Not getting full audio signal
I have a realistic sta-64b receiver with a pair of matching speakers. I'm running RCA outs to each speaker but there is only one RCA in on each speaker-- so I've had to choose red or white for each speaker whereas I have both red and white for L and R coming out of the receiver. how do I set this up righT?
    Master:
  • 796 Answers
You only need one red from the receiver to reach the right speaker and one white from the receiver to reach the left speaker. You say you have both red and white for L and R coming out of the receiver, are you sure? Because all red ouputs are RIGHT and all white are LEFT. I think you have 2 white and 2 red. One of the white is for a front left speaker and one for a rear left speaker. You need to connect to the one for FRONT speakers.
Posted on Dec 15, 2013
3 Suggested Answers
SOURCE:
SOURCE: Receiver Realistic STA 2700: no sound / signal argggh
Sounds like a power supply issue, maybe the transformer when bad, it may need replacing.
Posted on May 16, 2008
SOURCE: 4 ohm connection for realistic STA-64B
I have a pair of Cerwin Vega 123's as they are 4 Ohm BUT just one pair only as this will have your amp working harder!!!
Posted on Nov 08, 2011
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up? Thanks.
The Jensen JS650 does not accept line level input so you need to use the Front B speaker output from your Sony receiver and not the RCA subwoofer output. Even though your subwoofer is active, it does not support line level (RCA) signals.
Just connect the subwoofer as you would a pair of speakers. Once connected, you make sure the front panel speaker switch on the Sony is set to A+B so you get sound from your existing speakers (A) and subwoofer (B).
I hope that works for you.
Feb 15, 2015 | Sony STR-DE597 Receiver
How do I connect Active speakers to my Denon 3805 AV receiver?
Your Genelec 1037C monitors are professional design with balanced inputs. Balanced inputs expect a low impedance signal with pin 1 earth, pin 2 hot and pin 3 cold. Because the Denon amplifier supplies a pre out for the front speakers (the first pair in the set of pre outs) at 1.2 volts and high impedance, you will need to convert the signal close to the amplifier with a stereo active DI box. Plug the pre out directly into the input of the DI with a SHORT lead and then plug two standard balanced microphone type cables ( XLR to XLR) into each of your active monitors. You cannot make a cable that is RCA to XLR by shorting pin 3 to earth to do this job properly. The inputs on your Genelecs expect a signal in the range -6dBU to +6dBU for rated output. A suitable DI box would be for example a Klark Teknik DN200. Hope that helps.
Cheers, Don.
Dec 06, 2014 | Denon AVR-3805 Receiver
Sound
Your TV has a pair of analog RCA Audio Outputs on the back of the set. They are the red and white, female, round outputs and should be labelled as Audio Out. If you have a surround receiver or stereo that accepts this type of input (most do), then you would purchase a stereo RCA audio cable that has the red and white male ends on both ends of the cable and plug them in to the appropriate stereo RCA left and right channel audio inputs on your receiver and the aforementioned outputs on your TV. The same is true if you have a pair of self-powered computer speakers (or similar). If your external speakers or audio systems don't have the RCA inputs, you may need to get an adapter to convert the RCA output to stereo mini-jack (or similar) to match the appropriate input on your external speakers. Does that make sense?
Apr 14, 2014 | Sceptre X322BV HD 32 inch Class Television...
My Realistic STA-2380 Receiver SHUTS DOWN
Try disconnecting all the speakers and see if the volume goes up without shutting down (watch the vu meter on the front) if it goes all the way up without dropping, you will need to check your speakers. If the speakers are drawing too much current then the system will go into shutdown(protection mode)could just be a bad speaker. Secondly try blowing out the receiver with canned air and removing anything that would obstruct ventilation.(ie; another device sitting on top of it or in a cabinet where it can not breathe.
Feb 15, 2014 | RCA Audio Players & Recorders
How many amps is my RCA Sta 3850 am/fm stereo receiver and where would I find a fuse for it also what exactly could be making the fuse blow out?
I would like to purchase a Realistic STA-3850 AM/FM Stereo Receiver, anyone that would like to sell, please contact me at my email address: [email protected]. Thank you-dave
Mar 24, 2012 | RCA Audio Players & Recorders
I purchase a denon AVR-591 & now i am using speakers from a kenwood home theater system but know all of the speakers work except the subwoofer does not, know the swbwoofer input has a wire Plus Minus...
Take a clue from the bare wire speaker connections on a speaker not matching RCA connectors. RCA is not for feeding +/- speaker terminals on REAL audio equipment.
The Denon requires an active (self-amplified) subwoofer which it feeds a specialized Low Frequency Line Level Pre Out signal.
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/denon/avr591.html
Disassembling the parts of HTS and reassigning them to other makes and models is unwise and unpredictable electrically and sound-wise.
Feb 26, 2011 | Audio Players & Recorders
Service manual for realistic STA-2080
I have a sta-2080 realistic receiver and wide range frequency equalizer plus a tape deck sct-22 all realistic.My problem is when i play the tuner or cd player witch is connected to the aux
the volume goes soft and then loud with a lot of cracking sound now ther is hardly any volume.when i play the tape deck it has it own volume control every thing is good so what parts do i need. thanks corneil
Nov 22, 2010 | Audio Players & Recorders
Bose 901 Hook up help !
The use of 901's in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor.
That is because if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. However, you can still draw the Front Left and Right signals out of any Pre-Out (with a Y-cable set, looping the Pre Out directly back to the Main In) or Tape Out jacks (remembering to NEVER activate that monitor on the receiver), go into the Active EQ's Amplifier Connections; then Out of the EQ's Amplifier Connection to a separate amp and attach the 901's to that amp. This way you won't introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them. On many, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others, you may have to borrow the signals from a typical Tape- or Adapter-Out RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won't have to switch IN. The signal Out is always there regardless of the monitor state.
The AV Receiver can still drive the Center, Surrounds and the Sub(s) as it is designed. This is how mine is wired.
Come to think of it, you could still have conventional Front L&R speakers on the AV Receiver, but why? Maybe one would prefer the 901's for music and some other speakers for surround. Level matching with the 901's to conventional front speakers would only be possible if the separate amp has its own volume, but it would work. Maybe I'll try it someday. None of my current amps has a volume control.
Oct 22, 2009 | Bose 901 VI Main / Stereo Speaker
Apr 15, 2009 | Audio Players & Recorders
Sep 27, 2007 | Audio Players & Recorders
44 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
