Question about Yamaha Emx88s Powered PA Mixer System
Yamaha EMX 512SC - playing an outside show - configuration
Would it be better to daisy chain 2 speakers per side, plug all four in directly, or run 2 speakers off the amp and run the other 2 off the line out through a second amp.
My speakers are all 8 ohms.
thanks
Jim
  • essknapp May 14, 2009
    Battery?
    Makes no sense to me.
    Even though using just the Yamaha would bring the speakers down to 4 ohms and the wattage up to 1,000?
    President:
  • 788 Answers
If you are looking to run stereo mode you will have to run 2 speakers per side and daisy chain them. As you know by putting them in parallel they will raise the impendence of the speakers, so some of your system setting will change, mostly the volume and maybe the balance. You can get those tuned in pretty easily.
The Yamaha system will be able to handle this set up but you will have a lot more sound this way. Just watch out if someone cranks it up too high.
If you don't want stereo sound or need it, then you can hook this system up with all four directly plugged in to the amp. This will raise the impedance and you may not get the power that you are looking for as the amp will not be loading.
You have some options, if this is a big outside show; I would defiantly hook up the second amp option to get the most sound out to the crowd.
Hope it goes well!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for your support
Posted on May 14, 2009
    Brigadier General:
  • 3,917 Answers
Hey,
Looking at the 8ohms speakers you have with 4 in total , its always good to run 2 speakers off the amp and run the other 2 off the line from the second amp. The reason for advising so is better effeciency of the battery and performance.
Thanks
  • e-Guru
    e-Guru May 14, 2009
    Okie appologies for confusing you. What I meant is for best performance and high efficiency .
Mackie srm450 amplifier low sound
are you running a sub, daisy chained to it? are they connected to each, just have one, two, four? are you hooked up like in the pic?
Jan 03, 2017 | Mackie Audio Players & Recorders
Can I connect only one speaker to a yamaha emx 312 sc power mixer?
First it is certain that you would not want to plug both outputs of the stereo power amp into one speaker combining both channels into the same speaker. (see image from manual below - also link to manual)
Next I would be very concerned about only using the one side of the main amp out as it could cause an unbalanced load, or you could be driving the load into dead air connection and any of these conditions are destined to cause premature failure of the power amp.
Taking a quick scan of the manual for this unit, it appears what is pretty common to most powered mixers, hook up two matched speakers/loads to each chanel of the output.
Your best bet is to shed those monster cabs, there really is no need for them especially with this sized powered mixer, and get yourself a nice pair of full range cabs like EV1202;s, EV SX300's, or some nice 2 or 3 way 15" JBL's/
Just my opinon.
Link to Yamaha EMX 312 Owner's Manual:
Yamaha EMX Series Owners Manual
Dec 06, 2013 | Yamaha Music
3 monitors required for emx5016cf-- daisy chain? Any way to EQ monitors?
There are several ways to solve the problem. Probably the simplest technically is to connect a powered speaker (or separate amplifier) to one of the ST OUT jacks in the master section of the top panel for the third speaker, and connect the other two speakers directly to the speaker jacks on the back. The drawback to this arrangement is the possibility of problems with setting the frequency correction (automatic equalizer adjustment). You would have the same problem with paralleling speakers (more on this in a subsequent paragraph) on one channel. It may help to use a second speaker from each channel for the "third" monitor so the automatic EQ is working with the same setup on each channel.
Another method is to daisy chain the mixer by connecting another mixer/EQ amplifier to the pre-EQ SUB OUT jacks to drive the third speaker. This permits independent equalization and level setting for that monitor. (You would probably set this EQ first with the main outputs all the way down, then set the EQ on the two primary monitors.)
Regarding multiple speaker connections to the speaker out jacks: Do not connect them in series ("daisy chain"). Unless they are very closely matched, varying responses in the speakers may cause distortion, and each will be running at about half power. You can connect them in parallel (the + terminals are both connected to the SPEAKER jack + terminal, and the likewise the - terminals are all connected together), if the total impedance is as least 4 Ohms. Note that when two speakers are in parallel, the impedance is calculated as follows: (X1*X2)/(X1+X2), X1 is the impedance of one speaker, and X2 is the impedance of the other. In other words, parallel connection reduces the impedance, and too many in parallel will overload the amplifier. If both speakers are 8 Ohms, this works out to 4 Ohms. See page 29 of the owner's manual.
Dec 02, 2013 | Yamaha Emx5016cf Emx-5016cf Powered Mixer
I'm a guitar player, never had to mess with the PA system. I needed to come up with a monitor system to work with a non powered mixer used for powered mains. I can't afford good powered speakers, so I...
This mixer will run 2 8 ohm cabinets per side, if this is an older unit, it has only one NL2/combo jack per channel....with the button on the front panel in the Main Monitor position you can run 2 main cabinets and 2 monitor cabinets, you will have to daisy chain your speakers.All speakers powered from the back of the unit must be passive, no powered speakers.....if you want to use this head just to run moitors and run a pair of powered mains then connect the jack on the front that says main out to input of your powered speakers, hopefully your powered speakers can be daisy chained at low level, then if you want to use the 8600 to power only monitors, get a 1/4 in y cable and plug it into monitor out on the front of the mixer and then plug it into PA 1 and PA 2 to the right there and both sides will now be the monitor mix from this mixer and it will run 2 speakers per side, as long as the cabinets are 8 ohms.
