Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Power steering on john deere 750 works intermitttantly
Works ok sometimes and then suddenly no assist when turning left
  • 246 Answers
Hello mudvane420:
>>I have Found this Problem to be Caused by a Worn or Sticking Components in the Steering Control Unit or Dirty Fluid.
>>If the Fluid has Not been Changed, then Change the Fluid ( I Usually Flush the System. I have a Special Unit that I Use, but you can Simply Purchase Extra Fluid and Filter (if applicable) and Change the Fluid 2 Times Instead of Once) and Cycle the Unit for a Minute or 2.
>>The Cleaner the Fluid the Better and Longer the Steering Operates.
>>Operate the Unit for 1 Season. I Say 1 Season for you Because the Problem is Not a Constant, it is at Different Intervals. Usually for your Problem, the Fluid is the Cause and New Fluid Corrects this Type of Steering Problem.
>>If the Problem Presists, then Disassemble the Steering Control Unit and Replace All the Components Listed.
>>Usually, if the Person has the Common Shop Tools; Plus Snap Ring Pliers and a Vise, they can Disassemble the Control Unit, Clean and Rebuild (Purchase the Service Kit for your Specificate Steering Control Unit) it with Little to No Problems Using a Breakdown of the Steering Control Unit.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
Does anybody know why steering column doesn't lock on a 5325 john deere tractor?
Its likely worn out.The key switch could be working fine but their is a pin that locks the column spring loaded that maybe worn or damaged or the column tube that receives the pin .
As long as it runs OK and the steering wheel turns its not going to effect anything else but the steering lock .
Oct 28, 2016 | John Deere Garden
My steering on my 790 john deere tractiior wont work
ck your hydraulic oil tank level ? if ok ck that your three point hitch moves up/down ? this model uses the tractors hydraulics to steer , testing these things first helps to identify a bad steering valve
Sep 14, 2015 | John Deere Garden
Myjohn deere 850 will not steer
if it has power steering then you should check the that the power steering well is full and that the belt drive is ok
Jul 04, 2014 | John Deere 650 750 850 655 755 855 955 670...
Steering is loose and slips on my John Deere LA140 is it hard to fix
The steering gears are striping out. There are two gears that mesh to steer unit.
May 06, 2014 | Garden
John deere hydro leak ay steering column
Robert,I had the same problem with my 855.I repaired the power steering unit with replacing the seals provided in a kit. Part No. AM 107078The power steering unit is made by Parker Hydraulics. You may go to the web site, refer to HGF service Manual for proper disassembly and assembly. Have a look as what is involved to replace the seals.The removal of the power steering unit from the tractor is quite involved.The replacement of the seals is also tricky as you must open up the unit.If you are not a seasoned mechanic, this repair may be tricky.
Nov 28, 2012 | John Deere 650 750 850 655 755 855 955 670...
I have a 750 john deere oil is in the radiator and is over heating. how can i fix it ?
Sounds like a rebuilld is in order. You probably have a blown headgasket or worse warped heads permitting the oil going into the cooling water. This work is best left to a shop with proper tools.
Aug 02, 2012 | John Deere 650 750 850 655 755 855 955 670...
My John Deer 1020 turns fine to the left but when turning to the right the power sterring does not work. It seems to me an intermittant problems. Occasionally the sterring is fine but most of the time it...
open hood to get to top steering gear check for lube and check adjuster worm gear known to crack or break a gear tooth than check thru view plate opposite of the steering cylinder which is connected to the rack&pinion make sure timing marks line up may have skipped a tooth or the thrust pad(shims) have shifted
Oct 30, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Wheel turnd left OK Wont turn right, Get loud
THE GEAR ON THE SHAFT IS STRIPED OUT NEEDS A NEW ONE
Sep 05, 2009 | Garden
John Deere riding mower SRX95 - Steering wheel is sticking
You need to replace your Ball Joints! On the front steering rods There are two sometimes three !
May 08, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
422 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
