Question about Dell Dimension E521 PC Desktop
Dell Dimension E521 bad sectors
We purchased a DELL Dimension E521 around 2007 and now am on 3rd hard drive. Each time I install a new one, it works for a little while and then suddenly develops bad sectors or unreadable area.
What is going on here???
Hard to believe I can get three bad hard drives in a row in under 2 years.
  • Anonymous May 14, 2009
    It was two Western Digitals and one Seagate drive that developed bad sectors.
    I am wondering if something about the computer itself is causing this.
  • Dell Master
  • 4,806 Answers
Hi there.
Hard to believe but this can be common depending on the manufacturer of the hard drive as some are not that good at all, some Maxtor's for example.
The best hard drives you can buy at the moment are Western Digital and Seagate, these drives come with 3 - 5 years guarantee so if they develop bad sectors they will replace the the drives free.
The best way to look after your drives is to perform a sector check once a month and keep your internet cache cleared, use a program called Ccleaner to clear the cache and temp files and also keep the registry clean.
I would also recommend you defragment your drive as soon as you have installed a clean operating system or defrag once a month too, that way you will get your full life from the hard drive.
Get Ccleaner here >>>>>>
http://www.filehippo.com/download_ccleaner/
Good luck and thanks for using FixYa!!
Posted on May 14, 2009
How do i reformat my dell dimension e521 computer
The easiest way is to boot from the Windows installation CD and select format hard drive.
Jan 17, 2012 | Dell Dimension E521 PC Desktop
My dell dimension E521 desktop. I installed a new hard drive on my I installed windows xp os instead of the windows vista os that the pc came with, it installed fine, drivers disk wouldn't work so I had to...
Please go to the Dell website again. You should be looking for a LAN driver. Make sure that you are downloading drivers for Windows XP.
If that doesn't help visit broadcom website.
Feb 03, 2010 | Dell Dimension E521 PC Desktop
MY DELL DIMENSION E521 WONT BOOT WINDOWS AFTER STARTING UP, I WAS TOLD THAT THE VIDEO CARD COULD BE BAD, WHERE IS THIS LOCATED IN MY PC AND CAN i USE ANY VIDEO CARD TO RPLACE THIS?
Hello, if you were told by an expert tha you need a video card, here what you need:
1: You do not have a slot card type video card in your system( Dimension E521) your system has on board video, which you can not remove from the system but disable it.
2: Your system has PCIe x16 slot that can be used for new video card.
3: Link below will give you a list of PCIe x16 video cards, you can pick and choose according to your needs. Do you need DVI (digital connection, does your monitor has a white port in the back or just the blue one?), or regular VGA (blue port) is enough, do you need HDMI etc...
bottom line is any of those video card will work.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=40000048%201069609641&Description=pci%20express%20video%20card&name=PCI%20Express%20x16&ActiveSearchResult=False
4: I am assuming you have never done this before so before you open up computer and start taking things apart go to the link below and download service manual for Dell Dimension E521 ( I selected the model for you so you don't have to look for it :-) )
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/index.htm
5: In the service manual link there are several Sections like:
Before You Begin
About Your Computer
Technical Overview
Specifications
Advanced Troubleshooting
System Setup
Removing and Installing Parts click on each one and read about it first to familiarize your self with the system.
6: Once you feel confident enough remove the power cable from from computer.
-> open computer cover
-> follow instructions in service manual under
->Removing and Installing Parts
-> Cards
->PCI Express Cards
-> Installing PCI express card.
-> Close computer cover
-> plug monitor cable to new card
-> power on the computer
-> if Picture quality is bad that means card was not properly recoginzed, install drivers from the CD that came with the video card.
I hope this helps, if you get stuck at any step or not clear feel free to post back.
Kind Regards,
Amar Sondhi
Feb 01, 2010 | Dell Dimension E521 (D10E16) PC Desktop
My Dell Dimension E521 won't start up and has a flashing 3,4 code.
Can you check your bios page on startup? Do you see anything on the screen when you first powerup? If you see nothing and only get the flashing lights you may need a power supply.
You may also have a bad HD or perhaps loose memory chips.
You can start by checking the bios for an installed hard drive and memory. If you see those and then it stops booting. Check the power supply.
Dec 09, 2009 | Dell Dimension E521 PC Desktop
Hard drives keep getting bad sectors on computer. I replace a drive and the new one gets bad sectors. I installed a PCI PoOST Diagnostic Test Card and it revealed error ''E4'' which says ''Check for forced...
Ok there be something you are doing that is making the hard drive go bad. And as I know when you buy a new hard drive they usaly have a 3 yr warrent I would go to the website of your hard drive and put in serial number and see if there is a warrenty. if you need any more assistance email joegoetz16@gmail.com
Jun 04, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Computer not booting up
What are the service lights doing on the back of the PC, two green two yellow, should be something to this affect,4 lights. Try your install again and see what the lights are doing when the error appears. Now take your service tag and go to dell.com.
and see what the error lights means.
Remember Xp is the only operating system that can be run on this pc.
If it was a hard drive problem,the last thing you do is try to install a OS, you get a hard drive diagnostic disk from dell, or get HDD regenerator
1.5.1, its free, it checks the hard drive for bad sectors and can repair them,so you can get your important info off of them, because if it had bad sectors, the problem will just come back. So its better to get a new one.
Mar 21, 2009 | Computers & Internet
Install 2nd Hard Drive in a Dell Dimension 8400 Computer
all u do is make your new hard drive the master by setting the correct jumper for it the manual will tell u more. then make the old drive a slave. install yr opreating system it should be installed in drive c: thats the master when done, u do yr normal copy and paste to transfer your files from old drive to new drive.
xerick
May 22, 2008 | Dell Dimension 8400 PC Desktop
DELL PART # DN804 For E521 computer
Hi
Dell Part # DN804 is PCI-e ATI Theater 650 Pro Combo Analog/Digital TV Tuner and it is compatible with Dell Dimension E521.
The ATI Theater 650 Pro PCI-e card is available in two form factors - Low Profile or Full Height. Dimension E521 is compatible with Full Height cards only. It is important that you ensure the you receive a full height card.
Check Installing a PCI Express Card for help installing the hardware. Next install required software/drivers.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/parts.htm#wp1080274
Mike
May 03, 2008 | Dell PART NUMBER CARD NTWK PCI TR IBM 16/4...
Dell Dimension E521 PC Desktop Logo
199 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