Oct 09, 2013 | Peavey XR Series XR8600 Powered Mixer
What is the actual watts per channel @ 8-ohms and 4-ohms on the Behringer PMP3000?
Those specs would be right - I have this same board but the amp was fried by a previous owner. I pulled the amp board out and tossed it and use the mixer now to drive an external amp. Great board. This amp is rated at 1200W "peak", bridged into an 8ohm load. That would equate to about 900W RMS bridged into 8ohm or 450 per side into 4ohm loads per side. You can't daisy chain all 4 speakers....impedance would be too low. You can run two of your 8ohm speakers per side - that results in a 4ohm load per side for the amp. That would give you amp delivery of 450W per side. Your speakers are rated to handle more than that so you're fine. For the record.....you could run one speaker per side no problem....just lower power output.
Aug 16, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
Speaker daisy chaining , am I going to damage my amp etc.?
The Peavey CS4080HZ is intended to place 2,040 watts
per channel into four-Ohm-rated speaker
impedances. The "HZ" suffix is intended
to state the amplifier has a relatively high
impedance output and is optimized for no
lower than four-Ohm loads. Are you strapping in Bridged or Stereo Mode? Bridged Mono Operation
Both amplifier channels can be bridged together to make a very powerful single-channel monaural amplifier. Use
extreme caution when operating in the bridged mode; potentially lethal voltage may be present at the output
terminals. To bridge the amplifier, depress the rear panel Bridge switch to the IN position. Direct the signal to channel
A's input and connect the speakers across the hot outputs (the "+" binding posts) of channels A and B. Only channel
A's input attenuator is active while in Bridge Mono mode. Both connectors are strapped together, so either connector
can be used with a patch cable to drive the input of another amplifier.
Unlike the stereo mode, in which one side of each output is at ground, both sides are hot in bridged mode. Channel A's
side is the same polarity as its input with the minimum nominal load impedance being 4 ohms (equivalent to driving
both channels at 2 ohms) in bridged mode. Driving bridged loads of less than 4 ohms will activate the DDT
circuitry, resulting in a loss of power, and may also cause a thermal (overheating) overload.
Therefore, check the impedance of the cabs for each mode. Remember, if you connect two individual speakers in Parallel (+ to + and - to -) you cut the impedance in half. Two 8 ohm speakers in parallel now have a load of 4 ohms. Series connection + to - to + to -, will double the impedance. Two 8 ohm speakers will have a load of 16 ohms.
I have actually taken a two speaker cab with a 4 ohm impedance and opened up the back to re-do the wiring. I rechecked the impedance with a ohm meter. So yes, be careful. Whatever you do, keep the speaker lengths as short as possible. Buy really good speaker wire or if you make your own, go with 10 gauge wire.
May 02, 2017 | Music
Hi i have 2x ev sx300 speakers (speakon) and 2x peavey es 315 (1/4 jack) can i daisy chain the ev's from channel a and the peavey's from channel B (all speakers are 8 ohm). Also should speakon...
Yes, you can put two 8 ohm speakers daisy chain per side MAX. The Speakon should have ONLY two wires on the +1 and -1 terminals unless you are using bridged mode which is NOT applicable in your configuration of speakers. Also be careful is you use any 1/4 inch speaker plugs in the sytem as the SLEEVE, not the TIP of channel A is the "hot" lead... get this to ground someplace and goodbye amp.
Jul 03, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Can I plug just one subwoofer into my Yamaha EMX88S? What kind of sub do I need to get for it? Do I need to have 2 subs plugged in for it to sound right? Do I daisy chain the subs with the A15 speakers I...
it is not reccomended to daisy chain passive subs with main speakers, because there is no crossover unit involved. you want a sub to have a crossover frequency around 100hz, so that only frequencies lower than this go through the subs, and not in the main speakers.
you could get away with 1 sub plugged into the mono output on the front, subs dont have to be stereo. you would need a self popwered sub, or an additional amplifier+crossover for passive subs. your best bet would to be to get a powered sub and hook it up to the front panel mono out. powered subs usually already have the crossover built--in.
Nov 25, 2010 | Yamaha Emx88s Powered PA Mixer System
I have a Crate PA-8 4 ohm 150 watt PA head that I run to four Peavy 10" PA speakers (two per side in series). It was very good, clean sound, but the speakers were cheap and may have been pushed too hard -...
150 watts should be easily handled by four Peavey speakers in the connection you described.. If the Peavey's are 8 ohms, then your total load was 8 ohms for the series/parallel arrangement which is well within the 2 ohm drive capability of the Crate according to specs.
I question if you really mean the speakers were in series? This requires a special cable to do this. Now if you mean they were "daisy chained" like the amp went to one speaker and another cable connected that speaker to another, then you REALLY had ALL speakers in parallel electrically which would be at the 2 ohm low limit of the amp... In either case, with only 1/4 of the 150 Watts to each, the speakers should NOT have been damaged. The amp MAY have been damaged. Try each speaker individually at a REASONABLE level to test.
If you plug into the effects loop out jack,OFTEN the connection to the internal power amp is broken so you might have to arrange a special cable as a wye to go back into the power amp as well as your external amp. In any case pwere ALL interconnected amps, etc from the same power source/receptacle for system safety.
Jul 15, 2010 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Can this all be hooked up?
There was never anything mentioned about the 18 yamaha sub in the hook up process
Aug 17, 2009 | Crown CE1000 2-Channel Amplifier
Yamaha Emx88s Powered PA Mixer System Logo
460 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
