PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Slow typing on screen
By Eyedoc on Oct 15, 2007
When I type on my Dell Inspiron E1705 Laptop, the letters show up very slowly on the screen.  My typing gets way ahead of what shows up on the screen!
Please help.
Joe
Same Problem
Mar 30, 2009
-   When typing on my Dell Vostro 1500 LapTop, it seems my key board does not keep up with my typing. It's very irregular, sometimes it finishes a sentence on time and then other times, it may stall on one word and when I finish typing - all of a sudden the words all appear at once. the worse part is when trying to backspace, I may hit it five times and it will erase back more than I hit.-   ILOVEPURPLE
Dec 12, 2008
-   slow typing have to wait for it to catch up. Types normal when i remove the ati grapic card software. Cheers-   russ sweak
Nov 15, 2008
-   I am ahving the same problem, but am running xp not vista. I dont show a pcmservice.exe on startup menu. Is there something different for xp?-   diggn89
Sep 05, 2008
-   same problem-   Guest
May 01, 2008
-   I'm having an issue with my Dell XPS 1530 laptop. When I type it seems that the keyboard is slower than my typing speed and it ends up that some letters that I KNOW I hit do not appear in my text. For example, while typing this, if I slow down and type very slowly its generally ok. If I type at the speed I'm used to typing then I have to backspace and correct almost every other word since letters are missing from what I wrote. I have Windows Vista (unfortunately). Otherwise this is a very nice laptop. I have tried locating the offending program in start up as recommended but this program is not listed. I really could use some help if anyone has any tips. Thanx.-   elfgirl
Best Solution
posted on Jan 08, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Solution #2
posted on Oct 15, 2007
Helpful)
sandrew
Rank: Wiz
Rating: 83%, 5933 votes
Unless you are low on memory, you may have a corrupt driver or an incorrect setting, go to my computer icon or on start menu, right click>properties>hardware tab>device manager, then look down the list for keyboard, click the '+' sign, select your keyboard and right click, and select uninstal or delete.
Restart pc and then it will install the keyboard automatically and the driver and should now work as normal
Was this helpful?
Yes
No
Solution #3
posted on Mar 20, 2008
Somewhat Helpful)
manches
Rank: Apprentice
Rating: 78%, 8 votes
The previous post had the fix in the comments. Disable loading of PCMService.exe through Start-->Run-->msconfig, de-select PCMService.exe on the startup tab. Cleared the slow typing problem right up.
Was this helpful?
Yes
No
Solution #4
posted on Oct 30, 2009
Helpful)
noclss2000
Rank: Apprentice
Rating: 94%, 4 votes
those proposed solutions disabling the pmcservice only works if you have a DELL laptop. The pcmservice is linked to the dell media direct. This service is not installed on other computers. I have no idea why this title says generic problem for all laptops when clearly it isn't.
I have yet to find the solution for the non-Dell computers after 3 hours of work on a HP laptop that is having the issue. Just uninstalled symantec corporate 10.2 to see if that was the issue and it is not. I've killed all startup services, checked registry items, malware scans, etc. and I'm kind of at a loss at the moment.
Comments:
Oct 30, 2009
- OK, I have found another fix finally after 3 hours of tinkering around and looking around among other sites.
If the battery is at the end of its life, it CAN cause the performance of the laptop to deteriorate. I know, I wouldn't of ever thought of it either. We removed the battery from the problem laptop and the issue immediately went away.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Sep 08, 2008
Somewhat Helpful)
lucienzerey
Rank: Apprentice
Rating: 75%, 2 votes
AftermI type the second word, I find the first word starting to appear.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
what is the problem of my HP laptop is going to blink2x his display in screen?
Answer
How to choose a ebook reader.Comparison of performances between different models
Answer
went in and adjusted the hibernation settings and now the screen just flickers what is it?
Answer
How do I turn bluetooth on in L300D Toshiba laptop
Answer
Hi there! I have a big problem with my ASUS W3J! First of all my problems starts with that I turned... (More)
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 08, 2007
The letters appearing on the screen a behind my typing speed and the speed that they appear is very irregular. It like they get stuck and then catch up. I have read the previous answer and followed it but my set up seems to be different. I have uninstalled the keyboard driver and reinstalled but it has made no difference.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 733
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
