Question about Frigidaire FRS26R4A Side by Side Refrigerator
I have a side by side. The problem I am having is that there is water accumulating at the bottom of the freezer side. There isn't any water hooked up so I am thinking there is a problem with the defrost. I took the inside back panel off and I see the grill is frosted up too. What to you think the problem is and how to I fix it please?
  • 3 more comments
  • djcturner May 14, 2009
    Thanks for the reply but it doesn't solve my problem.
    #1 I have a side by side
    #2 I don't have water hooked up.
    #3 My water problem is on the inside so it can't be froma drip pan.
    I removed the evaporator cover to expose the evaporator. The water builds up in and under the drain trough. Then spills over into the bottom of the freezer where it then freezes up. I am assuming the water problem has to be a defrost problem.
    Problem unsolved. need assistance please.
  • djcturner May 15, 2009
    Thank you very much. I suspected the defrost. Thank you for the solution.
    This makes since to me. I will look into replacing the timer. Thank you very much for the solution to my problem.
    Novelist:
  • 151 Answers
Thats a definate problem of defrost timer the defrost timer is a device which sets out command to defrost the frozen ice blocking up.between the evaporator coils.if the timer is faulty it does not send commands for defrosting which lets it go on and freezing and blocking until its completely blocked and there is no place for cool air to circulate and hence some of water startys melting and gets accumulated at bottom of the unit. to fix this problem you will have to replace the defrost timer.it costs approx 40 dollars.you can order defrost timer online from: http://www.repairclinic.com/
once the timer is replaced let the ice melt completely for sometime . the problem will be solved definately
thanks and do not forget to accept the solution .thanks for using fixya.keep updated.
Posted on May 14, 2009
    Genius:
  • 1,847 Answers
The freezer has an obvious leak. When we wait a few days, we can see that water leaked into the freezer and it turned into a large brick of ice? What does that mean?
Hi Monica,
This seems to be a problem with overflow of water into the ice maker, or a leak in the feeder to the ice maker. My suggestion is to turn off the ice maker by raising the lever on the unit, and see if the ice re-accumulates. This would mean that the water is leaking from the inlet, and the ice maker has no obvious fault. If you find this, you can remove the ice maker from the freezer by removing the screws holding it to the inside, unplug the unit from the back of the freezer, and pull straight out. Look at the inlet of the water at the rear of the freezer and see if there is a break in the line or a crack somewhere along it. You can replace it from the back of the refrigerator itself, going from the bottom where the water is hooked up to the top by removing the panel that guards it.
I hope this isn't too confusing.
Joe
Sep 13, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water collecting in bottom of freezer
Your seal may be bad letting in moist air that provides a source of water to condense on parts of the freezer.
Jul 24, 2010 | Kenmore 53703 / 53706 Stainless Steel Side...
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
We have a side by side Maytag refrigerator. Model # MSD2758DRQ Serial # 14043813YU. The bottom of the freezer is accumulation water and freezing. We turned the ice maker off, and it continued to accumulate...
your drain in the freezer is plugged or frozen ...remove the back panel and pour HOT water down the drain until it runs thru.... hope it helps
Sep 20, 2009 | Refrigerators
Water is accumulating inside the bottom of the freezer.
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Jul 13, 2009 | Frigidaire FRS26R4A Side by Side...
Water accumulates at the bottom of the freezer unit and leaks
You must clear the drain of anything that would cause water to pool up after each defrost cycle. Check your door gaskets for wear. Air entering the ice box can cause excessive frost.
Jul 06, 2009 | Refrigerators
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
Water inside bottom of freezer.
Water accumulation in the freezer more commonly points to the ice maker. Over a period of time, water entering the ice maker can slowly freeze to the point it provides a small restriction and prevents a portion of the water from entering the ice maker. The plastic spout/tube could also have either cracked or shifted and is allowing a small amount of water to leak into the freezer.
Feb 24, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Water accumulation in bottom of freezer in Frigidaire FRS26ZSHB5
take out everything and at the lower inside back of the freezer you have a drain ..... pour hot water till it opens / the water comes from you evap when it goes into defrost and it cant get out the drain / Larry
Nov 25, 2008 | Frigidaire Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
