flashing
I saw a 360 do the same red ring one time when the power cord wasn't completely plugged in to the back of the console. Check and make sure all of your connections are good and tight. I hope this helps.
Dec 05, 2008 | Microsoft Xbox 360 Console
SL 90 Machine not heating
Hi There are 3 things that could be the problem. 1. The power board on the left rear inside. 2. Heating element is burnt out. Replace the top part of the boiler and order a brew head gasket and replace it at the same time while you have the machine apart. 3. and less likely is the temperature sensor. 2 red wires goes from the board to the top of the boiler.
Nov 16, 2008 | Solis Crema SL-90 Espresso Machine
Power light on, no warning light, doesn't heat up at all
Your resettable thermostat turned off the high power heater circuit and the red warning light. The heater got too hot when the boiler became empty of water. This is to keep the heater from burning out if the boiler becomes empty. To reset the thermostat, turn the micro casa a leva over. There is a yellow plug near the center of the bottom which is easy to pry out. Stick a screwdriver, pencil, toothpick, chopstick or whatever else is lying around into the hole and gently reset the thermostat button. You will hear a click when it resets. You are then ready to go.
Jan 04, 2008 | Elektra micro casa a leva S1CO Espresso...
DeLonghi Caffe Elite DC77TC Coffee Maker Logo
148 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
