SOURCE: isuzu trooper problem!with a 00 3 litre diesel engine not starting
Was it lined up right as the trigger point for the sensor is important.Is the fly wheel fitted one position only that the bolt holes line up or will it fit no matter which position it bolts up Line up the flywheel trigger with the sensor after you have put the engine to Top Dead Centre.Put at tdc and see if the trigger and sensor are together.
SOURCE: 4 wjheel drive problem
not transfer case motor....there is none on a rodeo....trooper has torque on demand.....rodeo problem is likely shift on fly mtr...mounted on front axle....if u dont use 4wd regularly it sticks and gets stuck.
SOURCE: renault clio
check your carbaretta take it out and give it a good clean also check your petrol fuel pipe it sounds like you have a block somewhere
SOURCE: engine revs go high when changing gears but loss of power on MAGN
throttle body shaft seals are worn do a boost leak test and you will hear the leak
http://www.cobbtuning.com/info/?ID=3481
